Kent Shaun
Kent Shaun
Kent Garden of England
25 registered members (Alan_nc), 208 guests, and 405 spiders.
pemdoc65, creativecroc, gregneal, Chris Marsland, heathcliff
10169 Registered Users
Lannis 100
Stuart 88
reverb 78
NickL 75
koan58 54
548,613 mail-order LSR
Topics66,537
Posts644,984
Members10,169
A65 Valve Clearances #266086
07/21/09 7:27 pm
07/21/09 7:27 pm
Rotherham, UK
Ian Clifton Offline OP
Rotherham, UK
I know the manual says 0.008" for Inlet and 0.010" for Exhaust, but it sures seems 'Clattery' at the top end!! After the extensive re-build I have just performed, I would expect the Engine to seem a little quieter than before (boy was it worn out). Any of you Guys had experience of smaller tappet gaps?
Just a few Beezers.. ☺
Re: A65 Valve Clearances [Re: Ian Clifton] #266089
07/21/09 7:49 pm
07/21/09 7:49 pm
Do not let the clatter noise bother you. I like to hear my tappets so I'm sure my valves are closed when they are supposed to be closed.
I sailed with a diesel engine once where a collegue set the clearance to tight. The damage was 50.000 Dollars worth of damaged turbo charger.
I know your A-65 has no turbocharger, neither has mine, but still I like to know my valves are close.
Re: A65 Valve Clearances [Re: Ian Clifton] #266093
07/21/09 7:58 pm
07/21/09 7:58 pm
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
.008 and .010 is not an unrealistic amount of clearance for an air cooled engine, and when adjusted "properly" should not be excessively offensive by itself. Are the rocker shafts and spindles per spec? Are the spacers, shims and preload springs assembled correctly. Are the pushrod cup ends firmly attached to the pushrod tubes. (i have seen some able to be pulled off.)
Are you sure its valve clatter? Heard at idle, higher RPM, hot/ cold, load. Have you listed with a stethoscope? ALL valves? (1) valve? Piston slap? How much piston clearance you have? Wrist pins fitted properly?
After 500 miles, you will need to re-torque the head and readjust the valves. Good time to reinspect the rockers and related. I usually check clearances before the re-torque as well because i am anal. HAve you accumulated many miles on your rebuild? Was this right from the start? Looking at your list of MC's in the barn, you can not compare this to a 2009 Triumph. The BSA will make some noise. You need to determine if its normal. IF the valves are properly adjusted, and all is properly assembled and to spec., then its probably normal. DO NOT reduce clearance unless you want to flirt with burnt valves.
Re: A65 Valve Clearances [Re: nert] #266103
07/21/09 8:42 pm
07/21/09 8:42 pm
An A65 with its one-piece sound-amplifying valve cover and a small gas tank is always going to make some valve noise.
.008 and .010 valve clearances have a LOT of history behind them. You could open them up a few thousandths and it wouldn't hurt a thing - open them too much and the valve timing will be off and the cam will start "slamming" the valves.
You MIGHT be able to get away with closing them up a little for a miniscule reduction in valve noise. But if, upon reaching operating temperature, you miscalculated or mismeasured even .001" off of your tighter clearance (say .005 instead of .006), and the exhaust valve is not able to make full and tight contact with the head every revolution and transfer its heat to it, then you're going to burn the exhaust valve sure as God made little green apples.
Just not worth it. Not to me anyway, your mileage may differ.
Re: A65 Valve Clearances [Re: nert] #266104
07/21/09 8:44 pm
07/21/09 8:44 pm
Rotherham, UK
Rotherham, UK
Many thanks for your reply Ger. In respect of your answer nert, I started the re-build late last year after running the bike for 6 months with an extremely worn engine. I don't remember the 'top end' sounding as loud as it does now. As far as piston slap etc.. the barrels are re-sleeved to std with BSA NOS pistons fitted. The gudgeon (wrist) pins fit just ok. New rocker shafts fitted etc.. I was very careful during the re-build to ensure all correct procedures were followed. I have only just been running the engine for the last two days after re-building. Maybe I should give more time for bedding in..
Re: A65 Valve Clearances [Re: Lannis] #266105
07/21/09 8:48 pm
07/21/09 8:48 pm
Rotherham, UK
Rotherham, UK
[quote=Lannis]An A65 with its one-piece sound-amplifying valve cover and a small gas tank is always going to make some valve noise.
Lannis, I think you may have hit the nail on the head !!! perhaps the above plus some bedding in being required is the cause...
