norbsa48503
norbsa48503
Flint,Mich
205 registered members (1xfatboy), 1,768 guests, and 573 spiders.
Lannis 144
kommando 105
Stuart 64
477,131 mail-order LSR
Topics65,722
Posts635,286
A65 camshafts #248632
04/16/09 9:19 am
04/16/09 9:19 am
Picton, NSW, Australia
Billiam Offline OP
Billiam  Offline OP
Howdy,
I'm elbows deep rebuilding a 1971 Thunderbolt spending waaaaay too much money, and I just received the new camshaft I ordered. I really should know my stuff by now, but I'm not familiar with the A65 camshafts.
I ordered a spitfire grind cam (part number 68-0473) to replace what I assumed was a stock camshaft. The part I took out has 68-473 stamped on it. Problem is, I can't see or measure any difference in the profiles of the two. The new camshaft has no part number stamped on it.
Anybody out there know whether the spitfire and thunderbolt shared the same cam profile? Either I've ordered a stock camshaft or the bike already had the spitfire profile cam in it... my mistake or the bike shops??
W.
'71 BSA A65T
'71 Honda 500/4
Various unmentionables
Re: A65 camshafts [Re: Billiam] #248634
04/16/09 9:36 am
04/16/09 9:36 am
FWIW.
In my 1971 part number book the part number of the T-bolt camshaft is 68-0473.
I do not know if the Spitfire has a different number.
2c
Re: A65 camshafts [Re: Ger B] #248638
04/16/09 10:41 am
04/16/09 10:41 am
Dordogne, SW France
johnnyrvf Offline
johnnyrvf  Offline
Dordogne, SW France
According to what I have read the unit twin series only used two camshaft profiles and by the time the OIF's arrived BSA were trying to compete performance wise with the spangly new generation Japanese bikes so any thing to boost performance was utilised, I even read somewhere many moons ago that the last year (72) Lightnings had Spitfire pistons fitted but I can't comment on the accuracy of that statement, as to the cam being a Spitfire profile, that would'nt be at all unusual for the year of your bike. Johnny.
What d'ya mean it won't rev to 10?
1965 BSA A65D Lightning Rocket
1976 K*w*s*ki Z900.
1978 Triumph Bonn3ville (930 T160 Powered T140)
1988 H*nd* RC30
1990 Moto Guzzi California 3
1993 Y*m*h* TDM 850
Re: A65 camshafts [Re: johnnyrvf] #248646
04/16/09 12:03 pm
04/16/09 12:03 pm
Rich B Online happy
Rich B  Online Happy
There were only ever 2 camshafts for A65's. There is no "Spitfire" cam or "Spitfire" pistons.
The 68-0473 cam was introduced around 1964 for the Rocket, Spitfire Hornet, and Lightning Rocket models. Post 65, it was utilized in all of the A65's. I doubt it was for unltimate performance as much as for parts commonality, even though the A50's retained the original cam.
All the late bikes used the same 9-1 compression ratio, even the 68 Spitfire's were fitted with the that piston. BSA seemed to shy away from high compression pistons on the A65's after 67.
Re: A65 camshafts [Re: Rich B] #248658
04/16/09 1:31 pm
04/16/09 1:31 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Rich,
So you are saying a Lightning after 67 was pretty much a Spitfire in disguise with some different carbs. Did I get that right?
Re: A65 camshafts [Re: Mr Mike] #248673
04/16/09 2:26 pm
04/16/09 2:26 pm
AFAIK, the term "Spitfire Cam" is only correct when used in connection with the A10 Spitfire Scrambler. The term was used in advertisement for Super Rockets using the -357 cam, now known as the "Spitfire Cam".
As rich sez, on unit twins, the "Full Race" cam, as it was called by BSA in its ads was used first on the '64 lightning rocket and by '66 went into all A65's until the end of production. And yes, A65 Spitfires had the same cams, heads and pistons (Excepting '67) as lightnings. The only significant difference in the engines was carburetion.
Re: A65 camshafts [Re: Alex] #248684
04/16/09 3:28 pm
04/16/09 3:28 pm
Same deal with the Hornet, which evolved into the Firebird in 1968. Only engine difference between the Hornet/Firebird and the Lightning was the jetting in the carbs, which was opened up to account for the more open exhausts on the Hornet/Firebird.
Makes it easy to have a practical road bike no matter what bits you start with.
Re: A65 camshafts [Re: Mr Mike] #248832
04/17/09 12:30 pm
04/17/09 12:30 pm
Rich B Online happy
Rich B  Online Happy
More like a 68 Spitfire MK IV was a tarted up Lightning. Tank, rims, decals & 32 mm concentrics were about the only major changes from a Lightning to Spitfire.
Reality is, after the closed loop frame bikes ended in 65, the A65's were all based on pretty much a Lightning spec bike that had some cosmetic or carb changes. The bikes that were most different from that common spec were the 66 & 67 Spitfires & Hornets.
Re: A65 camshafts [Re: Billiam] #248853
04/17/09 2:11 pm
04/17/09 2:11 pm
Billiam Offline OP
Billiam  Offline OP
Good on ya guys, hard to find a straight answer from a bike shop or research alone.. suspected a commonality, but had my doubts with the notorious stubbornness underlying so many aspects of brit bikes.
B.
W.
'71 BSA A65T
'71 Honda 500/4
Re: A65 camshafts [Re: Billiam] #248936
04/18/09 2:51 am
04/18/09 2:51 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
...All the late bikes used the same 9-1 compression ratio, even the 68 Spitfire's were fitted with the that piston. BSA seemed to shy away from high compression pistons on the A65's after 67...
