maylar
maylar
Connecticut
35 registered members (AML), 234 guests, and 451 spiders.
10257 Registered Users
Stuart 77
Lannis 60
TBolt72 46
609,133 mail-order LSR
Topics67,118
Posts651,344
Members10,257
smiths speedometer repair #266868
07/26/09 10:34 pm
07/26/09 10:34 pm
maxwell Offline OP
maxwell  Offline OP
Hi there
Has anybody any basic maintenance advice for one of the smiths speedometers?
I have an 80 mph one on my b32, It works but sometimes the needle leaps around erratically showing all kinds of random speeds.
Is there a way to maintain them or fix this probem?
Re: smiths speedometer repair [Re: maxwell] #266875
07/27/09 12:05 am
07/27/09 12:05 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
max,
About par for the course for a Smiths. I think there was a thread on repairing these speedos some time back. I have not had any good luck sending them out to be fixed. Might just try it myself sometime. What could be worse it flutters all around anyway. there are some aftermarket speedos for about the same price as a repair...Taiwanese I think. Maybe someone will chime in.
Re: smiths speedometer repair [Re: maxwell] #266879
07/27/09 12:29 am
07/27/09 12:29 am
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
I started a post on that very topic. Check out what Mike and others told me: Smith's repair
Josh
Re: smiths speedometer repair [Re: JD] #266900
07/27/09 2:28 am
07/27/09 2:28 am
Maxwell; Is that a chronometric speedo you have. Most of the advice seems to be for magnetic types.
However if you look in Members Projects under "1955 Triumph Thuderbird WVK 345" on page seven you will find a lot of good information on sorting out the chronometric.
Re: smiths speedometer repair [Re: Gordo in Comox] #266904
07/27/09 3:41 am
07/27/09 3:41 am
Ponoka ,Alberta,Canada
A.k.a Homer Offline
A.k.a Homer  Offline
check the cable is not push in to much.that will kill it.
Aka Homer
A day with out learning something new is a bad day indeed.
Re: smiths speedometer repair [Re: A.k.a Homer] #266930
07/27/09 9:23 am
07/27/09 9:23 am
BSA_WM20 Offline
BSA_WM20  Offline
Usually it is either the cable or the drive and not the head although if it has not been to the shop since BSA installed it then it is way over due for a clean & lube.
Re: smiths speedometer repair [Re: BSA_WM20] #267030
07/27/09 7:54 pm
07/27/09 7:54 pm
maxwell Offline OP
maxwell  Offline OP
Hi there thanks for the pointers, I cannot seem to get the search function to work so couldnt find the other threads.
This is the first time the bike has been ridden for about 15 years i think. Speedo worked fine for about 100 miles, then it started to go wrong.
I'll check those links
Re: smiths speedometer repair [Re: maxwell] #267049
07/27/09 8:36 pm
07/27/09 8:36 pm
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
+1 an what the others said but if you do need a rebuild of your original intrument...
Joel Levine in Atlanta GA did a great job re-doing the Smiths for the Firebird.
http://www.joellevinecompany.com/custompage.asp?pg=vintagegage
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
Re: smiths speedometer repair [Re: Semper Gumby] #267739
07/30/09 7:46 pm
07/30/09 7:46 pm
Canada
Brummie Offline
One time poster
Brummie  Offline
One time poster
Canada
Had the same prob with my speedo, took the cable out, sprayed a bit of WD40 up inside, unorthodox, but it worked and the needle is as steady as a rock.
