glastrywhippet
glastrywhippet
co.down n.ireland
45 registered members (Alan_nc), 296 guests, and 461 spiders.
Kara Chaffee, Dan1818, Konaflyer, Begbie, Andrew Fallo
10420 Registered Users
btour 84
Rohan 78
Triless 70
reverb 68
713,931 mail-order LSR
Topics68,332
Posts665,254
Members10,420
Why? Not gettin it... #229985
12/28/08 1:56 pm
12/28/08 1:56 pm
DPO Offline OP
DPO  Offline OP
My '72 T120 is 90% finished, and runs great. I tickle the Amals, and she always fires right up on the first kick. When I first start her up, I have to constantly "tap" the throttle to keep her idling until she warms. Once out on the open road after awhile, when I stop for a traffic light, the RPM's are now at 2500 or so. Once the engine cools to ambient temps (overnight), I have to tap the throttle to keep her idling. Checked sliders AGAIN..they are dead on the stops (1/4 turn on idle stop screw)..Something to do with engine temp Im thinking...Anyone else have this problem? Very frustrating (Dang it)...Thanks in advance for any guidance.
1971 Triumph T120
2005 Triumph "America"
1976 BMW R90/6
Re: Why? Not gettin it... [Re: DPO] #229988
12/28/08 2:05 pm
12/28/08 2:05 pm
triton thrasher Offline
Set idle and all other carb adjustments on a fully warm engine.
It's not meant to idle when cold- how can it?
Re: Why? Not gettin it... [Re: triton thrasher] #229997
12/28/08 3:18 pm
12/28/08 3:18 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Sounds like your idle mixture is weak if revs increase as the engine warms up, but you can reckon to help the idle with the throttle a bit when cold anyway.
Blapper redwine
Re: Why? Not gettin it... [Re: triton thrasher] #230048
12/28/08 10:57 pm
12/28/08 10:57 pm
DPO Offline OP
DPO  Offline OP
Did that....idle screws all the way out, pilot air screw all the way out, no help..If I turn the pilot air screw in, mixture really leans out...Sounds like a slide problem, but cant pinpoint it...both slides are synched, and slide free....
1971 Triumph T120
1976 BMW R90/6
Re: Why? Not gettin it... [Re: DPO] #230049
12/28/08 11:40 pm
12/28/08 11:40 pm
Florida
F
Florida TR6 Offline
Florida TR6  Offline
F
Florida
If none of the suggestions above has worked, perhaps the carburetor bores are worn. If there is excessive slop between one or both of the slides and one or both of the carburetor bodies, you'll likely never get it to idle properly. One of our BBF sponsors, Lund Machine, amalsleeve.com, has a great remedy for this. Costs $75 per carb, but what a difference. Mine came back in two weeks. Worth every penny, a new slide alone is about $30 and does not solve the problem of a worn bore. Good luck.
"For every problem, there is a solution that is simple, neat, and wrong." H.L.MENCKEN
'06 T100 Bonneville
'70 TR6 Bitsa, Pazon EI
Re: Why? Not gettin it... [Re: Florida TR6] #230051
12/29/08 12:22 am
12/29/08 12:22 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Whatley's Second Law of Brit Bikes: A man always buys a Brit bike with one more carburetor than he is capable of tuning.
Tom -
Engine idle is controlled by a lot more than the carb slide...
Condition of the balance tube
Seal of the carb to the intake manifold
Condition of the AAU
Heat range of the spark plug
Grade of fuel
...just to name a few.
:bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Why? Not gettin it... [Re: RF Whatley] #230074
12/29/08 2:08 am
12/29/08 2:08 am
Florida
F
Florida TR6 Offline
Florida TR6  Offline
F
Florida
Richard: My plea (guilty as charged) is mitigated by the Mencken BBF signature I use.
'06 T100 Bonneville
Re: Why? Not gettin it... [Re: Florida TR6] #230082
12/29/08 3:22 am
12/29/08 3:22 am
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
Quote: If I turn the pilot air screw in, mixture really leans out. Say What? Jack
Re: Why? Not gettin it... [Re: Jack Adams] #230116
12/29/08 1:35 pm
12/29/08 1:35 pm
DPO Offline OP
DPO  Offline OP
Seems to lean out, never really figured out that by turning pilot air screw, if it leans or richens....seems to lean it out, may be wrong. Regardless, this (or either) adjustment will not lower RPM'S below 2500. Makes it hard on the tranny.
1971 Triumph T120
1976 BMW R90/6
Re: Why? Not gettin it... [Re: DPO] #230123
12/29/08 2:53 pm
12/29/08 2:53 pm
Tridentman Offline
Tridentman  Offline
Air leak carb to manifold? Try sqirting WD40 on joint when idling at 2500 rpm and see if it makes a difference.