Re: A65 Valve Clearances [Re: Ian Clifton] #266126
07/21/09 10:36 pm
07/21/09 10:36 pm
Brooklyn, NY, USA
jholmes Offline
jholmes  Offline
Brooklyn, NY, USA
Hi guys,
This is interesting. Over the years, have pushrods been manufactured in different materials for the A65, both OEM and aftermarket? And then, does that make a difference for rocker clearance? My engine has aluminum alloy (seems like anyhow) pushrods with steel cups on the ends, but I'm certainly not the original owner. Just wondering if it would make a difference how you set the clearance if steel (or other type) pushrods are or have been available?
Also, I saw (heard) a guy on an old vincent the other day, and his bike was WAY more clattery than the A65. Not sure what year or model, but it was more the trailer queen type than my daily rider A65. Man, that thing was clinkin and clankin away. My T-Bolt clicks a bit, but not something I ever thought was unusual, especially not after hearing that thing run.
Cheers!
-Jason
Re: A65 Valve Clearances [Re: jholmes] #266129
07/21/09 11:08 pm
07/21/09 11:08 pm
nert Offline
nert  Offline
Originally Posted By: James Holmes
Hi guys,
James, I do believe that is the standard for BSA A65l engines.
Rothery35
I'm sorry if i ruffled feathers. (i don't speak well)Just trying to inspire some thought.
I usually kick my re-assemblies over many times with no spark plugs to "squeeze" oil out of the pushrod cups and "centralize" the mechanical forces at hand before i make my final valve clearance adjustment. Then i kick it through some more and check again, before i install the valve cover.
It sounds like you have performed a real nice quality rebuild. Comprehensive, and no cut corners. I am excited for you. Proper break-in is key for long life on these machines. I am sure you will find the Old Brit Iron, fast to becoming a favorite.
Re: A65 Valve Clearances [Re: nert] #266141
07/21/09 11:59 pm
07/21/09 11:59 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Rothery, FWIW:
when i got a new toy (M20) the other week the PO told me he had put 50/50 Avgas (propper leaded petrol like A65 was designed to run on) in it.
I figured since I didnt know how old the petrol was i would syphon it out and stick it in the A65...if it was a bit stale i figured the real strong spark on the A65 would burn it anyhow.
FFS!!!! what a diffrence! all the valve rattle practicaly disappeared , you could hear it quietening down as the carbs refilled with real petrol. The diffrence in engine noise was real dramatic!....so was the preformance! (I knew the valves were set right 8/10)
Recon it just shows what we have become used to with THIS SHI* "FUEL".....
Re: A65 Valve Clearances [Re: Ignoramus] #266170
07/22/09 1:49 am
07/22/09 1:49 am
nert Offline
nert  Offline
what are we supposed to do, buy aviation fuel?
do the additives work?
Re: A65 Valve Clearances [Re: nert] #266192
07/22/09 5:04 am
07/22/09 5:04 am
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
[quote=nert]what are we supposed to do, buy aviation fuel?
the point i was trying to make is that these bikes were designed for leaded fuel...running them on uleaded CRA* (which is the only practicle option) has consequences like upper cylinder noise.
I guess the additives do some good but how much is the question?
Re: A65 Valve Clearances [Re: nert] #266260
07/22/09 4:59 pm
07/22/09 4:59 pm
Bethesda, MD
V
Valk Offline
Valk  Offline
V
Bethesda, MD
So better gas can reduce valve noise?? I know it reduces knocking (pinging) - I have to but top shelf Shell or Sunoco in my '56A10 RR or else it pings under load. Didn't have to do that a few years ago...gas quality is getting worse in this respect...
Peter
'56 Road Rocket
'66 Lightningbolt
'98 Valk
Re: A65 Valve Clearances [Re: Valk] #266266
07/22/09 5:17 pm
07/22/09 5:17 pm
I'm not sure that better gas can reduce valve noise, but it can reduce engine noise overall with its smoother burning characteristics, like giving the piston a "push" rather than whacking it with a hammer like 87 octane does, and by reducing any noise associated with "pinking" or "detonation".
A65s definitely run better with 100+ octane fuel, any of them do.
Problem is, it's difficult to obtain avgas, and illegal to burn it in your road-going bike. I'm not a stickler for the law, mind you (the bike I rode to work this morning has an inspection sticker (MOT to the Brits) that's 2 years out of date), but the fact that untaxed fuel isn't legal on the road takes it out of the "long term solutions" for better running.
I just tune my bike (compression, carbs, and ignition advance) for whatever ethanol-diluted crap they sell as fuel these days and put up with the lower power and worse gas mileage.
