The Bonneville Shop
wadeschields
wadeschields
10528 Registered Users
franko 90
NickL 66
785,188 mail-order LSR
Topics69,221
Posts674,274
Members10,528
Page 2 of 2 1 2
Re: Rollers anyone? What... [Re: noisy norton] #233531
01/19/09 5:50 pm
01/19/09 5:50 pm
, Lower -Lower michigan
Bob S Offline OP
Bob S  Offline OP
Dig----------yeah that starting motor is great.[el mirage] But.........i need one like yours as i have noone to help me,
The one you have, and i believe you are right about it staying centered.
Did you see the other one[that was doc z`s]Why would you want the motors to the rollers hooked up separately? I still think i can make one like yours work, and for one person, i will just attach a small ramp up to the rollers for better accesibility.
I am looking around for rollers. the thing will stay under the bike till you turn it off won't it????
I can see where it might launch you out of the garage if you weren't careful>
bob s
Bob S
Street Rods, Kustom Kars,A BSA,Cushmans,H.Shadow ACE, Now a 2004 triumph america . "More than enough!!!!
Re: Rollers anyone? What... [Re: Bob S] #233542
01/19/09 6:43 pm
01/19/09 6:43 pm
new zealand
dig Offline
dig  Offline
new zealand
Bob, yes, mine has a small ramp but its not shown.
Some V8 engines have them geared high torque starter motors.
As soon as i have bike started i select neutral as well as use front brake when starting.
Re: Rollers anyone? What... [Re: dig] #233544
01/19/09 7:10 pm
01/19/09 7:10 pm
Bob S Offline OP
Bob S  Offline OP
yes-------I have a high torque starter on my 32 ford coupe.It will start that coupe, when that car won't start any otherway[gets a mind of its own]
Did you have any ideas why they would use two motors? You don't need it set up that way.
bob s
Bob S
Re: Rollers anyone? What... [Re: Bob S] #233545
01/19/09 7:18 pm
01/19/09 7:18 pm
new zealand
dig Offline
dig  Offline
new zealand
LOL BOB its the MINE IS BIGGER thing Bob
Re: Rollers anyone? What... [Re: dig] #233546
01/19/09 7:23 pm
01/19/09 7:23 pm
Bob S Offline OP
Bob S  Offline OP
GOTCHA dig!!
bob s
Bob S
Re: Rollers anyone? What... [Re: Bob S] #233578
01/19/09 11:01 pm
01/19/09 11:01 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Somebody further up was talking about tapering the rollers towards the middle? I know it is counter intuitive, but they should be tapered towards the edge (larger dia in the centre). Honest! It is what stops toothed belts coming off apparently flat pulleys - they have a crown in the middle.
Blapper redwine
Re: Rollers anyone? What... [Re: Blapper] #233583
01/19/09 11:15 pm
01/19/09 11:15 pm
Bob S Offline OP
Bob S  Offline OP
THAT FIGURES
Bob S
Re: Rollers anyone? What... [Re: Bob S] #233594
01/20/09 12:26 am
01/20/09 12:26 am
Houston Texas
Britbodger R.I.P. Offline
Houston Texas
Bob,
Having two motors also puzzled me for a while confused . I think the reason is to lessen possibility of tire slip in the case of smooth racing tires on high compression racing engines that are hard to turn over.
One motor may work fine with a lower compression street bike with treaded tires.
my 2c
P.S. Now realize I am all wet on this one. Tried to delete post but couldn't so have to take my lumps I suppose blush
Re: Rollers anyone? What... [Re: Britbodger R.I.P.] #233608
01/20/09 2:14 am
01/20/09 2:14 am
Riverside, CA.
noisy norton Offline
Riverside, CA.
If you go to Doz Intl. they show a variety of starters. Some with single motors for starting speedway bikes. Phil's has two and they are independent of each other but boy do they work!! I think a single motor would have no problem starting high comp. motors.
TGA in England do a snazzy starter with tapered (to the center) rollers. The taper is to keep the wheel in the center of the rollers. The taper towards the edge is a recipe for disaster. But the price is 2000 Stg. Not sure what the current excahnge rate is but its over my head.
Anyone here remember run and bump starts? Well the rollers are the same thing only you are stationary. Spinn the back wheel and bump. No slippage.
I'll throw this up here. Its a Danish friend's nitro Godden firing up on home made rollers.
http://www.motorcykelgalleri.dk/html/vid_vis.asp?VideoID=2561
Re: Rollers anyone? What... [Re: noisy norton] #233611
01/20/09 2:23 am
01/20/09 2:23 am
Houston Texas
Houston Texas
Pavement has a higher coefficient of friction than do steel rollers. In this regard, have noticed that some rollers do have a high coefficient of friction coating on them to help correct this problem. Not sure how long this lasts though...
Re: Rollers anyone? What... [Re: Britbodger R.I.P.] #233612
01/20/09 2:32 am
01/20/09 2:32 am
Riverside, CA.
