loment11
loment11
Seattle, WA
206 registered members (68 royalstar tony), 1,730 guests, and 591 spiders.
10036 Registered Users
Lannis 146
kommando 110
Stuart 64
478,053 mail-order LSR
Topics65,736
Posts635,437
Members10,036
kill switch for Commando #230905
01/02/09 9:18 pm
01/02/09 9:18 pm
Texas Gulf Coast
Curmudgeon Offline OP
Texas Gulf Coast
I'm having problems with the stock kill switch on my '74 Commando and would like to replace it with a good quality, handlebar mounted aftermarket switch. Can anyone recommend one? Thanks.
reliccycles.com
Re: kill switch for Commando [Re: Curmudgeon] #231035
01/03/09 6:15 pm
01/03/09 6:15 pm
Ron Leisner Offline
Ron Leisner  Offline
I would suggest adding a relay and cleaning and keeping your switch. The relay takes much less current to activate yet will supply full current to the ignition system.
If you add another switch, it will be in addition to your existing handlebar switch and not an easy reach from the handlebar grip.
If you are doing away with the entire switch and changing the master cylinder, then you can use most any Japanese or Italian switch gear that uses a normally closed kill switch.(I like using the late model Ducati stuff. There are usually a number of them on e-Bay)
Don't add a typical British magneto kill button as these are normally open and push to ground. This will cause a direct short in a battery and coil system.
Ron
Ron L
1973 MkV 750 Roadster
1974 850 Interstate
1975 850 Cafe Racer
1968 750 Fastback
1967 P11
1969 Ranger 750
Re: kill switch for Commando [Re: Ron Leisner] #231061
01/03/09 9:40 pm
01/03/09 9:40 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
I have worked on this project for a long time getting the fitments to apply to Norton, BSA and Triumph maybe others. It is a three relay kit with the required wiring to put it on your bike. The relays are Motorcycle duty not car relays that I started with.
Right away in the development the problem of models with small head lights came up so an under the tank system was chosen. The use is to your digression but started as high beam low beam and horn. On older bikes 67 and back with grounding switch horns I have used a separate relay wired it backwards in the headlight just for the horn and then used the third relay for the ignition switch.
The kit includes a 90 degree H-4 headlight plug, a fused connector for the battery end, the relays are pre-wired. All the wiring, shrouding, and connectors are of the highest quality. You just wire them on to your handle bar pod switches in the headlight shell than hook up to your Battery. Nothing shows but now the light and the horn really work well because the voltage does not have to travel up into the pod switches and than back to the device powered. Only enough power to trip the relay via the switch is needed after fitting the kit. PM me if you have interest in the kit.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: kill switch for Commando [Re: norbsa48503] #231252
01/05/09 2:11 am
01/05/09 2:11 am
Stuart Online content
Stuart  Online Content
With all due respect to the two posters above, from experience, I wouldn't use a relay switched by the kill switch to supply the ignition.
Bike makers have used relays on bikes for at least 40 years - switched by the handlebar horn button to supply twin horns, switched by a handlebar lever to supply flashers, switched by a handlebar button to switch an electric start, etc., etc. In addition, I've used relays on bikes for over 25 years - switched by the dipswitch to supply a high-wattage headlight bulb. The one thing all those have in common is, if the relay fails, it isn't a disaster.
Otoh, if either the kill switch or its relay fails - say, in the middle of an overtake with a truck heading towards you (this is known as Murphy's or Sod's Law wink ) - it is a disaster. Ignitions draw a relatively low current - points or first-generation electronic (e.g. Rita or Boyer-Bransden) about 3A, modern e.i. a little less - so adding a relay takes little load off the switch, but adding a relay adds a potential failure point.
Fwiw, I've run Brit. bikes with kill switches that have a distinct 'on' and 'off', Brit. bikes with kill switches that have to be pressed for off and Jap bikes that actually earth the ignition power through the kill switch ... and, ime, neither one type is any more, or less, reliable than any other. Just buy a new switch, maybe open it up and check that it doesn't have a manufacturing fault that would cause only a tiny contact area that will burn through, fit it, maybe check that there isn't an unexpectedly-high current draw across it, then forget it except once a year or so when you give it a little tlc.
Re: kill switch for Commando [Re: Stuart] #231257
01/05/09 2:58 am
01/05/09 2:58 am
orofino Idaho
Mike, in Idaho Offline
orofino Idaho
I would use a single pole double throw(five pole) relay, with the ignition wires run through the pair of normally closed contacts(30 and 87a).You kill the ignition by energising the relay(contacts 85 and 86) with 12 volts from the "extra" button on the other side of the switch gear. Wired this way, the relay contacts seldom move and theoretically should last a very long time. You could even tee the unused terminal(87)into the brake light circuit to warn following traffic that you will be slowing down.
Mike
My company car is a Kenworth
Re: kill switch for Commando [Re: Mike, in Idaho] #231654
01/07/09 3:16 pm
01/07/09 3:16 pm
Texas Gulf Coast
Texas Gulf Coast
Thank you all for the advice. I'm the type that likes to keep things as simple as possible so I'm leaning towards using the type of kill switch that my old Rocket 3 had mounted on the handlebars, the push-to-open one with rubber boot cover like the rear brake light switch. For now I've just bypassed the stock switch by removing the two wires from the circuit.
reliccycles.com
Re: kill switch for Commando [Re: Curmudgeon] #231905
01/09/09 1:00 am
01/09/09 1:00 am
FLORIDA
Alan Prudhomme Offline
FLORIDA
Try http://www.tri-corengland.com/acatalog/Handlebar_switchgear.html I just love these long addresses! Try SPARX ELECTRICS, they cary a line of handlebar switchgear that are dead ringer for the stock unit. I have taken apart stock switches and repaired them but if some one buggered it up already it's eBay or SPARX.
Moderated by  Dave Comeau