Re: Why? Not gettin it... [Re: Tridentman] #230132
12/29/08 3:25 pm
12/29/08 3:25 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
O.K. DPO, 2500 rpm takes air, so as TDM is pointing out you may have an air leak,but if not carb to manifold,keep checking every possible connection. Also do you have some slack in the cables so the slide is not being held off of its seat? Are the slides so worn that they are getting cocked in the carb body. Finally, were we not here before? Jack
Re: Why? Not gettin it... [Re: Jack Adams] #230152
12/29/08 5:38 pm
12/29/08 5:38 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
I thought this sounded familiar, like Oct.21 2008. All I can say is Hey Tridentman, Heeee's Baaack! Watch your legs! Jack
Re: Why? Not gettin it... [Re: Jack Adams] #230166
12/29/08 7:08 pm
12/29/08 7:08 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Then:
Aren't those two statements contradictory DP? I'd call that 'runs like sh*t' personally.
Blapper redwine
Re: Why? Not gettin it... [Re: Blapper] #230176
12/29/08 10:02 pm
12/29/08 10:02 pm
New Brunswick, Canada.
Bruce Martin Offline
I have found that this problem can be caused by friction in the throttle cables. Is the routing correct without any sharp bends or pinches and are the cables well lubricated?
1937 Ariel Red Hunter 500
1970 Triumph Bonneville
Making the scene with the gasoline
Re: Why? Not gettin it... [Re: Bruce Martin] #230192
12/29/08 11:33 pm
12/29/08 11:33 pm
Beautiful North Carolina
HughdeMann Offline
HughdeMann  Offline
DPO, those are NOT pilot air screws. If they lean the mixture when turned in, the must be idle mixture screws. They control the amount of FUEL flow at idle. Now, before anyone gets prickly about this, remember that to get correct help, you must ask correct questions. Correct questions contain the correct terminology. Now, back to all the responses.
1964 Bonneville
A couple others
Re: Why? Not gettin it... [Re: HughdeMann] #230215
12/30/08 2:04 am
12/30/08 2:04 am
Tridentman Offline
Tridentman  Offline
Legs well guarded, Jack!
One question---is this the last DPO saga of 2008 or the first one of 2009----or both?
Re: Why? Not gettin it... [Re: Tridentman] #230232
12/30/08 3:37 am
12/30/08 3:37 am
JubeePrince Offline
JubeePrince  Offline
Deep -
Sit back, grab a cold one and read through this:
http://www.jba.bc.ca/Bushmans%20Carb%20Tuning.html
It may not cure your ills (the reading that is), but it might help you with your carbs......(AMAL not ale) laughing
HTH,
Re: Why? Not gettin it... [Re: JubeePrince] #230266
12/30/08 1:07 pm
12/30/08 1:07 pm
DPO Offline OP
DPO  Offline OP
Thanks Jubee, printed out, great information. You know what? I think it's probably better for me to simply "lurk" and use information on here rather than post anything, as too many instigators trying to redicule everything...Thanks for all the help, those of you that have....No reply's, please.
1971 Triumph T120
1976 BMW R90/6
Re: Why? Not gettin it... [Re: DPO] #230276
12/30/08 2:38 pm
12/30/08 2:38 pm
georgia
trumpetloon Offline
trumpetloon  Offline
georgia
Let's get back to basics for a sec... the carbs are the last thing to eff with when setting up a fresh rebuild. Are you SURE the ignition timing is correct (via timing light not eyeball) for BOTH sets of points? Deductive reasoning leads me to think that since nothing you have done to the fuel system has cured the problem perhaps you don't have a fuel related issue?????? Just thinking out loud here... no disrespect intended.
1974 TR5T
Re: Why? Not gettin it... [Re: Tridentman] #230443
12/31/08 2:50 pm
12/31/08 2:50 pm
East Bethany New York
Dick Harris Offline
Dick Harris  Offline
I think that our old friend,Jack,is trying to tell you that the screw in question,is called the "airscrew" which in operation,will,as you turn the screw in (clockwise) will decrease the air supply,making the mixture rich. Right Jack,Yuk,yuk Rooster Racing #2
Re: Why? Not gettin it... [Re: Dick Harris] #230489
12/31/08 6:04 pm
12/31/08 6:04 pm
Tridentman Offline
Tridentman  Offline
Happy New Year DPO.
May the New Year bring you plenty of sagas for us to enjoy and you to endure and hopefully succeed.
Re: Why? Not gettin it... [Re: Tridentman] #230856
01/02/09 4:06 pm
01/02/09 4:06 pm
DPO Offline OP
DPO  Offline OP
Happy New Year to you and yours as well TDM...and you to Hacksaw Adams!!!
1971 Triumph T120
1976 BMW R90/6
