ADC
ADC
CALIFORNIA
39 registered members (Allan Gill), 174 guests, and 370 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 87
Triless 66
754,293 mail-order LSR
Topics68,905
Posts671,177
Members10,485
A65 Cam Follower Circlips #257816
06/07/09 1:19 pm
06/07/09 1:19 pm
Rotherham, UK
Ian Clifton Offline OP
Rotherham, UK
Has anyone had experience of trying to fit those circlips? I bought what I thought was the correct tool, but even with that it seems an almost immposible feat!! Are the ciclips even necessary? I assume they are there only for removal and replacement of the barrel.. Your thoughts would be most appreciated..
Just a few Beezers.. ☺
Re: A65 Cam Follower Circlips [Re: Ian Clifton] #257818
06/07/09 1:53 pm
06/07/09 1:53 pm
As far as I understand, these circlips are there only to prevent the followers (as you assume) from falling out of the cylinder barrel when you handle that.
The engine can safely run without them.
Why did you remove your picture of this bike from your post of July 20 last year?
Re: A65 Cam Follower Circlips [Re: Ger B] #257830
06/07/09 3:00 pm
06/07/09 3:00 pm
Bedfordshire, England
Mrkerr Offline
Mrkerr  Offline
Hi
I have fitted those pain in the backside clips twice now, The best method I have found is to get a tube that u can drill/machine to just fit over the 'bullet shape head' of the follower, slide the clip down and use a screwdriver or similar to pop them into place. A bit fiddly but.....works.
Hope this helps.
Wayne
Re: A65 Cam Follower Circlips [Re: Ger B] #257831
06/07/09 3:09 pm
06/07/09 3:09 pm
Rotherham, UK
Rotherham, UK
Hi Ger, Thanks for that. Re: the pictures, I didn't remove them.. I posted them as you saw, then some time later they dissappeared!! Very Strange. I will try to re-post later.
Re: A65 Cam Follower Circlips [Re: Ian Clifton] #257832
06/07/09 3:11 pm
06/07/09 3:11 pm
Rotherham, UK
Rotherham, UK
Thanks Wayne. I've now managed it after some fiddling!!
Re: A65 Cam Follower Circlips [Re: Ian Clifton] #257864
06/07/09 8:10 pm
06/07/09 8:10 pm
Duesseldorf/Germany
Phil in Germany Offline
Duesseldorf/Germany
rothery;
I do run my engines without the circlips, definitely no need for them.
For top end assembly I put some white grease or vaseline, which gets solved in the engine oil more easily (no, Ger.... do not even think about making jokes about this! laugh ) on the tappets. That keeps them from falling out.
The only good thing about the circlips is when disassembling the top end. The tappets stay in place then, without you have to be careful to get each tappet back on its own cam.
FWIW
Best regards
Phil
Duesseldorf/Germany
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
Re: A65 Cam Follower Circlips [Re: Phil in Germany] #257911
06/08/09 7:06 am
06/08/09 7:06 am
Why are you looking at me??? laughing
Re: A65 Cam Follower Circlips [Re: Ger B] #257934
06/08/09 1:08 pm
06/08/09 1:08 pm
Because the vaseline he mentioned would prevent the "sitting" problem in your Shout box joke .... ??? laughing
Re: A65 Cam Follower Circlips [Re: Lannis] #257970
06/08/09 4:32 pm
06/08/09 4:32 pm
Rotherham, UK
Rotherham, UK
Many thanks again Guys for your input. On a separate note, I couldn't find my BSA workshop manual, so refered to the Haynes for torque settings on the oil pump drive worm gear. Haynes state 60 ft/lbs whereas BSA recommend 35. Quite a potential thread stripping difference!!!
Re: A65 Cam Follower Circlips [Re: Ian Clifton] #258009
06/08/09 9:14 pm
06/08/09 9:14 pm
Norway
Ola Offline
Ola  Offline
Norway
Circlip mounting:
Grease up the end of a suitable plastic tube, stick the clip to the end and force the tube down the stem until the circlip is home.
Best regards
(Doug Hele, 1919 - 2001)
Re: A65 Cam Follower Circlips [Re: Ola] #258013
06/08/09 9:34 pm
06/08/09 9:34 pm
John Healy Offline
John Healy  Offline
May I dare say: Buy the tool!
Re: A65 Cam Follower Circlips [Re: John Healy] #258024
06/08/09 10:00 pm
06/08/09 10:00 pm
Mark Parker Offline
Mark Parker  Offline
I just push a piece of plastic hose onto each to hold them in place while fitting or removing cyls.
