29 registered members (998John),
196
guests, and 443
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics66,612
Posts645,585
Members10,175
Most Online3,995 Feb 13th, 2017
BSA A65 crankshaft idler pinion removal
#265908
07/20/09 7:58 pm
07/20/09 7:58 pm
Posts: 14 South Wales
UNF
South Wales
Hi, Need some advice on removing the crankshaft idler pinion on my A65 lightning 71' engine. The user manual advises that BSA extractor tool 61-3676 should be used, but what I'm not sure about is whether this is just a small puller or some special tool. Also, the pinion only has one machined slot (see picture), so I'm not sure if a puller will work.  Cheers, UNF
'71 BSA A65 Lightning
Re: BSA A65 crankshaft idler pinion removal
[Re: Alex]
#265929
07/20/09 9:53 pm
07/20/09 9:53 pm
Posts: 529 Norway
Ola
Norway
The idler gear needs some kind of a puller, the gear on your picture however will usually get off with the aid of two suitable screwdrivers. If still stuck, try a little heat.
Best regards
There are no bosses in a technical discussion (Doug Hele, 1919 - 2001)
[Re: UNF]
#266284
07/22/09 6:55 pm
07/22/09 6:55 pm
UNF
South Wales
Thanks for the feedback. Hopefully, one way or another I'll be able to get the pinion off!
UNF
[Re: leon bee]
#267146
07/28/09 3:10 am
07/28/09 3:10 am
Posts: 4,947 Gnashville
DavidP
That's the first one I've seen that just has one slot. I wonder if you could cut another slot with a die grinder/dremel. If its on there real tight, the large screwdriver method can be kinda ugly. Maybe I'm not sure what y'all mean, but my 71 parts book shows only one keyway and one "slot" in the crankshaft. In any case, , I'd use two Wonderbars to ease the gear off the shaft, at least until you have enough space behind the gear to use a gear puller.
71 A65L "Zelda" 92 BMW K100rs "Gustav" 72 T120V cafe project "Mr. Jim"
[Re: DavidP]
#267157
07/28/09 3:44 am
07/28/09 3:44 am
Posts: 2,792 Comox BC Canada
Gordo in Comox
I don't think we are talking about the crank keyway. I think the 'slots' are the grooves for use with a puller. This shot shows the top groove reasonably well and the bottom groove if you really look. I have never seen this gear with only one slot for pulling it off. Gordo
[Re: Alex]
#267470
07/29/09 2:44 pm
07/29/09 2:44 pm
Posts: 68 FRANCE
SERGE A65
FRANCE
This is an obvious manufacturing error. I have a dozen engines from 1962 to 1970. Everyone has a pinion with two slots. In such a case, do not hesitate to machine a second slot, using a grinder equipped with a narrow disk. These slots are the best solution to remove the pinion without risk for the cranckcase and sprocket teeth.
1965 A65 STAR 1968 A65 LIGHTNING
[Re: DavidP]
#267864
07/31/09 1:35 pm
07/31/09 1:35 pm
UNF
South Wales
Hi all, Well, I took a chance and knocked the crankshaft through the casing, with a rubber mallet I might add. No damage to crankshaft assembly and pinion, but the plain bearing got a bit scored. I was intending to replace this, but obviously will have to now! Next task: remove the pinion. New slot 180 degrees opposed to the existing one is the option I'll investigate first.   Thanks for all the feedback. Cheers, UNF
[Re: UNF]
#324846
07/26/10 8:00 am
07/26/10 8:00 am
Posts: 1 Alberta, Canada
JohnTaylor
One time poster
One time poster
Alberta, Canada
I have mine off, any advice on getting it back on without upsetting anything?
Cheers!
72 BSA Lightning
