T100Mark
T100Mark
Southern California
50 registered members (Adam M.), 221 guests, and 373 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,659 mail-order LSR
Topics68,846
Posts670,617
Members10,478
Dye in engine oils #257317
06/04/09 12:51 pm
06/04/09 12:51 pm
Massachusetts, U.S.A.
btour Online content OP
btour  Online Content OP
Did you guys know there is a dye in most engine oils? I did not know that. They put it in there so if some one tries to claim engine damage from their oil they can put a light on it and see if it was their oil.
So if you take apart your engine, and it is red, or blue or vermillion in the top end, you can be it is oil.
It explains why when I drained my Castrol GTX it is reddish tinge. The heat activates the dye.
Re: Dye in engine oils [Re: btour] #257813
06/07/09 12:52 pm
06/07/09 12:52 pm
This is the first time I read about dye in engine oils. That does not mean it is not true.
I know dyes were sometimes used in compressor oils in the reefer industry. The maintenance engineer could add some, so when oil circulates through the complete system with the refrigerant (and it allways does), it will tell where there is a leak. It is not used very frequently though as there are better leak detection systems.
A britbike does not need a leak detection system. It creates it's own dye (black as my soles) and is in itself, by design, one complete leak detector.
Re: Dye in engine oils [Re: Ger B] #257844
06/07/09 4:39 pm
06/07/09 4:39 pm
Saskatoon
cgmze Offline
cgmze  Offline
Saskatoon
some aviation oils have a dye that shows in uv light. we use it to track down leaks. maybe there is a similar dye in motorcycle oils I must try it. I think I can find a bit of oil on my 71.
Gary
1971 T120R matching numbers
Re: Dye in engine oils [Re: cgmze] #257872
06/07/09 9:57 pm
06/07/09 9:57 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
I put a couple of drops of UV aircon dye in my gearox oil, you DO only need a couple of drops, leaks show up easily under a UV tube. I can't imagine a couple of mL in the engine oil will cause any harm, especially if you are going to change it after you have done the work to cure the leak
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
