Thunderbutt
Thunderbutt
Fl., U.S.A.
52 registered members (Adam M.), 330 guests, and 456 spiders.
Metalguru, hanscarlsson, BSADon, VH5150, okieboss02
10219 Registered Users
Lannis 113
Stuart 108
reverb 62
NickL 61
580,735 mail-order LSR
Topics66,845
Posts648,335
Members10,219
Best Crank Case Sealant available in the UK? #239883
02/25/09 10:07 pm
02/25/09 10:07 pm
Midlands, UK
Quantumrevs Offline OP
Midlands, UK
Hi All
I'm sure that this has been answered before, but what is the best sealant to use when I put the two halves of the power house back together? I bought a tube of 'Wellseal', but was told to chuck it in the bin by a man in the know. Someone else has suggested 'Honda Bond' - though when I googled that it was being used to stick hand grips on!
Any suggestions? I'm in the UK so that that might impact the availability of things.
Thanks in advance
Jon
Re: Best Crank Case Sealant available in the UK? [Re: Quantumrevs] #239886
02/25/09 10:24 pm
02/25/09 10:24 pm
chatham kent UK
john toghill Offline
chatham kent UK
Hi Jon,
I got some threebond 1194 on eBay. I'ts a grey (to match the cases) rubber like sealant that won't break up and block oil ways like silicone can. It's the new version of yamabond and hondabond.
http://cgi.eBay.co.uk/Threebond-1194-1104-200g-tube-liquid-gasket-yamabond_W0QQitemZ370148148648QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item370148148648&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
the trouble with the world today is apathy; but I don't care.
British Motorcycles, built to last, till worn out.
Re: Best Crank Case Sealant available in the UK? [Re: john toghill] #239887
02/25/09 10:30 pm
02/25/09 10:30 pm
Tridentman Online content
Tridentman  Online Content
Wellseal---used by the factory and countless others.
Old product but does the job.
Dont know what your "man in the know" knows but Wellseal has worked for me for over 45 years!
Re: Best Crank Case Sealant available in the UK? [Re: Tridentman] #239891
02/25/09 10:47 pm
02/25/09 10:47 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
Yamabond 4 or Threebond 1194
USA
GB
I use the Yamabond but believe that the Threebond is identical.
Edit
I see that above posters agree. These were posted while I was researching the websites for you.
>>sb
Stop the insanity.
Re: Best Crank Case Sealant available in the UK? [Re: SBoyd] #239895
02/25/09 11:12 pm
02/25/09 11:12 pm
Marblehead,Ma USA
W
Woody1911a1 Offline
Woody1911a1  Offline
W
Marblehead,Ma USA
bought some hondabond 4 recently and the part #on the back says 08717-1194 , the 1194 being the clue .
Re: Best Crank Case Sealant available in the UK? [Re: Woody1911a1] #239966
02/26/09 1:20 pm
02/26/09 1:20 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Loctite 518 - Google it bigt
Blapper redwine
Re: Best Crank Case Sealant available in the UK? [Re: Blapper] #239973
02/26/09 2:59 pm
02/26/09 2:59 pm
England
Tom_dup1 Offline
Tom_dup1  Offline
England
Wellseal works for me.
Re: Best Crank Case Sealant available in the UK? [Re: Tom_dup1] #239975
02/26/09 3:02 pm
02/26/09 3:02 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Opinion threads - don't ya love 'em!
redwine
Re: Best Crank Case Sealant available in the UK? [Re: Quantumrevs] #239989
02/26/09 3:58 pm
02/26/09 3:58 pm
Rich B Offline
Rich B  Offline
From actual experience.....
The 3 Bond products are quite good. HondaBond, YamaBond, etc. work nice. Works very well on the case joint.
LocTite 515 & 518 are excellent products. Little more expensive than the 3 Bond products, but they are high end sealant. IME, if either of these LocTite products leak, the part you are sealing is broken or was never meant to hold oil eek.
Re: Best Crank Case Sealant available in the UK? [Re: Rich B] #239991
02/26/09 4:45 pm
02/26/09 4:45 pm
Skudeneshavn Norway
Stein Roger Online content
Stein Roger  Online Content
Skudeneshavn Norway
Wellseal. If it leaks you've done something wrong.
Re: Best Crank Case Sealant available in the UK? [Re: Stein Roger] #240063
02/26/09 10:38 pm
02/26/09 10:38 pm
Midlands, UK
Midlands, UK
Thanks for the feed back everyone. Looks like opinions differ! Well, I already have the Wellseal - so I guess Ill give that a go fisrt. If i'm disapointed with the outcome I'll move onto the others. A few weeks away yet, but I'll let you know how I get on.
Thanks again
Jon
Re: Best Crank Case Sealant available in the UK? [Re: Quantumrevs] #240096
02/27/09 2:32 am
02/27/09 2:32 am
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
This is a good opinion thread, as opposed to those "bad" opinion threads.
There are only three products mentioned: Yamabond (& the other "bonds"), Wellseal, and Loctite 518.
No one is saying anything against any of them, so obviously all will work well for the crank case joint.
The reason this thread is important is that NO ONE wants to re-split their cases for a leak.
I have only used Yamabond since discovering it twenty years ago.
Everyone knows the Japanese use the best sealants (even if they were formulated in England) as their engines don't weep.
Legend has it that Harley went to Japanese engineers to solve their oil leaks, and Harleys haven't leaked since.
