T100Mark
T100Mark
Southern California
41 registered members (21inGoldie), 211 guests, and 360 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,628 mail-order LSR
Topics68,845
Posts670,611
Members10,478
Main bearing question #249342
04/20/09 3:54 pm
04/20/09 3:54 pm
Connecticut
maylar Offline OP
maylar  Offline OP
Connecticut
When I removed the crankshaft assembly from my '74 850 the inner races of the main bearings stayed with the crank. Normally I'd say they were broken.. but according to the FAG data sheet the bearing is listed as "separable". Is this normal, and can I reassemble the engine with the old bearings, or do they need to be replaced?
(Rollers and race look perfect BTW).
Dave from CT
Re: Main bearing question [Re: maylar] #249409
04/20/09 9:12 pm
04/20/09 9:12 pm
Ontario
Thomas Offline
Thomas  Offline
Ontario
That is what should happen when you take out superblends the inner race stays with the crank cheek throws. The rollers are slightly barrel shaped to allow for crank flex.
http://www.oldbritts.com/11_067569.html
That is a picture of the outer and inner race and shims to set the end float. This site is a good read for doing tricks to your 74 850.
72CCRider
72CCRider
Re: Main bearing question [Re: maylar] #249411
04/20/09 9:24 pm
04/20/09 9:24 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Yes, the main bearings would normally be "seperable".
However not in the way you describe, as the correct 850 FAG NJ306E cage and rollers should be captive to the outer bearing race (NJ type bearing) with the inner race as the seperable part.
The Norton factory used both NF and NJ bearing types before they introduced the heavy duty "Superblend" RHP 6 MRJA30 main bearings on the 750s, and the FAG NJ306E on all 850 models.
The factory issued a service bulletin recommending that only the NJ(306) double lipped outer and single lipped inner type bearings should continue to be supplied and fitted
All 850 models should have been supplied with the FAG NJ306E bearings, and that bearing is still the best one to use for all 850s and earlier 750s far as I know.
Moderated by  Dave Comeau
