Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,885 guests, and 584 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,357 mail-order LSR
Topics65,693
Posts634,978
Members10,028
Brakes. Front and Rear. Conical hub. Tips for max performance and set up. #261603
06/28/09 3:13 pm
06/28/09 3:13 pm
midwest
babyz Offline OP
babyz  Offline OP
midwest
Not much different than all other drum brakes, just one question really:
Rear brake lever, the one mounted on the hub, mine is pointing down. I notice on other bikes it is pointing up. Still works down. Is pointing up the prefered position?
any other set up tips specific to these conical hubs?
thanks
1972 TRIUMPH t120r
1973 BMW 75/5
2004 BMW R1150R
1963 LAMBRETTA LI125
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: babyz] #261607
06/28/09 3:31 pm
06/28/09 3:31 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
On my 72 the lever is up but the book shows it down???
The front brakes on these things are a bad joke. I virtually drove without using it for 15 years as it was useless. Then I found Vintage Brake(vintagebrake.com) and I had to learn how to drive all over again. It's amazing how much more fun you can have with a brake that actually WORKS. And works better,much better,than when it left the factory.
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: desco] #261618
06/28/09 4:34 pm
06/28/09 4:34 pm
Melbourne Fl
Terry_tr6 Offline
Terry_tr6  Offline
Melbourne Fl
As far as i know. the lever up/down is limited by clearance of the shock by the brake rod. I wish i could get mine pointing up because due to wear the rod/lever angle is past perpendicular so i lose leverage.
As to the front, the brake switch in the cable often causes problems. I got a straight thru cable(as good quality as you can get) and things improved a bunch. the length is important too. Too long adds to the bends and work against you. Get good linings, keep things lubed and the shoes adjusted. I also adjusted where the hand lever is so i'm grabbing it as near to the end as possible to get the best leverage
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: Terry_tr6] #261638
06/28/09 5:54 pm
06/28/09 5:54 pm
Waldorf, Maryland
Tiger Dale Offline
Tiger Dale  Offline
Waldorf, Maryland
The difference in the way the lever points is because Triumph lowered the frame in that range of years. If yours points down you probably have the higher frame. Mine points up and I have the lower frame. Mine was built in January 1972 my serial #'s start AGxxxx.
TD
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: Tiger Dale] #261783
06/29/09 1:19 pm
06/29/09 1:19 pm
midwest
babyz Offline OP
babyz  Offline OP
midwest
wow. they actually left the factory like this? no wonder they went out of business. i had a drum brake honda that worked as good as a disc...almost too good...what were they thinking?
1972 TRIUMPH t120r
1973 BMW 75/5
2004 BMW R1150R
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: babyz] #261788
06/29/09 1:29 pm
06/29/09 1:29 pm
Blue Ridge, Georgia, USA
Rob Harper Offline
Rob Harper  Offline
The most important part of getting the conical to stop is to true the drum after the wheel is laced up, and to then radius the shoes to the drum. That being said, I'm starting to think this may not be the bike for you. Triumphs have many quirks, and making the bike perform well within their limitations is part of the fun. If it's not fun for you, don't do it.
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: Rob Harper] #270998
08/19/09 6:21 pm
08/19/09 6:21 pm
redondo beach, ca
Bob G Offline
Bob G  Offline
redondo beach, ca
A few years ago, a buddy suggested extending the actuating arms by 1/2 inch to get more leverage. I have a 71 that I am tempted to try it on.
Has anyone tried this?
Bob Gregor
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: Bob G] #271013
08/19/09 7:39 pm
08/19/09 7:39 pm
British Columbia
hh Offline
hh  Offline
British Columbia
I recently bought a '72 A65L from a friend that had it for 20 years. He said he never used the front brake because it was practically useless. Having owned a B50 with an excellent front brake for about a year, I was pretty sure there was a simple reason.
I took the Lightning's brake apart and found oil or grease contaminated linings. Being cheap, I tried cleaning them with brakleen and arcing them to the drum with sandpaper, but the brake was still terrible. The shoes were so contaminated, the oil came back to the surface. Installing new shoes transformed the brake.
When I first took the bike out for a test, I hear this squeaky noise that I hadn't heard before every time I hit the the brake. I couldn't figure out what it was, but it was braking so well I didn't really care. It turned out it was the tire chirping.
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set up. [Re: hh] #271024
08/19/09 8:38 pm
08/19/09 8:38 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
i was once told that the conical brake shoes were the same as those on MGB and other british cars of the period....anyone confirm this??
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: Brakes. Front and Rear. Conical hub. Tips for max performance and set [Re: Bob G] #271173
08/20/09 3:23 pm
08/20/09 3:23 pm
Bishop, Calif.
Bishop, Calif.
On extending the levers. I too have heard that and one of the advertisers on this site sells them. For about what they cost you can have Vintage Brake do a proper brake job.
