Lars Melin
Lars Melin
Sweden
30 registered members (Adam M.), 173 guests, and 442 spiders.
Andy Mac, kwbikr, RandomTask, George Henstorf, IanBSABurns44
10378 Registered Users
Mori55 94
NickL 86
DavidP 82
Stuart 82
reverb 73
Triless 69
687,851 mail-order LSR
Topics67,995
Posts661,404
Members10,378
auto-advance unit #251441
05/02/09 8:35 pm
05/02/09 8:35 pm
just a guy from Jersey [Hopewe...
nert Offline OP
nert  Offline OP
can any one tell me what this Lucas auto-advance fits?
54427182, its CCW and it is 12'
Re: auto-advance unit [Re: nert] #251450
05/02/09 10:50 pm
05/02/09 10:50 pm
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
Rotation is easy to tell, hold the taper and twist the point cam. Whichever direction causes the bob-weights to move outward is the direction of rotation. Look in the back, thee usually is a degree marking. That number is not listed for the triple or the '71 A65.
Re: auto-advance unit [Re: nert] #251514
05/03/09 10:37 am
05/03/09 10:37 am
Rich B Offline
Rich B  Offline
Good question Nert, none of my Lucas stuff lists anything for that P/N as far as fit.
Re: auto-advance unit [Re: Rich B] #251530
05/03/09 12:11 pm
05/03/09 12:11 pm
BSA_WM20 Offline
BSA_WM20  Offline
Well 12 deg on the cam is 24 deg BTC and that is not ringing any bells for me.
The aa units were common to every British bike so it could be virtually from any thing post 1959 ( which is about when they started using that unit me thinks)
Re: auto-advance unit [Re: BSA_WM20] #251554
05/03/09 2:04 pm
05/03/09 2:04 pm
It's a late Norton 6ca AAU unit that will work with most nortons and BSA's. 12 degree is standard for most british singles and twins and both BSA's and Nortons have the points cam rotate CCW.
Re: auto-advance unit [Re: Alex] #251569
05/03/09 2:53 pm
05/03/09 2:53 pm
nert Offline OP
nert  Offline OP
Thanks ALL
Alex, i have noticed in other posts you have an amazing amount of information. thanks for your reply. I have searched the net, brit parts houses, etc and can not find reference to that number. I have a NOS one available to me to purchase. I was hoping it would fit my 6ca BSA lightning, and i guess it will.
thanks
Re: auto-advance unit [Re: nert] #251577
05/03/09 3:12 pm
05/03/09 3:12 pm
Nert,
MAP and BO price list show it as being a replacement for 54419653, really intended for unit singles. I don't know what the difference is between that and a twin AAU unit. They look identical to me, have the same amount of advance, so maybe the springs are different? bob weight mass? I dunno but it seems like it should work fine. Supplier parts catalogs and price lists and can be very useful in this respect.
Good luck.
Re: auto-advance unit [Re: Alex] #251593
05/03/09 5:01 pm
05/03/09 5:01 pm
nert Offline OP
nert  Offline OP
I wonder if the difference is in the cam profile? The points dwell? The weights differance or spring spec doesn't bother me. Full advance normally comes on at about 2000RPM. So i can "adjust that".
If the cam profile is different, I would hate to create the same problems that the 4ca cam profile produced.
Do you know what a good 6ca advance part number would be? I prefer a point system over the Boyer and electronic systems available. And of course NOS is better than used.
thanks
Re: auto-advance unit [Re: nert] #251664
05/04/09 1:28 am
05/04/09 1:28 am
E
EWebster Offline
EWebster  Offline
E
What is wrong with the advance unit you have already? Did it end up being an older style?
Re: auto-advance unit [Re: EWebster] #251706
05/04/09 7:02 am
05/04/09 7:02 am
BSA_WM20 Offline
BSA_WM20  Offline
Nert.
TTBOMN there were only 2 cam profiles.
The standard egg shape for battery ignitions
Base circle with a flat for ET & magneto flywheel ignitions.
All bob weights are the same size and weight.
There seems to be an infinite number of different size & strength of springs
Re: auto-advance unit [Re: BSA_WM20] #251785
05/04/09 2:07 pm
05/04/09 2:07 pm
nert Offline OP
nert  Offline OP
Thanks Trevor
that makes me feel better.
