T100Mark
T100Mark
Southern California
50 registered members (Adam M.), 221 guests, and 373 spiders.
10478 Registered Users
NickL 89
franko 78
Triless 69
748,659 mail-order LSR
Topics68,846
Posts670,617
Members10,478
Cracked aluminum barrells #230154
12/29/08 5:59 pm
12/29/08 5:59 pm
Sanger, CA
jim schmidt Offline OP
Sanger, CA
I've discovered a couple cracked aluminum aftermarket cylinders for Norton twins. The crack occurs between the bores when the sleeves are pressed in. The material is very thin there and you can only see the crack at the bottom or if the liners are removed. The crack runs from top to bottom. Has any one else noticed this and what brand cylinders are cracking? Anyone notice overheating or smoking?
thanks
Jim
Re: Cracked aluminum barrells [Re: jim schmidt] #230181
12/29/08 10:45 pm
12/29/08 10:45 pm
Nashville, Tn.
T. Sharp Offline
T. Sharp  Offline
Nashville, Tn.
Jim, I've seen some advertised in the past that have pointed out the cracks; don't know what brand.
The old Morgo iron Triumph cylinder would crack if you tried to put two liners in the block. One was OK; two would split the thing up the middle!
Sounds like something I wouldn't want to risk the bank on!
Moderated by  Allan Gill
