T100Mark
T100Mark
Southern California
44 registered members (21inGoldie), 206 guests, and 364 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,628 mail-order LSR
Topics68,845
Posts670,611
Members10,478
How do I remove this? #233872
01/21/09 9:43 pm
01/21/09 9:43 pm
San Jose, CA
V
vernonh Offline OP
vernonh  Offline OP
V
San Jose, CA
It's called the cable guide in the parts book. It needs to come out to remove that alternator housing. I tried getting the studs out but they're not budging.
Re: How do I remove this? [Re: vernonh] #233882
01/21/09 10:49 pm
01/21/09 10:49 pm
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Is there a reason you need to take the alternator housing out?
Re: How do I remove this? [Re: Mr Mike] #233883
01/21/09 11:10 pm
01/21/09 11:10 pm
San Jose, CA
V
vernonh Offline OP
vernonh  Offline OP
V
San Jose, CA
I'd like to clean behind it. If I can find another one that would be good since it's chipped.
Re: How do I remove this? [Re: vernonh] #233893
01/22/09 12:40 am
01/22/09 12:40 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Mines chipped too, but serves its purose. Nobody will ever know if it is clean back there and the primary chain won't care. My 2 cents.
Re: How do I remove this? [Re: Mr Mike] #233949
01/22/09 1:17 pm
01/22/09 1:17 pm
gavin eisler Online content
gavin eisler  Online Content
the alternator housing and chaincase are one casting, they dont come apart, no need to remove the cable guide, clean up the end though.
Watch out for a spacer stuck in the ds bearing seal, once you scrub it down , put it in the oven to get the bearing out.
Pod
Re: How do I remove this? [Re: gavin eisler] #233952
01/22/09 1:38 pm
01/22/09 1:38 pm
Rich B Online happy
Rich B  Online Happy
Cases prior to 68 had no cast in alternator support. A removeable support was available in 67 time frame. Prior to that, it was just studs.
Re: How do I remove this? [Re: Rich B] #234012
01/22/09 10:30 pm
01/22/09 10:30 pm
San Jose, CA
V
vernonh Offline OP
vernonh  Offline OP
V
San Jose, CA
So there's no way to remove it?
Re: How do I remove this? [Re: vernonh] #234020
01/22/09 11:17 pm
01/22/09 11:17 pm
Michigan, USA
BONZO R.I.P. Offline
Michigan, USA
Vernon , I cant tell from the pic , but if there is a hex at the base of that pipe it should simply unscrew . I've only seen that in the early engines though. I have had that alternator housing out of an engine once , I simply double nutted the studs and removed all three studs and wiggled the housing out . If I had to remove the pipe , and it wasnt threaded in , I would simply use some heat on the aluminum around it , propane should do the job but it might take some time , then with the aluminum expanding faster than the steel it should twist right outta there .
FWIW-BONZO
