Display Name
Display Name
Vancouver Island
33 registered members (Bigtwin), 302 guests, and 131 spiders.
10173 Registered Users
Lannis 93
reverb 83
Stuart 77
NickL 67
koan58 61
550,961 mail-order LSR
Topics66,568
Posts645,327
Members10,173
1972 T120 valve setting #221037
10/28/08 9:47 pm
10/28/08 9:47 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
getting ready to set the valves on my bike...should i use the haynes manual setting or ?????????????seems i recall there has been some controversy on this
thanks
stay warm it finally got cold down here in NC today
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: 1972 T120 valve setting [Re: raf940] #221043
10/28/08 10:54 pm
10/28/08 10:54 pm
Florida
F
Florida TR6 Offline
Florida TR6  Offline
F
Florida
Posted October 2006 by John Healy:
"Scout Dog:
Some notes: Although the factory figures were .002" and .004" for the 650, west coast distributor, Johnson Motors, recommended running the 650's with .004" and .006". At these figures the valves were not particularly noisy."
"For every problem, there is a solution that is simple, neat, and wrong." H.L.MENCKEN
'06 T100 Bonneville
'70 TR6 Bitsa, Pazon EI
Re: 1972 T120 valve setting [Re: Florida TR6] #221046
10/28/08 11:01 pm
10/28/08 11:01 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
ah so....but why the wider settings??
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: 1972 T120 valve setting [Re: raf940] #221078
10/29/08 1:47 am
10/29/08 1:47 am
Cincinnati, Oh
Jethro Offline
Jethro  Offline
Cincinnati, Oh
Boy, this is an interesting bag of worms... I'm not sure some ppl who THINK they know how to set valves DO... probably starting with me. The basic premise behind the idea of setting the valves "slightly loose" is protection. Meaning, if the valves are too tight, they will not be able to cool sufficiently, and they can indeed "burn up". Too loose and performance suffers, and the valves can also be very noisy, as Florida points out. I have tried to set the valves at both clearances referenced above. I think I have been successful, and for ME... and me only, I do notice a difference when the valves are set to factory standards on my 71 T120. But then again, I am careful not only setting them, but checking them multiple times before buttoning everything up. I forgot to point out also, that some riders feel the difference in modern petrol is a good reason to provide a "cushion" that older, lead based fuels provided.
Re: 1972 T120 valve setting [Re: Jethro] #221095
10/29/08 8:46 am
10/29/08 8:46 am
dave jones Offline
dave jones  Offline
I set mine with feeler gauges to 2 and 4 and it is ok. However, after a very high mileage, the valves can acquire a dent in the top where the rockers bear on them which the feeler doesn't take into account so you get a bigger clearance anyway!
Re: 1972 T120 valve setting [Re: dave jones] #221105
10/29/08 11:32 am
10/29/08 11:32 am
DPO Offline
DPO  Offline
Are ya'll talking about the valve clearance, as far as the gap between the rocker and the stem? I set mine per the manual at .020, runs sweet...what am I missing here?
1971 Triumph T120
2005 Triumph "America"
1976 BMW R90/6
Re: 1972 T120 valve setting [Re: DPO] #221109
10/29/08 12:22 pm
10/29/08 12:22 pm
dave jones Offline
dave jones  Offline
DPO- If you have a unit 650 Triumph the original clearances were .002" inlet and .004" for the exhaust. What you are using, if you haven't written it incorrectly, is 20 thousandths of an inch which is too big. Some people like to set them a little wider than the original book to .004" and .006".
Re: 1972 T120 valve setting [Re: DPO] #221111
10/29/08 12:30 pm
10/29/08 12:30 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
DPO, What are you missing here? A real manual? A decimal point? A correct feeler gauge? Common sense? Take your pick. Indiana Rooster
Re: 1972 T120 valve setting [Re: Jethro] #221112
10/29/08 12:49 pm
10/29/08 12:49 pm
JubeePrince Online content
JubeePrince  Online Content
The bane of air-cooled engines: how to keep them cooled sufficiently....
The valves need to seat well and uniformly in order for the heat to be dissapated to the head....the head acts as a heat sink for the valves...
If the valve or seat is not Concentric, or the lash is too tight, you end up with hot gases heating the edge of the valve.....then you have a nice glow plug to start the process of preigntion.....it all goes slowly downhill from there.....
Re: 1972 T120 valve setting [Re: JubeePrince] #221114
10/29/08 1:06 pm
10/29/08 1:06 pm
gastonia nc
raf940 Offline OP
raf940  Offline OP
gastonia nc
i recollect an old guy i used to know who worked on british cars..especially austin-healy 3000s..his motto on valves was ..."valves are like f*rts..i would rather hear them than smell them (burning)"
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: 1972 T120 valve setting [Re: raf940] #221118
10/29/08 1:43 pm
10/29/08 1:43 pm
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
laughing I like it!
Blapper redwine
Re: 1972 T120 valve setting [Re: Blapper] #221123
10/29/08 2:22 pm
10/29/08 2:22 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
I just realized that DPO was using .020 for both cams because he was using the specs. for degreeing cams as running clearance.As usual DPO was just being consistant. Also I must have a different idea as to what "running sweet" means. I know "a slappy tappet is a happy tappet" but .020 is way past happy! Jack
Page Time: 0.064s Queries: 15 (0.005s) Memory: 1.0749 MB (Peak: 1.2847 MB) Zlib disabled. Server Time: 2018-04-22 21:54:19 UTC
