sawtooth
sawtooth
New York
189 registered members (79T140E), 2,123 guests, and 573 spiders.
koan58 90
NickL 86
505,561 mail-order LSR
Topics66,061
Posts639,394
Clutch slip, again or still... #251395
05/02/09 3:11 pm
05/02/09 3:11 pm
Denmark
Ducknaldo Offline OP
Denmark
Sorry for the double posting, but thought it needed a new thread.
I have now put around 1200 kmīs on the bike with atf fluid in
New clutch springs and very tight.
Plenty free movement on clutch handle before disengaging.
I can certainly hear it when i put it in 1īst, but no excessive grinding.
I put some marks on the twistgrip to see how much of maximum Iīm giving it.
To my surprise I found that I hardly ever use more than half throttle.
BUT(why is there always a but), after I found out that the bike has so much more to offer on the twistgrip I now give it a little more under acceleration, but it seems soon after(over half throttle) when accelerating hard I still have clutch slip.
The clutch plates are not glazed and the surface still seems soft.
I honestly dont think they have many kmīs on `em.
What are my options now?
Map, surflex, Hyde or should I look at something else or even stop using the bike the way it was intended?
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251399
05/02/09 3:26 pm
05/02/09 3:26 pm
dave jones Offline
dave jones  Offline
Make sure you still have 1/16" clearance at the pushrod, with the handlebar lever slackened right off. Also, the thing that made mine slip was too much oil in the chaincase. With the machine on its wheels and held upright use the level plug rather than measuring the oil out. It cured my slip.
Re: Clutch slip, again or still... [Re: dave jones] #251401
05/02/09 3:37 pm
05/02/09 3:37 pm
Denmark
Denmark
Ahh, silly me.
You may have nailed it there, with the oil level.
I wasnīt being very precise when putting atf in it as I knew I would spill something when adjusting the iginition.
Iīll check it right away and what a cheap solution that would be ;-)
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: dave jones] #251402
05/02/09 3:40 pm
05/02/09 3:40 pm
Massachusetts, U.S.A.
btour Online content
btour  Online Content
Hi Ducknold,
I know The springs come in different lengths, and strengths. I have heard the T140, clutch plate is heavier duty than T120, and that a little sanding on a flat surface gives it even more bite.
Re: Clutch slip, again or still... [Re: btour] #251406
05/02/09 4:04 pm
05/02/09 4:04 pm
Denmark
Denmark
Hey btour, duck.
Soon weīll have angry enthusiasts throwing stuff around in here ;-)
Iīve also heard the sanding thing and ridden a Bonnie that had it done.
1īst gear engagement sounds very grinding and Iīm not really sure it cured the problem.
But the T140 plates and longer springs may be worth checking if the suggestion by Dave doesnt help.
Cost is not an issue here as I will be taking it around europe this summer.
Iīve tried standing in southern France before with something trashed and I wont do it again if I cant help it :-)
Mr. Healy has previously mentioned surflex plates and that might be the way to go if the easy/cheap stuff fails.
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251413
05/02/09 4:43 pm
05/02/09 4:43 pm
Denmark
Denmark
Ok Dave.
I just checked the oil level by using the level plug and no oil came out, so that cant be the problem.
The pushrod has clearance, although I havenīt measured it precisely.
Now Iīm no expert on english measurements but according to google an inch is 254 mm and one sixteenth of that is almost 16 mm. If I gave it that much slack i dont think the clutch would work at all.
I have a couple of mmīs free movement in the lever before I can feel the pushrod getting into again.
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251425
05/02/09 7:04 pm
05/02/09 7:04 pm
Denmark
Denmark
I just ordered a set of Norman Hyde plates.
I noticed John recommending them in another thread
Anyone else has experience with them?
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251426
05/02/09 7:09 pm
05/02/09 7:09 pm
Originally Posted By: Ducknaldo
Ok Dave.
No it's not. Look again.
Re: Clutch slip, again or still... [Re: triton thrasher] #251427
05/02/09 7:12 pm
05/02/09 7:12 pm
Denmark
Denmark
Yeah, I figured it would be near 1,6 mm and I have that much free movement.
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251431
05/02/09 7:34 pm
05/02/09 7:34 pm
Bishop, Calif.
desco Online content
desco  Online Content
Bishop, Calif.
Where do you have that much free movement? There are five adjustments for the clutch. Pressure plate springs, pressure plate truing, handle bar free play, drive side push rod clearance and
timing side clutch operating mechanism. The handle bar is done last.
Re: Clutch slip, again or still... [Re: desco] #251497
05/03/09 7:29 am
05/03/09 7:29 am
Denmark
Denmark
Desco
At the pushrod.
I havenīt measured it precisely, but will do that today if guys think it could have anything to do with the slipping.
From a "naked eye" point of view Iīd say it has a little bit more clearance.
The bike has always had this problem(as long as I had it), also after having itīs clutch rebuild from a trusty "Meriden" shop.
I have a feeling the clearance hasnīt got anything to do with it.
The drum looks like new, no dents or anything and the clutch seems to operate perfectly except this slipping when putting it under real heavy load.