...And yes, A65 Spitfires had the same cams, heads and pistons (Excepting '67) as lightnings. The only significant difference in the engines was carburetion...
...Same deal with the Hornet, which evolved into the Firebird in 1968. Only engine difference between the Hornet/Firebird and the Lightning was the jetting in the carbs,...
...The bikes that were most different from that common spec were the 66 & 67 Spitfires & Hornets...
Aw, but there are differences. There were two different frames in '66 and '67. In '68 the frame was changed. And, since you all are mostly talking about performance, the '68 Firebird Scrambler has the Hornet/'66,'67 Spitfire high compression pistons. Other differences were front brakes and rim, front fender, as well as mufflers and others.
Since I'm a lover of Spitfires I certainly wouldn't say "...More like a 68 Spitfire MK IV was a tarted up Lightning...
Re: A65 camshafts [Re: Gary E] #248950
04/18/09 6:47 am
04/18/09 6:47 am
San Francisco
Redman Offline
Redman  Offline
San Francisco
Pistons...brakes...fender, mufflers......like he said..tarted up
Life is short but very wide.
Re: A65 camshafts [Re: Redman] #248951
04/18/09 6:50 am
04/18/09 6:50 am
San Francisco
Redman Offline
Redman  Offline
San Francisco
Sorry...just couldn't resist Gary. All due respect to ya.
Re: A65 camshafts [Re: Gary E] #248965
04/18/09 9:53 am
04/18/09 9:53 am
Rich B Online happy
Rich B  Online Happy
Gary,
I know there are a lot of details bits that are different, especially in 66 & 67, but I was trying to make the point that BSA was working at reducing the parts count. And refuting the internet myth that the Spitfire's had lots of special engine bits, which they didn't, particularl;y cams. That story keeps coming back like a bad penny.
Besides, if you want to really go nuts figuring out BSA parts, get serious about the 62 - 65 unit twins. They can make you crazy with all the differences and detail changes seemingly from month to month. But then you know that from practical experience grin
Re: A65 camshafts [Re: Rich B] #248977
04/18/09 12:33 pm
04/18/09 12:33 pm
Mark Parker Online content
Mark Parker  Online Content
I must say for a long time owning a Tunderbolt, or at least the motor in a plunger A10, then a lightning, I always wished I could get the hot Spitfire cam to put in, but as Rich points out they already had it, I think magazine articles might have been responsible for making it seem like the Spitfire had a bigger cam than everything else, (magazines seemed always facinated by cams, if something picked up 2HP from a cam and 10hp from pipes, they'd rave about the cam?)
It is a very good cam, so good, boyers used it in their Triumph twin race bikes, rather than anything else. We use that profile in a modified 750 A65 and it pulls hard to at least 9,000RPM. So if you want to make one faster changing the cam isn't the place to start.
Re: A65 camshafts [Re: Mark Parker] #249081
04/19/09 3:02 am
04/19/09 3:02 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Redman,
I'd say the Lightning is a splashed Spitfire with a fat tank and extra chrome.
Rich, I understand the intent of the information, but I wanted to clear up some of the incorrect portions. After all, misinformation is what keeps the cam rumors going for years. Accuracy here is what keeps this forum credible.
Re: A65 camshafts [Re: Billiam] #249092
04/19/09 5:34 am
04/19/09 5:34 am
Billiam Offline OP
Billiam  Offline OP
I think the lifespan of the cam myth is due more to the resurfacing of Triumph and Norton cams for various purposes, not least of all racing. Usually termed 'spitfire grind' it comes as no surprise the assumption that L and T BSA twins didn't share it
W.
'71 BSA A65T
'71 Honda 500/4
Re: A65 camshafts [Re: Billiam] #249095
04/19/09 6:59 am
04/19/09 6:59 am
Billiam, I get your point, no one is going to say they are useing the std BSA Tunderbolt profile in their super hot Triumph racer are they.
Re: A65 camshafts [Re: Mark Parker] #249103
04/19/09 8:43 am
04/19/09 8:43 am
Billiam Offline OP
Billiam  Offline OP
Indeed, I've been thrown off by deceptive marketing once again! I reckon a 390 profile would do more harm than good. Don't suppose anyone is using those specs on road?
Just as an aside, are these forums UK or US based? In Aus myself
W.
'71 BSA A65T
'71 Honda 500/4
Re: A65 camshafts [Re: Billiam] #249115
04/19/09 11:14 am
04/19/09 11:14 am
Billiam, just read your first post! Replacing a spitfire cam with a spitfire cam! Oh well you have a spare I guess, better than just one good cam and one mild one,,,sort of.
This is a world wide forum, started by Morgan in Sweden, I'm also in NSW. Some info:
BritBike.com was established in 1996. BritBike.com is created by British Motorcycle enthusiasts for British Motorcycle enthusiasts. You the visitor and member are most important and your knowledge is highly appreciated by other visitors aspecially on our popular BritBike Forum.
email: morgan@britbike.com
web: http://www.britbike.com
Re: A65 camshafts [Re: Mark Parker] #249119
04/19/09 12:35 pm
04/19/09 12:35 pm
Billiam Offline OP
Billiam  Offline OP
Cheers Mark, and not too far away I see.
Seems I do have a spare, at least another excuse to buy another bike to rebuild..
From what I gather the dwell on the later cams is around 281/277 in & out, big change from the pre '65 twins?
W.
'71 BSA A65T
'71 Honda 500/4
