MikesClassics
MikesClassics
Queensland, Australia
209 registered members (68 royalstar tony), 1,770 guests, and 586 spiders.
10032 Registered Users
Lannis 144
kommando 102
476,308 mail-order LSR
Topics65,711
Posts635,140
Members10,032
Page 2 of 2 1 2
Re: Best electronic ignition [Re: hh] #232055
01/10/09 2:18 am
01/10/09 2:18 am
Adelaide
Steve Kelly Offline
Steve Kelly  Offline
Adelaide
hh,
I presume the Analogue systems in question make the advance something like what you suggested by utlising the increasing voltage developed by the magnets and coils as the RPM increses to trigger the spark slightly sooner in the rotation.
I've tested a number of Analogue systems for customers and found varying advance curves as has already been said before.
The worst one I've seen had almost no advance / retard and reached full advance just above idle.
To be fair these are old systems - possibly 20 years old - that were cheap to buy in the first place.
As an aside I've tested 2 RITA systems (again at the request of customers) and both had the same curve which matched pretty closely to what has been published on the web. The later AB11 amp had improved spark duration over the AB5 and looked a nicer part.
By doing the advance / retard digitally things can be vastly improved.
For example the Tri-Spark "Classic Twin" adjusts the timing digitally in 50 RPM increments in a chip and does this on each crank revolution. (I presumme other digital systems would do a similar thing)
With the advance / retard programmed into the chip there is little chance of variation from one unit to the other.
The exact values for the timing we arrived at by dyno in combination with riding and endless trails under different conditions.
As always, happy to hear from you,
Steve from Tri-Spark
www.trispark.com.au
Steve Kelly
www.trispark.com.au
Re: Best electronic ignition [Re: Steve Kelly] #232065
01/10/09 3:24 am
01/10/09 3:24 am
Ron - in California R.I.P. Offline
Gosh, lots of exPURTS in the world..lots of unneeded bells and whilstles too. Currently none of the above named ignitions are "perfect." They all have some form of compromise. Getting full advance at 3,500 rpm's is fine for first gear, do that in top gear uphill and you may just find a nice hole in the piston.
What you want, you can not easily have... that is fact. You want a ton of advance under a light throttle while cruising (for a bit more fuel economy not performance). You want less advance excellerating until you reach X rpm's where you are less likely to detonate. And of course you want a bunch of retard for easy starting. For years, cars accomplished a lot of this with a centrifugal advance combined with a vacuum advance. The vacuum advance quickly retards on throttle opening. Then some of the first electronic ignitions came out, still using the same advance as before. Today you have a computer with a complete feedback system with a knock sensor, so you get the most advance and not burn a piston. Some systems do a LOT more checks with even more sensors.. all of this adds a lot of cost..
It is a LOT safer (especially with the crap we call gas today), to have full advance at a higher rpm, and run just a tad less advance when someone may be tempted to "lug" an engine.
So, yes all the aftermarket ignitions work just dandy... and do not have much differences that are meaningful, just marketing hype, and customer preferences.
Ron
Re: Best electronic ignition [Re: Blapper] #232096
01/10/09 12:19 pm
01/10/09 12:19 pm
belgium
ludwig Offline
ludwig  Offline
belgium
Ultimately , the correct ignition timing depends on the combustion speed of the mixture , wich is function of many factors .
Any ignition curve that is function of ONLY engine rpm can be no more than a crude compromise .
Even the ' best ' electronic ingitions available for our Brit bikes are stone age technology .
Re: Best electronic ignition [Re: ludwig] #232144
01/10/09 5:22 pm
01/10/09 5:22 pm
British Columbia
hh Offline
hh  Offline
British Columbia
Ron and ludwig, you both make valid points (heh, heh) but with a sympathetic operator, a mechanical advance can work quite well. I'd rather have too early an advance like points give in some circumstances, and need to be careful with the throttle in high gear up hills, than to have impeded acceleration in the lower gears when you need more advance for best power. From personal experience, the analog Boyer advance curve is too late for most average road use, but it is a compromise I have learned to live with in order to not need the ongoing maintenance of a twin points setup. On my singles, I have so far stuck with points and been happy with them.
