Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,884 guests, and 585 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,307 mail-order LSR
Topics65,693
Posts634,977
Members10,027
6V to 12V #228917
12/20/08 1:13 pm
12/20/08 1:13 pm
SA, Australia
3
3TA1962 Offline OP
3TA1962  Offline OP
SA, Australia
To convert an 3 wire alternator (Triumph 3TA)from 6v to 12v, 2 wires have to be joined. My bike has Green/yellow, blue & brown wires from the alternator. Which 2 are joined or doesn't it matter?
Re: 6V to 12V [Re: 3TA1962] #228945
12/20/08 5:37 pm
12/20/08 5:37 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
3TA welcome to the forum.
It matters a lot.
The colors that are most common on 3 wire Lucas stators are:
green/black, green/yellow, and white/green.
Since yours is a 1962 AFIK that should be the case.
In that case, it is the G/B and G/Y that are connected together.
The W/G stands alone.
I would say, double-check the colors all the way back to the open-frame stator. Maybe someone soldered on new leads.
If you can afford it, now is the time to upgrade to a new 2 wire encapsulated stator. The pattern ones are reasonable in price.
good luck
>>sb
Stop the insanity.
Re: 6V to 12V [Re: SBoyd] #229007
12/21/08 3:10 am
12/21/08 3:10 am
SA, Australia
3
3TA1962 Offline OP
3TA1962  Offline OP
SA, Australia
SBoyd thanks for the information.
You were right, someone has soldered new leads on. So I'm still in the dark (no pun intended re Mr Lucas). Can anyone identify which correct coloured wires used to be connected to which coils. I'm trying to get out of this as cheap as possible + I like trying to fix things in this disposable world.
Thanks for any assistance.
Re: 6V to 12V [Re: 3TA1962] #229022
12/21/08 10:25 am
12/21/08 10:25 am
It should be possible to work it out, presuming the 6V system is working now.
2 alternator leads go to the rectifier, don't they? and a third one goes to the light switch and is connected to one of the other two, only when the headlight is switched on. So you want the third one connected permanently to the one that the switch connects it to now. Does that make sense?
I don't think you can damage the alternator by getting it wrong (no guarantee, I'm just an internet nonentity).
Re: 6V to 12V [Re: 3TA1962] #229065
12/21/08 3:51 pm
12/21/08 3:51 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Alternator wire identification: http://www.classicmotorcycles.org.uk/c15/c15_alternator_wiring.htm
12V Conversion: http://www.classicmotorcycles.org.uk/c15/c15_12v_conversion.htm
Re: 6V to 12V [Re: L.A.B.] #229106
12/21/08 9:21 pm
12/21/08 9:21 pm
SA, Australia
3
3TA1962 Offline OP
3TA1962  Offline OP
SA, Australia
Thankyou all for your assistance and links.
Should be able to sort it out now
