Simonofsweden
Simonofsweden
Gothenburg/Stockholm, Sweden
28 registered members (Andrew Dunham), 171 guests, and 382 spiders.
MackenzieBM, Metisseguy, Justintimeclark, Tim Pedder, blayde54
10481 Registered Users
NickL 100
franko 86
Triless 69
751,679 mail-order LSR
Topics68,883
Posts670,980
Members10,481
BSA C12 - lights give problems... #23291
04/06/07 7:28 pm
04/06/07 7:28 pm
Belgium
dakota Offline OP
dakota  Offline OP
Belgium
When I put on the lights (rear+front) and then open the throttle the engine starts to sputter and finally it stops running.
What is going on? The battery seems fine...
I don't know. Can somebdoy give me a hint?
thanx
Re: BSA C12 - lights give problems... #23292
04/06/07 9:04 pm
04/06/07 9:04 pm
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Start checking carefully for a loose wire. Check all areas where wire is in contact with the frame or metal bits for chaffing. It sounds like an intermittent short.
,_o
_ -\_<,
NOPGS #2
Re: BSA C12 - lights give problems... #23293
04/07/07 12:03 am
04/07/07 12:03 am
Winston, Oregon
beezerbill Offline
beezerbill  Offline
Winston, Oregon
If she runs ok before the light are turned on..well you got a big short in your wiring,,or also...make sure it's charging..one easy way put your light on a wall in the garage see if it get's a little brighter when you rev her up..if it don't well something...screwed up on the way..Beezerbill
Re: BSA C12 - lights give problems... #23294
04/08/07 8:33 pm
04/08/07 8:33 pm
Belgium
dakota Offline OP
dakota  Offline OP
Belgium
Fixed.
The wiring coming from the alternator were loose.
Thanx