Re: Best electronic ignition [Re: hh] #232147
01/10/09 5:28 pm
01/10/09 5:28 pm
Northern KY
Ron T. in KY Offline
Northern KY
Dyno Dave has done a lot of testing and posting of the various ignitions, see link below, He also repairs and will have replacement amplifiers.
http://atlanticgreen.com/bsamain.htm
You can see the curves of points, BB and the Rita...
Nobody mentions Pazon here, and we have had great performance with the Pazon on several race bikes.
Best is going to be a subject choice, since what is best for one will not be best for all...
If you don't like change, you're going to hate extinction...
75' Commando
71' Bonneville
71' BSA Firebird
71' B50 Street tracker
62' BSA A10 Super rocket
60' BSA DBD Goldstar roller
97' Buell S3T
09' KTM 990 Adventure
00' Sherco 2.5
Re: Best electronic ignition [Re: Ron T. in KY] #232158
01/10/09 6:10 pm
01/10/09 6:10 pm
belgium
ludwig Offline
ludwig  Offline
belgium
I plotted the Pazon Shurefire for Norton commando( black line ) compared to 4 Boyer analog ( courtesy Dynodave )
Re: Best electronic ignition [Re: ludwig] #232168
01/10/09 7:51 pm
01/10/09 7:51 pm
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
HH, the advance of the Boyer is not from the speed of the magnetic field, they use a tachometer circuit to change the advance timing. The speed of the pickup magnet comes into effect in the lowest RPM that will trigger the circuit. The pulse output from the pickup is dependant upon the strength of the magnetic field and velocity past the coil. These analog systems are basically exponential since they rely on a capacitor charging/discharging.
With centrifugal advance the best you can do is the maximum advance at each RPM that will cause peak pressure in the cylinder at 10-14 degrees ATDC which is about 5/9 of the combustion process at TDC. Too much advance will cause knock (pinking). Since you are only measuring RPM and not all the other factors that effect combustion you need to be conservative. Using mechanical advance you are limited to only advance with RPM, no plateaus or retard. Electronically this can easily be done. Adding an engine load sensor (vacuum or more crudely, throttle position) you can achive a better response and fuel economy. The electronic systems out there now are essentially only electronic versions of the mechanical setup. I think the Tri-Spark race version allows for some control over the slope of the advance curve.
The crudest ignition is what is used on a lawn mower, none. Next is the old two stroke dirt bikes that switched between full retard and full advance with only a few degrees difference, then the mechanical centrifugal advance, then adding vacuum advance, temperature sensors, altimeter sensors. A reasonably advanced ignition can measure the difference in RPM between each combustion cycle so you can check compression or carburettor syncronization.
Try reading C. Taylor's (MIT Press) books in I.C. engines.
Re: Best electronic ignition [Re: DMadigan] #232200
01/10/09 10:09 pm
01/10/09 10:09 pm
John Healy Online content
John Healy  Online Content
Ludwig: Have your corrected Dave's curves to reflect engine rpm, not distributer rpm as his diagrams indicate?
Ditto Dm's remarks (yes the analog has a counting circuit and trigger comes when a diode lets the negative pulse pass into the circuit as the small alternator produces an AC output), but he only barely touched on this subject.
The digital chip used by Boyer (and I am sure similar ones used by Tri-Spark and Pazon) are of a modern automotive design. They have the ability to incorporate many of the features of a modern automobile ignition system. It has been discussed to incorporate some of these features into one of these ignitions, but implementation would not be that easy, connections subject to harsh environment and handling, and the general British dealer and enthusiast barely copes with the analog version.
A few factors about engine ignition advance come to mind and I am sure Dm, Ludwig or Dave can add more.
Mechanical Stuff: Effectiveness of squish bands, combustion chamber design, cylinder bore diameter, number and location of spark plugs, number and location of valves, etc. can effect what timing we choose and at what time.
