Steve m
Steve m
Billings,Mt
196 registered members (1xfatboy), 1,886 guests, and 557 spiders.
10070 Registered Users
koan58 86
Lannis 82
NickL 75
Stuart 67
501,277 mail-order LSR
Topics65,995
Posts638,657
Members10,070
powder coat cylinder barrels? #24853
05/15/07 10:29 pm
05/15/07 10:29 pm
duluth, mn
grif0092 Offline OP
grif0092  Offline OP
duluth, mn
hey folks,
i have a bsa a10 and was wondering about powdercoating the cylinder barrel, yea or nay?
let me know! thanks!
Re: powder coat cylinder barrels? #24854
05/15/07 11:08 pm
05/15/07 11:08 pm
Massachusetts, U.S.A.
btour Offline
btour  Offline
Why not, Panic? Curious.
Re: powder coat cylinder barrels? #24855
05/15/07 11:41 pm
05/15/07 11:41 pm
Altoona, Florida
Mike Carter R.I.P. Offline
Altoona, Florida
There has been plenty of discussions on this and many other boards regarding lack of heat transfer because of powder coating...They came from the factory with stove enamel on them not much different from powder of today I have several bikes powder coated with no ill effects...Some people say even polishing covers causes the engines to run hot but....Whatever you like should work I have some with engine paint looks just as good.. :rolleyes:
Later
Mike Carter
Re: powder coat cylinder barrels? #24856
05/16/07 1:03 am
05/16/07 1:03 am
Asheville, North Carolina
ca7a Offline
ca7a  Offline
Strictly for the heat ransfer mechanism, no coating is best. And given that the A7/A10 barrel is cast iron and the finning is somewhat minimal, rust and thick coatings ought to be avoided.
For moderate roadwork, however, Mike's comment is fine.
Re: powder coat cylinder barrels? #24857
05/16/07 2:46 am
05/16/07 2:46 am
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
Even though I am a fan of powder coatings , I am in the "NO" camp on this one myself . The way I look at it , ading any coating is like throwing a blanket around the part , keeping heat in . This is good in an exhaust system , but bad on a cylinder barrel where you wanna remove heat . probably wont make a difference on an occasionally ridden bike ??
Just my .02-BONZO
Re: powder coat cylinder barrels? #24858
05/16/07 2:58 am
05/16/07 2:58 am
Westminster, MD, USA
J. Charles Smith Offline
From what I understand, not all coatings are insulators. For example, Kal-Gard is supposed to transmit heat better than aluminum - and much better than cast iron. Plus, being darker, it also radiates heat more efficiently. Brit-Tech, for one, also markets coatings designed to improve heat transfer.
Re: powder coat cylinder barrels? #24859
05/16/07 3:17 pm
05/16/07 3:17 pm
Santa Barbara, California
KC in S.B. Online content
KC in S.B.  Online Content
So has someone actually got a bike with powder coated cylinder?? Not sure if Mike Carter meant the cylinder was coated.. smile . I have a basket A65L, with Maroon powder coated EVERYthing! :rolleyes: , which at the time seemed like it could be interesting in a "retro" kind of way. Anyhow, I was also worried about the cylinder heat. cool KC
Re: powder coat cylinder barrels? #24860
05/16/07 3:56 pm
05/16/07 3:56 pm
I did a radiative heat transfer analysis about a year ago with a .010" powdercoat thickness on a simple cylinder and found it raised the temperature by less than 1 degree F. Admittedly a simplification, but probably sufficient for an order of magnitude asessment. It satisfied me to the point where I have powdercoated the barrel on my SS90.
Re: powder coat cylinder barrels? #24861
05/16/07 9:32 pm
05/16/07 9:32 pm
sunshine coast, queensland, au...
bonnie john Offline
bonnie john  Offline
" radiant heat behaves in a very similar manner to light;it travels in straight lines, and is reflected by a polished surface and absorbed by a dull black one. the latter process is reversable, and therefore a polished surface emits less heat by radiation than a black on. the rate of emission from a polished surface is approximately one-tenth that from the same surface covered with a thin film of lamp-black, and the emissivity of a cast-aluminium surface is increased about 10 per cent by a THIN coating of black paint"
motorcycling engineering (1976) by phil irving, page 183, head design and materials
SPEED KILLS
do not exceed 250mg ...
Page Time: 1.516s Queries: 14 (0.134s) Memory: 1.0505 MB (Peak: 1.2280 MB) Zlib disabled. Server Time: 2018-02-18 06:44:47 UTC