My Guzzis, with one-piece tin valve covers sticking out in the breeze, make all KINDS of valve clatter. It's how you know the bike is happy!
Re: A65 Valve Clearances [Re: nert] #266280
07/22/09 6:46 pm
07/22/09 6:46 pm
Northern California
2
2ndchildhood Offline
Northern California
I just posted in another thread that 100 octane racing fuel is available at a few gas stations in CA. That may be true in NJ as well. Do a google search.
-Tony
73 Norton Interstate
72 Triumph T100R
67 BSA 441
Re: A65 Valve Clearances [Re: Lannis] #266283
07/22/09 6:52 pm
07/22/09 6:52 pm
I like that description of the frying pan size rocker cover.
But the tank wether is the small US-tank or the larger European tank makes no difference, I think. Mine clatters with 4 and 1/2 gallons of ... why don't you fellows use 18 liters... crazy of fuel over it. But the sound changes when the fuel level drops over a longer ride. But I think that's the resonance sound the tank itself makes, and it changes with fuel level.
Re: A65 Valve Clearances [Re: Ger B] #266299
07/22/09 8:16 pm
07/22/09 8:16 pm
sweden
nisse Offline
nisse  Offline
sweden
The various sounds it makes tells me that its happy
when one sound stops then I begin to worry
Re: A65 Valve Clearances [Re: nisse] #266567
07/24/09 6:26 pm
07/24/09 6:26 pm
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
Hi Rothery35,
I'm running both the 71 T'bolt and the 69 A65 Firebird at .006" intake and .008" exhaust and they run fine. I have noticed more valve noise when the bike first starts and the oil is not flowing to the head yet. Also I have noted more clattering when the bike is really hot (after a good thrashing) and the oil is really thin at idle.
Couple of thousand miles on each with out head trouble.
But don't get me started about AMALs and their sinking floats...
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Parking lot Elf in training
Re: A65 Valve Clearances [Re: Semper Gumby] #266580
07/24/09 7:53 pm
07/24/09 7:53 pm
Rotherham, UK
Rotherham, UK
Hi Semper,
Your statement is very interesting. I removed the Rocker Cover when the Engine was hot and re-checked the Valve clearances. It seemed as if they had widened!! I will use your values and report back.. Watch this space..
Re: A65 Valve Clearances [Re: Valk] #266581
07/24/09 7:57 pm
07/24/09 7:57 pm
Rotherham, UK
Rotherham, UK
[quote=Valk]So better gas can reduce valve noise?? I know it reduces knocking (pinging) - I have to but top shelf Shell or Sunoco in my '56A10 RR or else it pings under load. Didn't have to do that a few years ago...gas quality is getting worse in this respect...
BTW Valk, I have being using, what we call in the UK 'Super Un-Leaded' in the A65 with still some 'Pinking' under load...
Re: A65 Valve Clearances [Re: Ian Clifton] #266583
07/24/09 8:12 pm
07/24/09 8:12 pm
Atlanta, GA USA
Atlanta, GA USA
Hi Rothery35,
Those are cold clearances. Don't set while hot please.
Plinking under load: Sign of the times...alcohol fuel. I got rid of most of my plinking under load (around 4200 rpms) by richening the needles one notch. This helped a bit. Otherwise I just down shift..
I may try moving the timing more towards 32 degrees max as an experiment but I need a degree wheel first so I can see where it is right now. Curiously the 1971 Thunderbolt runs just fine whith out plinking at all. The 1969 Firebird is the one that "plinks".
Gaggle of BSAs
a Honda
an old BMW
and a Montesa
Re: A65 Valve Clearances [Re: Semper Gumby] #266587
07/24/09 8:50 pm
07/24/09 8:50 pm
Rotherham, UK
Rotherham, UK
Hi Semper,
I only ever adjust them cold. My meaning of "re-checked when hot" was just to observe what had happened to the clearance after getting hot..
Many thanks for your input..
Re: A65 Valve Clearances [Re: Ian Clifton] #266615
07/25/09 2:10 am
07/25/09 2:10 am
Middletown, NY
mxman1 Offline
mxman1  Offline
Middletown, NY
I know I'll get hounded on this one BUT....back in the day, I would get my 67 Lightning totally warmed up and quickly pop the gas tank and valve cover and set the valves so that there was just the slightest play. Gained a lot of performance doing this. granted, very unorthodox.
Todd
Page Time: 0.082s Queries: 15 (0.005s) Memory: 1.1626 MB (Peak: 1.4866 MB) Zlib disabled. Server Time: 2018-04-19 10:04:34 UTC