Riverside, CA.
The rollers on Phil's starter are smooth. I had no problem firing a 14:1 comp. Weslake. DocZ do rollers coated with some kind of coarse coating. Looked like sand in a fiberglass resin coating. I've seen rollers with non slip floor tape stuck on but wasn't really worth a damn.
Re: Rollers anyone? What... [Re: noisy norton] #233621
01/20/09 4:22 am
01/20/09 4:22 am
new zealand
dig Offline
dig  Offline
new zealand
Single motor yes, but both rollers driven if you look at it and smooth as well. You don't need any taper as its already built into the Tyre
Re: Rollers anyone? What... [Re: dig] #233624
01/20/09 5:02 am
01/20/09 5:02 am
Riverside, CA.
Riverside, CA.
Heres TGA's offering. I like the rollers and alloy frame but I don't like the price. $2804.35 at todays exchange rate! Sorry about the quality of the photo.
[Linked Image][/img]
Re: Rollers anyone? What... [Re: noisy norton] #233626
01/20/09 5:22 am
01/20/09 5:22 am
Ron - in California R.I.P. Offline
Hi Guys..!
Big Singles often will NOT start with those single starter motor jobs. That is why the twin starter motors exist. The whimpier twins start OK... not great but OK on the single units. BOTH rollers need to be driven or traction is an issue for sure. N.N's tire unit works good, lots of guys "back in the day" used mini bikes or small trail bikes to start their Dirt Track Bikes. Especially since my pal had a TD1-B for a Dirt Track bike... a real pain to get started sometimes...
Re: Rollers anyone? What... [Re: Ron - in California R.I.P.] #233646
01/20/09 1:10 pm
01/20/09 1:10 pm
Bob S Offline OP
Bob S  Offline OP
$2800.00.....thats not a good thing for a rider like me.now that link you gave me, noisey norton. thats a bike starter to behold. it don't show you alot . but may work perfect.I now have some ideas. if you think of anything else please let me know N.N.
i have to build one that i can zip the bike up on, hit a remote button on the wall, and takeoff.it don't have to be pretty, but thats the way i do things.
brit b.............the delete button won't let me wipe out anything, either. Another problem. although things are looking up a tad her lately.on the ole bbf.
bob s
Bob S
Re: Rollers anyone? What... [Re: Bob S] #233647
01/20/09 1:15 pm
01/20/09 1:15 pm
Bob S Offline OP
Bob S  Offline OP
My bonne is just a stock 70 650.Anything i would buy ........would not get used a bunch..but make my life a bunch easier!
bob s
Bob S
Re: Rollers anyone? What... [Re: Britbodger R.I.P.] #233652
01/20/09 2:04 pm
01/20/09 2:04 pm
Bob S Offline OP
Bob S  Offline OP
Brit B...........you mentioned DOZ intl, this won't bring anything up! do you have a better address i can use?
bobs
Bob S
Re: Rollers anyone? What... [Re: Bob S] #233734
01/21/09 12:01 am
01/21/09 12:01 am
Houston Texas
Houston Texas
Re: Rollers anyone? What... [Re: Britbodger R.I.P.] #233742
01/21/09 1:30 am
01/21/09 1:30 am
Riverside, CA.
Riverside, CA.
Bob, Try doczintl.com That should get you there. Rollers aren't rocket science. I'm looking at a piece of tubing in work that would make a fantastic set.
The TGA starter is a doozy. They had some various shots of it a while back. But thats all they now show. They also do a hand held remote for the starter. It couldn't be to hard to rig up a remote for any starter.
Re: Rollers anyone? What... [Re: Britbodger R.I.P.] #233836
01/21/09 5:34 pm
01/21/09 5:34 pm
Bob S Offline OP
Bob S  Offline OP
Brit B......thank you for the address.
bob s
Bob S
Re: Rollers anyone? What... [Re: noisy norton] #233838
01/21/09 5:40 pm
01/21/09 5:40 pm
Bob S Offline OP
Bob S  Offline OP
NOISEY NORTON....No they'er not rocket science, Ijust tend to use rocket science when i build something.And that ain't a good thing anymore, once i start a project i put my "all" into it.The tubing has to have bearings running true in both ends,is the biggest hurdle i can see on this deal.I am getting calls now on where to get the things i need. So i will come up with a starter. ...thank noisey norton
bob s
Bob S
Re: Rollers anyone? What... [Re: Bob S] #233850
01/21/09 7:05 pm
01/21/09 7:05 pm
wadeschields Offline
Let us know where you get the rollers Bob. The rest is easy.
Re: Rollers anyone? What... [Re: wadeschields] #233862
01/21/09 8:25 pm
01/21/09 8:25 pm
Bob S Offline OP
Bob S  Offline OP
yeah wade i'll bring it up when its starting the bike.and i will start the bike.
take care
bob s
Bob S
Page 2 of 2 1 2