EWebster, my advance unit it showing a bit of wear, spindle to cam center, so it does make it a bit difficult to adjust points accurately and keep ignition timing consistent.
Re: auto-advance unit [Re: nert] #251903
05/05/09 4:07 am
05/05/09 4:07 am
E
EWebster Offline
EWebster  Offline
E
The number you want for an A65 with a 6ca is either 54419344 or 54426429 the one you asked about is not suitable for a twin. They are not difficult to find.
Re: auto-advance unit [Re: EWebster] #251944
05/05/09 1:19 pm
05/05/09 1:19 pm
What's different about them?
Re: auto-advance unit [Re: Alex] #252177
05/06/09 12:14 pm
05/06/09 12:14 pm
BSA_WM20 Offline
BSA_WM20  Offline
I have a stack of unit single aa units and a couple of now redundant A 65 ones and I can see no difference in the cam profiles between the B 50 , B 44 & the A 65 ones.
When pulled apart the only difference that I could see was the springs and the hole in the plate to control the advance.
I even have a couple of plates with 2 different holes, stamped with 2 different advance numbers
Re: auto-advance unit [Re: BSA_WM20] #252183
05/06/09 12:42 pm
05/06/09 12:42 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Nert,
I don't recall you mentioning what bike you are fitting. I was never opposed to points. In fact my singles have points and the twin electronic. I have interchanged AA's from different bikes and the seem to work just fine. Everything was either points or magneto when I grew up so fiddling with points was never an issue. I decided to go ahead and fit my 66 A65 with a Boyer as timing the earlier bikes with the 4ca pints was very ticklish. I can tell you that the Boyer also provided a more gentle advance that largely cured pinking. I have't had the points cover off in years on the a65 so there is something to be said for the Boyers. Your timing never changes whereas with points it does change as the rublock wears or the points deteriorate thru arcing. But is is a personal choice. The big advantage with points is that you can carry cheap spares in the event you do have a problem out on the road Bnd you can run a long way off a battery if you have charging system problems. I once made it home on battery voltage of about 6-7 volts when a wire from my alternator broke. When you drop below about 10 volts with a Boyer it quits sparking. This site has guys that are strictly electronic and others that prefer points. I guess I am somewhere in between. Also setting points within a few thousandths with trifocals down on your knees is another reason to support Boyer, but it's a personal choice.
Re: auto-advance unit [Re: Mr Mike] #252221
05/06/09 3:44 pm
05/06/09 3:44 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
""TTBOMN there were only 2 cam profiles.
BSA WM20 ""
That statement seems to be exactly backwards
egg shape is for magnetos or ET
circle with flat spot is for battery ignitions.
>>sb
Stop the insanity.
Re: auto-advance unit [Re: SBoyd] #252242
05/06/09 6:13 pm
05/06/09 6:13 pm
nert Offline OP
nert  Offline OP
MR Mike
I have a 66' lightning. I picked up a used 6ca aau and points plate of e-bay. As it is worn and i am in the middle of a rebuild, i wanted to find a new old stock unit to put in.
BSA_WM20
Its amazing how we all collect these little "bitsa" parts. Can't throw any thing out. It has to be better than some other one, and gee it has to have value. Ive waste a lot of time and money replacing a part to one a little better than what i have. Than another one, a little bit better comes along. Before ya know it, ya got a collection. So, now i am looking for NOS.
Re: auto-advance unit [Re: nert] #252312
05/07/09 1:06 am
05/07/09 1:06 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Nert,
A 6ca is a big improvement over what came in the bike. Do you still have the Monoblocs?
Re: auto-advance unit [Re: Mr Mike] #252322
05/07/09 2:26 am
05/07/09 2:26 am
nert Offline OP
nert  Offline OP
yes. the monoblocs are on there. I don't like to change things and upgrade too much. I like it authentic and original. IF i wanted the latest technology and updates, i would buy a new bike.
Re: auto-advance unit [Re: nert] #252383
05/07/09 2:01 pm
05/07/09 2:01 pm
Hey Nert, Monos are great carbs. Better built than concentrics and look the part to boot. Good on ya for keeping them.
