DamienE
DamienE
Palm Bay, Fl.
36 registered members (AML), 209 guests, and 59 spiders.
10383 Registered Users
NickL 98
Mori55 89
Stuart 77
reverb 76
DavidP 71
Triless 71
Rohan 69
btour 65
689,335 mail-order LSR
Topics68,024
Posts661,788
Members10,383
NGK sparkplug caps? #263771
07/09/09 1:06 am
07/09/09 1:06 am
San Francisco Bay Area
MarksterTT Offline OP
Wondering if someone could help me here, I just received my Pazon ignition for streettracker TRI project and the kit came with 90* 5K ohm red plug caps. I would like to replace them with 120* caps but in searching have only found " black" caps. Question is, what is the difference between red and black caps? The boxes they came in even say (red) after the part no. Any help appreciated, Mark
Re: NGK sparkplug caps? [Re: MarksterTT] #263813
07/09/09 6:00 am
07/09/09 6:00 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Cyclewearables.com says the red are NGK "racing wires". They also have "Nology" wires that produce a spark 300 times more powerful than stock because they put a capacitor in the wire. Apparently creating power from thin air.
Re: NGK sparkplug caps? [Re: DMadigan] #263837
07/09/09 1:29 pm
07/09/09 1:29 pm
spfld vt
phantom309 Offline
phantom309  Offline
spfld vt
As long as they are 5k caps it should not matter the color.I have 3 red and one black.I have a duel plug head so 4 plugs.Some systems are touchy about caps.My pazons is crank triggered.
Tim Joyce
sponsors
D@D cycles
Works shocks
Glass from the past
Re: NGK sparkplug caps? [Re: phantom309] #263875
07/09/09 6:00 pm
07/09/09 6:00 pm
O.K., thanks guys, maybe it's just an aesthetic thing but I couldn't think of why they would go to the trouble, my first & only thought was higher temp. plastic but then I've never had trouble with melting plug caps no matter the color. I'll just get the black, I want 120* caps for ease of ht lead routing.
Tim, I have the std. dual plugged kit as I will be running alternator for street, otherwise crank triggered would have been nice.
Re: NGK sparkplug caps? [Re: MarksterTT] #263909
07/09/09 10:04 pm
07/09/09 10:04 pm
Stuart Online content
Stuart  Online Content
I'm not certain but you might want to do some more research - for some reason, I have it in the back of my mind that red plug caps are resistor plug caps, black are non-resistor.
Re: NGK sparkplug caps? [Re: Stuart] #263931
07/10/09 12:57 am
07/10/09 12:57 am
I found both resistor and non-resistor in all configurations but in black. The only other off-the-wall thought I had was that maybe red were for racing with high energy ignitions where you might not want black caps if they were pigmented with carbon black, in case there were issues with spark tracking but that's just my weird thinking...thanks for input, Mark
Re: NGK sparkplug caps? [Re: MarksterTT] #264247
07/12/09 10:26 am
07/12/09 10:26 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
In the UK, the Red NGK 5 kOhm resistor plug caps have certainly been around for many years, the Black NGK caps were generally the non-resistor type, however NGK do seem to make resistor caps in Black as well as Red these days, but there is no actual difference between them as far as I can tell?
http://www.ngkpartfinder.co.uk/files/NGK_Spark_Plug_Covers.pdf
Re: NGK sparkplug caps? [Re: L.A.B.] #264585
07/14/09 2:01 am
07/14/09 2:01 am
Thanks for the site L.A.B., it appears there is no diff. other than choice of color...I'll just find some 120* caps for the inner plugs and call it good...Mark
Re: NGK sparkplug caps? [Re: MarksterTT] #265700
07/19/09 6:18 pm
07/19/09 6:18 pm
Irwin, PA
TrmptRacer Offline
TrmptRacer  Offline
Irwin, PA
Just a word of caution on the Nology wires. I had a very good mechanic tell me that due the charge time of the capacitor in the wire, that at relatively high RPM's, ignition timing is retarded. Wanted to test it on dyno but the bike (a nicely done BMW cafe racer) left the shop to soon.
Keller Racing
"Performance By Design"
keller_racing@netscape.com
www.KellerRacing.net
http://www.cafeshops.com/KellerRacing
Re: NGK sparkplug caps? [Re: TrmptRacer] #265995
07/21/09 7:03 am
07/21/09 7:03 am
FRANCE- DINARD -BRITTANY
marinatlas Offline
marinatlas  Offline
Hi there, most of NGK plug caps are engraved with the resistance value on them, and/or you could take an ohmeter to check the value.......
Re: NGK sparkplug caps? [Re: DMadigan] #266232
07/22/09 1:53 pm
07/22/09 1:53 pm
The same amount of "power" is there - the capacitance of the wire allows voltage to build up longer, and then be converted to current when the voltage overcomes the ability of the capacitor to hold the charge.
Coils do the same sort of thing - convert high current and low voltage into low current and high voltage. Since Power = Voltage x Current, you don't have to "add" power to get higher voltage.
