The Bonneville Shop
CaptainPugwash
CaptainPugwash
Conisbrough,Yorkshire, UK
22 registered members (Alan_nc), 204 guests, and 438 spiders.
10528 Registered Users
franko 90
NickL 66
785,121 mail-order LSR
Topics69,220
Posts674,261
Members10,528
Replacing the fork oil seals 64' A65 #259662
06/17/09 3:50 pm
06/17/09 3:50 pm
Indy
Vox Teardrop Offline OP
Indy
Do I need any special tools to remove an re-install new fork oil seals? The manual mentions a couple of service tools.
Cheers!
95' Triumph Speed Triple
72' Triumph T120
64' BSA Lightning Rocket
Re: Replacing the fork oil seals 64' A65 [Re: Vox Teardrop] #259667
06/17/09 4:12 pm
06/17/09 4:12 pm
I do mine on the bench, with the fork tubes out of the clamps.
1. You have to remove the fork seal holders. I bought the tool (which is a "pin wrench" where two pins fit into two holes and you just screw it off). You CAN fight the thing off with a strap wrench and a lot of leverage, but if it's on there tight with years' worth of internal corrosion on the threads, it'll be an epic battle and you MIGHT squash the chrome holders or scar the finish. I like the tool.
2. You have to pry the old fork seals out. This is pretty straightforward but they can be tight - don't damage the interior surface of the slider.
3. You have to drive the new fork seals in. BSA makes a special tool for this that centers the seal driver and makes sure it goes in square. After trying to tap one in with a punch by going around the diameter and trying not to cock it in the slider (and then damaging the seal when the punch slipped) I made a driver of my own out of a pipe nipple of the right size and a little handwork with a file. Drove right in then.
4. You need a tool to pull the forks back into the clamps when you're done. The manual says that if you don't have a special tool for this, you can screw a broomstick into the fork threads and use that to pull it up into the taper. All that's ever done for me is to leave a bunch of broomstick shavings inside the fork. I bought the tool and quit worrying about it.
Good luck.