It seems that if Loctite 518 were better than Yamabond, the Japanese would be using it and it would be stocked by their dealers for their shops to use.
I am open minded and Rich's comments along with internet research and "cutting edge Blapper", have caused me to try Loctite 518 for my next engine.
My main stipulation is that the product must not squeeze out and get loose in the engine.
I know Yambond does not get loose, presumably the others don't. right?
Stop the insanity.
Re: Best Crank Case Sealant available in the UK? [Re: SBoyd] #240133
02/27/09 8:20 am
02/27/09 8:20 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Hi Steve, a couple of comments:
1/ I think Japanese engines are less likely to leak by design, not just jointing compound.
2/ Application of compound and condition/preparation of cases is mega important to some compounds, less to others. Loctite's spec is impressive.
3/ Amount applied is difficult to get perfect with any face, it is what happens to the compound that squeezes out that is important. At least with anaerobics you have a chance that they will get to the filter if they break free.
When I took my motor apart I found the gallery and lube hole of the exhaust tappet block filled with rock hard wellseal.
I expect the Yamabond is a good product but have never used it.
As they say 'your results may vary' - I look forward to your experiences and hope to be able to say that my 518'ed faces are oil tight (c/c & g/b).
Good luck guys - post results!
Blapper redwine
Re: Best Crank Case Sealant available in the UK? [Re: Blapper] #240149
02/27/09 12:54 pm
02/27/09 12:54 pm
Agree with Blap.
I think probably all of the products mentioned might work OK.
Of paramount importance is:
a) Preparation---clinically clean and oil/grease free.
b) Amount applied. Wellseal is pretty liquid and in my experience (as per the Triumph race shop) best applied using a small artists paint brush to give a thin uniform coating.
Just my 2pence/cents worth.
Re: Best Crank Case Sealant available in the UK? [Re: Blapper] #240150
02/27/09 12:54 pm
02/27/09 12:54 pm
Agree with Blap.
Re: Best Crank Case Sealant available in the UK? [Re: Blapper] #240151
02/27/09 12:55 pm
02/27/09 12:55 pm
Agree with Blap.
Re: Best Crank Case Sealant available in the UK? [Re: Blapper] #240152
02/27/09 12:55 pm
02/27/09 12:55 pm
Agree with Blap.
Re: Best Crank Case Sealant available in the UK? [Re: Tridentman] #240153
02/27/09 1:05 pm
02/27/09 1:05 pm
dave jones Offline
dave jones  Offline
I used golden hermetite at the crankcase joint and it doesn't leak. Blue Hylomar is good stuff too but all the products you can get for this job are very similar.
Re: Best Crank Case Sealant available in the UK? [Re: Tridentman] #240156
02/27/09 1:16 pm
02/27/09 1:16 pm
Reading UK
twinspin Offline
twinspin  Offline
Reading UK
Originally Posted By: Tridentman
Agree with Blap.
Thats what I call value for money all for 2 cents
1971 T100R
1970 T120
Re: Best Crank Case Sealant available in the UK? [Re: twinspin] #240163
02/27/09 2:09 pm
02/27/09 2:09 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
Tridentman...........OK smile OK smirk OK smile OK grin
Blapper
""At least with anaerobics you have a chance that they will get to the filter if they break free.""
please explain.
Stop the insanity.
Re: Best Crank Case Sealant available in the UK? [Re: SBoyd] #240173
02/27/09 2:54 pm
02/27/09 2:54 pm
Anaerobics only set in the absense of air, any excess forced out of the joint stays liquid and will mix in with the oil to be removed at the next oil change. I have moved to Loctitie 518 from Blue Hylomar for this very reason, it works as it says on the tin and have no leaks so far where it has been used.
Re: Best Crank Case Sealant available in the UK? [Re: kommando] #240174
02/27/09 3:04 pm
02/27/09 3:04 pm
Sorry for the comments X4---my computer has this stuttering complaint sometimes------
Hey---what is this?----mixing Loctite with engine oil now?
Very severe case of Loctitus in my view.
Just use a judicious amount of Wellseal and all will be well.
When you strip an engine first time from factory build you will see a small amount of excess Wellseal dribbled down from the crankcase joint and set on the inside of the crankcase---doing no one and nothing any harm.
But deliberately passing Loctite through the oil pump, OPRV, big end bearings etc---the very thought makes me shudder!!!
Come to think of it it must be thinking about that that made my computer stutter earlier on!
Re: Best Crank Case Sealant available in the UK? [Re: Tridentman] #240236
02/27/09 6:34 pm
02/27/09 6:34 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Thanks Kommando, exactly.
T-man : Wasn't Capt Jean-Luc Picards name Loctitus after the Borg got him? wink
Blapper redwine
Re: Best Crank Case Sealant available in the UK? [Re: Blapper] #240273
02/27/09 9:18 pm
02/27/09 9:18 pm
Look Blap--you are supposed to be a Brit---so cut out all this French c**p!
Loctitus is defined as a disease in which Loctite is used in all sorts of strange places where it shouldnt be!
Seems like 75% of the posters on this board suffer from it---and I have to say, Blap, that you seem to be one of them!
Re: Best Crank Case Sealant available in the UK? [Re: Tridentman] #240287
02/27/09 10:45 pm
02/27/09 10:45 pm
British Columbia
hh Offline
hh  Offline
British Columbia
Loctite is a brand, not a product. Loctite 518 is an excellent aluminum crankcase sealant that only hardens where there is no air, and the remainder is harmlessly carried away in the oil.
