Go2fer
Go2fer
39 registered members (Andrew Dunham), 191 guests, and 221 spiders.
10173 Registered Users
Lannis 93
reverb 82
Stuart 77
NickL 67
koan58 61
551,048 mail-order LSR
Topics66,569
Posts645,348
Members10,173
b25 (tr25w) crankshaft bearing questions #255927
05/28/09 2:23 am
05/28/09 2:23 am
Northridge CA
DavidB@northridge Offline OP
Northridge CA
Hello. Summer vacation is here and I finally tore down the 69 tr25w which after the last ride vibrated so badly I was in pain. When I pulled the piston there was considerable side play and I assumed the big end bearing was shot. And after tear down I found a small flake missing from it. The crank itself felt quite smooth but I assume that it will need to be reground when the undersized replacement goes in. But my question is, that when I split the case the crank came out stunk in the timing side and I needed to tap it out with a mallet. Both bearings are one the crank and the manual shows they should be in the case instead. Is this normal? also the Rupert book suggests using tire irons to pry them off but if I do this will muck em up so i need to replace them? any suggestions?
thanks
David
David B
01 T-Bird
69 tr25w
51 B31(in many boxes)
Re: b25 (tr25w) crankshaft bearing questions [Re: DavidB@northridge] #256062
05/28/09 8:38 pm
05/28/09 8:38 pm
kommando Offline
kommando  Offline
If the crank pin is to spec do not regrind but fit new shells to suit. I would go for Aluminium/Tin bearings as made for the Triumph 500 twin and drill a hole for the top shell. The B25 bearings seem to be whitemetal which is not up to the job.
If the main bearings are on the crank then pry them off using the proper extractor or use tyre irons and fit new ones. Relive the crank main bearing journals to give a sliding fit for the main bearings, using emery cloth this takes 1hr per journal. Then fit the main bearings to hot cases and the crank will fit easily and will come apart the same next time.
Re: b25 (tr25w) crankshaft bearing questions [Re: kommando] #257267
06/04/09 3:25 am
06/04/09 3:25 am
Northridge CA
Northridge CA
Crank pin looks and feels good but it mikes out 36.435mm where the manual says it should be 36.512-525 so I believe .10 under and a regrind will be necessary.
David B
01 T-Bird
69 tr25w
Re: b25 (tr25w) crankshaft bearing questions [Re: DavidB@northridge] #257401
06/04/09 7:25 pm
06/04/09 7:25 pm
kommando Offline
kommando  Offline
As its clean it should grind to -10 thou, make sure you get the ginder to give the right radius at the corners, too sharp and it will give a stress riser on the crank.
Re: b25 (tr25w) crankshaft bearing questions [Re: kommando] #257417
06/04/09 9:00 pm
06/04/09 9:00 pm
Northridge CA
Northridge CA
Will do, Thanks for the advice,
David
David B
01 T-Bird
69 tr25w
Page Time: 0.058s Queries: 15 (0.005s) Memory: 1.0115 MB (Peak: 1.1553 MB) Zlib disabled. Server Time: 2018-04-23 02:06:08 UTC