For example: Both of my 500 and 750 twins use radically different timing depending on whether I am using one or two spark plugs per cylinder. It varies from the high 30's for a single plug to the mid to low 20's for twin plugged. It is because combustion is much slower than speed of the piston as it goes up the bore that we need some spark advance. Adding the second plug speeds the rate of combustion.
With two plugs we ignite both sides of the combustion chamber and the rate of combustion increases. If you are using twin plugs I would advise you have your digital ignition re-programmed to compensate for this.
Physical Stuff: exhaust temperature, ambient air temperature, engine temperature, venturi vacuum, throttle butterfly acceleration, throttle butterfly position, manifold vacuum, air velocity, ambient air temperature, engine load, detonation, type of fuel recommended (type of fuel used), rpm, altitude, cold starting temperatures, compression ratios, dynamic cylinder pressure, cam timing, the strength/intensity of the spark itself, etc, etc. all can be modified or monitored and changes made to the timing by the computer chip.
In the old days (1950's) they used manifold vacuum, venturi vacuum and mechanical weights. With all of our advance in electronic ignitions we haven't reached that level of sophistication yet..
So with our sophisticated digital chip we are left with one input: RPM. This leaves us the ability to, after the motor starts, advance the timing for the first minute or so to help keep the motor from stalling when cold (but with out a motor heat sensor this feature is turned on when the motor is hot or cold) and then retarding it so the bike idles smoothly. From there it is just a matter of programming advance points to produce the "curve" we want.
But all this said, I still would use one of the electronic ignitions available today over the quality of the points that are available today. I thought they were junk 30 years ago, and used Lucas. Now, if you find Lucas points you will find that they started to use these people as their vendor some 15 years ago.
Ok... I have my flame suit on. I think I am going to get it from all sides... Just remember it is only my opinion...
if I have made any factual mistakes it was intentional, but please correct the old guy anyway! Just be kind.
Re: Best electronic ignition [Re: John Healy] #232209
01/10/09 11:15 pm
01/10/09 11:15 pm
All I can say that if those curves shown above are correct, then there is no real world difference in any of them.. Any difference is likely to be the maker's marketing hype...
Cheers..!
Ron
Re: Best electronic ignition [Re: John Healy] #232217
01/10/09 11:48 pm
01/10/09 11:48 pm
ca, us
ca, us
While I agree that there are wide variations in advance requirements depending upon construction, atmospherics and the like, I disagree that it we have not reached the level of sophistication of the 50's. My own ignition is PC programmable for RPM, vacuum, temperature or anything else I want to add in. If you can point and click a mouse button you can program my ignition to whatever you want, advance, retard or constant with RPM. Different software versions for RPM only or RPM and vacuum or adding a temperature sensor for cold fast idle are either available or can be programmed and can be downloaded by the user. No new box to buy. It can be changed over from fours to triples to twins to singles with software (assuming the box has sufficient coil drivers) and the correct pickup. It has a built in shift light (flash then steady at red line) with programmable RPM limits. One software version connects to the oil pressure switch and if pressure is lost it goes to full retard and flashes the shift light. Depending upon the number of sensors mapped, it can have 16 RPM maps or 8 RPM and 8 vacuum with 4 RPM limits that all can be selected on the fly. The default maps are set by a switch internally. Take off the control/display and your ham fisted friend is stuck with a mild advance and early RPM limit if you want. For racing you can test several maps on the track then set the best as the default.
There are many automotive sensors available, some reasonably cheap. I use the same vacuum sensor as the Megasquirt fuel injection, about $18. A throttle position sensor runs about $36 but one off a late GSXR is probably cheaper. A coolant sensor works for the oil. Nitrous? That is just a simple switch input. There are three kill inputs, connect to B+, connect to ground and disconnect from ground.
A low dropout regulator lets the timing work down to less than 6 volts input. The coil charge time is programmable to work with most any induction coils and if the battery voltage drops below 12 volts the charge time is doubled for better spark. If the engine stops for over 24 seconds the coil power is turned off to prevent battery drain and cooking coils. The pickup board has a timing light so timing can be accurately set statically. The only physical setting in the timing is the advance range which is set by the pickup cup. Full advance or retard can be short changed by the map of course. It just cannot fire outside the window.
