Wilmslow
Wilmslow
South West USA
39 registered members (bill50cal), 215 guests, and 95 spiders.
FireGuyKC, spuggy, Vinny Cotroneo, KeithM, Mridul Handa
10285 Registered Users
Stuart 97
Lannis 60
633,639 mail-order LSR
Topics67,349
Posts653,866
Members10,285
Is there a way to test a Tympanium regulator? #25738
06/06/07 1:16 pm
06/06/07 1:16 pm
Texas
Chopped1 Offline OP
Chopped1  Offline OP
Texas
Working on the wiring harness and wanted to make sure the Tympanium is working correctly and wondered if there's a way to verify it's good?
Chopped1
Re: Is there a way to test a Tympanium regulator? #25739
06/06/07 9:36 pm
06/06/07 9:36 pm
CA
BSA Mark Offline
BSA Mark  Offline
CA
Hi There,
If you'd like to simulate and alternator all you need to do is find a 110VAC to 12VAC power supply (Or a 110VAC to 12VAC transformer).
Connect the yellow leads to the 12VAC and with your multimeter you should measure 13.8VDC on the black and red.
Mark
1971 BSA Thunderbolt
Re: Is there a way to test a Tympanium regulator? #25740
06/06/07 10:10 pm
06/06/07 10:10 pm
John Healy Offline
John Healy  Offline
"Connect the yellow leads to the 12VAC and with your multimeter you should measure 13.8VDC on the black and red."
Me thinks not!
Re: Is there a way to test a Tympanium regulator? #25741
06/06/07 10:18 pm
06/06/07 10:18 pm
Maryland
JD Online happy
Moto-Amish
JD  Online Happy
Moto-Amish
Maryland
So the regulator creates power? I thought that went against physics...
Josh
Re: Is there a way to test a Tympanium regulator? #25742
06/07/07 12:09 am
06/07/07 12:09 am
British Columbia
hh Offline
hh  Offline
British Columbia
Actually it's quite easy to produce 13.8 VDC from 12 VAC in several different ways, but the best way to test the Tympanium is installed on the bike. If the voltage rises above 14.4 V, it's very likely either improperly grounded or damaged. That value may be lower. I don't know what they're specified to provide.
Re: Is there a way to test a Tympanium regulator? #25743
06/10/07 9:59 pm
06/10/07 9:59 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
You actually need a 15-18 volt AC transformer, preferably rated at better than 5 amps, 10 amps would be good. Feed the yellow wires with the AC from the transformer and load the output of the tymp with a 55/60 watt headlight bulb BOTH FILMENTS CONNECTED!(total of 110+ watts), then measure the voltage while it's on load. This will simulate an approximate operating condition.
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: Is there a way to test a Tympanium regulator? #25744
06/16/07 4:49 am
06/16/07 4:49 am
Norcross, GA (outside of Atl)
Tri Joe Offline
Tri Joe  Offline
Andrew,
Do you have access to these transformers? (so I could get one) Thanks.
Re: Is there a way to test a Tympanium regulator? #25745
06/16/07 8:47 am
06/16/07 8:47 am
beltdriveman Offline
Have Tympanium gone out of business???
If not why not just pick up the phone and ask them if they would test it for you if you were to send to them along with a stanped addressed return jiffee bag? I suspect they would do so.