I cant wait to get the Hyde surflex in, but I am well aware that the plates cant deliver if something else is wrong here.
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251502
05/03/09 8:58 am
05/03/09 8:58 am
Lower Rhine Area, Germany
Towner Offline
Towner  Offline
Hi Ducknaldo,
my clutch slipped too, when I got the bike, but the plates were old and glazed. I changed to the 7-plates conversion and it works fine since 4000 km now.
Ralf
Triumph Bonneville 650 T120RV 1972
Norton Commando 850 MKII 1973
Re: Clutch slip, again or still... [Re: Towner] #251511
05/03/09 10:13 am
05/03/09 10:13 am
Denmark
Denmark
Towner
That sure brings hope.
Which brand did you put in?
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251519
05/03/09 10:48 am
05/03/09 10:48 am
Johns Creek,Ga
GaCracker Offline
GaCracker  Offline
Johns Creek,Ga
Duck, I just installed this MAP pack in my '72 Tr6rv, and it made a world of difference. The old plates were not completely worn out, but depending on how much I adjusted, I either had slip, drag, hard to free, and finding neutral difficult. I run Valvoline 20/50 motorcycle oil for bikes with wet clutches.. This new clutch has cured all of that. Greg http://www.mapcycle.com/items.asp?Cc=Clutchkits&Bc= I should add that this kit is for post 1969 Triumph/BSA, so may not apply to yours, sorry.
72 TR6RV
2004 Thruxton
Re: Clutch slip, again or still... [Re: GaCracker] #251526
05/03/09 11:24 am
05/03/09 11:24 am
Denmark
Denmark
Iīve been looking at those map plates too.
I like the fact that the friction material covers the entire plate, but then again, these plates are patterned, so it might not make a big difference.
I only decided for the Norman Hyde plates because I read Mr. Healy stating that he really liked them, but they were too expensive.
Since I live in europe I figured that the price for MAP and shipping would be almost the same and Norman Hyde will propably be delivered faster than MAP from over there.
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251576
05/03/09 3:11 pm
05/03/09 3:11 pm
Towner Offline
Towner  Offline
sorry, I don't know the brand - I got them from my mechanic. But they are offered at several shops:
http://www.triumph-spares.co.uk/
T120/T140 7-plate clutch conversion ..... Ģ59.13
This conversion consists of 7 new plates with smaller friction area plus one new plain plate. Compared with standard it reduces problems of sticking, slipping, swelling, dragging and heavy operation provided the other components are in good condition. Use with existing 6 plain plates.
http://www.grintriumph.com/page2.htm
Ralf
Re: Clutch slip, again or still... [Re: Towner] #251609
05/03/09 7:31 pm
05/03/09 7:31 pm
dave jones Offline
dave jones  Offline
Ducknaldo- Sorry those two things didn't do the trick but usually with new plates the clearance disappears as the plates bed in and causes slip. A whole turn on the adjuster is right I have found.
Don't stand at lights etc with the bike in gear and the clutch disengaged as this will ruin the clutch. Anything more than a few seconds and you should go into neutral.
My clutch seems ok at the moment (in a 67 650) although it might be because I am very light at a bit under 8 stone! It has the 60s style plates with the small rectangular fibre pads that look like they have been stuck on a bit all over the place unlike the modern types which have a neat set of close fitting pads. I have some 15W50 or 20W50 oil in the chaincase at the moment. I did spend some time getting the pressure plate dead level and making sure that the plates were free in the slots but otherwise I just followed my manual.
Re: Clutch slip, again or still... [Re: dave jones] #251641
05/03/09 10:57 pm
05/03/09 10:57 pm
Denmark
Denmark
Thanks Dave
I did the adjustments again today, by the book and measuring every step instead of eyeballing it.
Now the weather is bad for a few days so I wont be able to test it before the weekend.
I hope it helps, but otherwise the new plates will probably arrive soon and help me out.
Getting the pressure plate level really is a struggle because of the movement in the drum, but when the new plates go in Iīll have a second chance if it wasnīt dead level the last time I did it. I should replace the springs also, just as a precaution then.
It seems I should use T140 springs instead of T120, although I havent looked into spring length and tension, thatīs what my searches on the forum led me to believe.
Iīm also quite skinny, about 10,7 stone, so at least I wont have to worry about exercise to fix the problem ;-)
Run `em...
1969 T120
Re: Clutch slip, again or still... [Re: Ducknaldo] #251654
05/04/09 12:21 am
05/04/09 12:21 am
Bishop, Calif.
Bishop, Calif.
How heavy is a "stone"????
Re: Clutch slip, again or still... [Re: desco] #251659
05/04/09 12:53 am
05/04/09 12:53 am
14 lbs.
Re: Clutch slip, again or still... [Re: shel] #251695
05/04/09 5:33 am
05/04/09 5:33 am
Denmark
Denmark
Some stones are heavier than others...
Except in England of course laugh
Run `em...
1969 T120
Page Time: 0.138s Queries: 15 (0.042s) Memory: 1.1584 MB (Peak: 1.4564 MB) Zlib disabled. Server Time: 2018-02-25 06:04:58 UTC