Re: Best electronic ignition [Re: DMadigan] #238664
02/19/09 2:16 am
02/19/09 2:16 am
Shoshone Offline
Shoshone  Offline
A sort of on topic question..the magnets on my Boyer rotor are weak, and won't trigger the unit. The ignition passes all the recommended tests except magnet strength. New magnets are 3 1/2 pounds shipped to the USA. Not too expensive, but does anyone have an alternative?
Re: Best electronic ignition [Re: Shoshone] #238669
02/19/09 2:39 am
02/19/09 2:39 am
JubeePrince Online content
JubeePrince  Online Content
Huh?!?! Are you talking about the Lucas rotor for the alternator??? I don't know of any Boyer rotor that weigh 3.5 lbs.....and even if they did, there are plenty of places to buy them in the US.....
As for testing, there is an excellent series of step-by-step tests you can view here, courtesy of our own John Healy and RF Whatley.
HTH,
Re: Best electronic ignition [Re: JubeePrince] #238805
02/19/09 9:37 pm
02/19/09 9:37 pm
Connecticut
maylar Offline
maylar  Offline
Connecticut
Umm.. perhaps he means GBP not lbs.
Dave from CT
Re: Best electronic ignition [Re: maylar] #238823
02/19/09 10:36 pm
02/19/09 10:36 pm
Hamilton, Mass. USA
Dave Comeau Offline
Crew Chief
Dave Comeau  Offline
Crew Chief
Hamilton, Mass. USA
wink
GBP or try (for US keyboard) alt(hold) then 1 5 6 =
http://atlanticgreen.com/ignition.htm
dynodave
BSA 3 1961-1963
Ducati 3 1992-2002
Norton many 1951-1975
Re: Best electronic ignition [Re: maylar] #238845
02/20/09 12:38 am
02/20/09 12:38 am
Well, color me stup.....yankee!! laughing
Re: Best electronic ignition [Re: JubeePrince] #239078
02/21/09 3:17 am
02/21/09 3:17 am
orofino Idaho
Mike, in Idaho Offline
orofino Idaho
I'm using a mechanical advance on my next ignition, using Toyota, GM and Lucas components:
The reluctor and pickup coil are out of a Toyota 22R distributor,the ignition module is a Wells four pin unit from a Chevrolet HEI distributor. The double-ended ignition coil is from a Pontiac Sunbird.
The reluctor( with two of the teeth ground off) is a light press fit on the cut-down Lucas points cam, its position will be deteremined by the final position of the pickip coil. One(or maybe two) heavy duty advance springs should get the spark advance in the ballpark. I've built two of these ignitions so far for other machines and they have worked really well I'm eager to see how it will work in My TR6. This wasn't My idea originally, it was cooked up by a guy on the Yamaha 650 list, it's surprising what you can do sometimes with stuff that's just lying around
Mike
My company car is a Kenworth
Re: Best electronic ignition [Re: Mike, in Idaho] #258331
06/10/09 1:49 am
06/10/09 1:49 am
orofino Idaho
orofino Idaho
Well, here is the trigger assembly.Only took Me four months,at this rate I might get it finished by the time I retire.
Mike
Re: Best electronic ignition [Re: Mike, in Idaho] #258377
06/10/09 10:39 am
06/10/09 10:39 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
We have "management tools" to avoid such, primarily the experienced brain and secondarily the gearbox and throttle !!!
Or do you assume that worst case must apply and Boneheads abound ?
1969 TR6R
Re: Best electronic ignition [Re: Tiger] #258501
06/10/09 10:03 pm
06/10/09 10:03 pm
orofino Idaho
orofino Idaho
I have a new Boyer unit in the bottom drawer of my toolbox, I thought I would build a low-tech, low budget version of it, just for fun. At least I won't have to set points anymore,it makes sparks with the battery as low as nine volts and parts are available at the local car parts store. If I decide I need perfection later I'll go buy a new Honda.
Mike
Page 2 of 2 1 2
