pittss1s
pittss1s
hamilton, va
29 registered members (Al Eckstadt), 187 guests, and 344 spiders.
10476 Registered Users
NickL 89
franko 72
Triless 67
746,785 mail-order LSR
Topics68,808
Posts670,219
Members10,476
pre unit vs unit pistons 650, same???? #220180
10/22/08 10:56 pm
10/22/08 10:56 pm
T120C Offline OP
T120C  Offline OP
Having discussion with friends about this, so pre unit triumph 650 pistons different than unit pistons 650?? specifically 1959 bonnie vs 1966 bonnie??
Jack
1967 MGB Roadster..
1959 Bonnie
1967 Bonnie in disguise as a Trophy
Re: pre unit vs unit pistons 650, same???? [Re: T120C] #220218
10/23/08 3:01 am
10/23/08 3:01 am
Jon W. Whitley Offline
I don't see why they would be or that you couldn't use the 1966 pistons. They both have the same rods, aluminum head and pushrods. I would think that comparable CR would be the same piston.
:bigt
Re: pre unit vs unit pistons 650, same???? [Re: Jon W. Whitley] #220275
10/23/08 1:34 pm
10/23/08 1:34 pm
T120C Offline OP
T120C  Offline OP
That was my thought Jon... They had stated that the pistons were heavier and the piston skirts were longer on the pre unit.. and I did not remember that in my pass projects... Thanks for confirmation...
Jack
Jack
1967 MGB Roadster..
1959 Bonnie
Re: pre unit vs unit pistons 650, same???? [Re: T120C] #220278
10/23/08 2:10 pm
10/23/08 2:10 pm
John Healy Offline
John Healy  Offline
Before about 1966 Triumph made their own pistons. They were made from a hypereutectic aluminum allow and can be identified by the "Lo-Ex" (low expansion) on the casting next to the wrist pin hole on the side of the piston.
http://kb-silvolite.com/article.php%3Faction%3Dread%26A_id%3D2
This is an important detail, as the later pistons, made by AE/Hepolite and supplied by Triumph as o.e.m. and available now in the after market, are not made from the same alloy and are NOT low expansion.
The early Triumph o.e.m. pistons, being low expansion required less piston clearance than the later equivalents. Fitting a late low silicone Hepolite, JCC, etc with the piston clearances for the earlier high silicone - low expansion pistons can lead to piston seizure!
Recommended clearance for Triumph 650 "Lo-Ex" pistons: .0035"
Recommended clearance for AE/Hepolite 650 pistons fitted as o.e.m and available today in the after market: .0046" to .0061"
Re: pre unit vs unit pistons 650, same???? [Re: John Healy] #220293
10/23/08 3:30 pm
10/23/08 3:30 pm
T120C Offline OP
T120C  Offline OP
Thanks John, that is a good thing to know.... The other discussion we had is boring cylinders more than 40 over... I had read that triumph did not recommend going over 40 over or over 20 over for alloy cylinders... does everyone agree with this?? then why do they make 60 over pistons???
Thanks for the help
Jack
Jack
1967 MGB Roadster..
1959 Bonnie
Re: pre unit vs unit pistons 650, same???? [Re: T120C] #220294
10/23/08 3:42 pm
10/23/08 3:42 pm
John Healy Offline
John Healy  Offline
The Triumph distributor in Baltimore MD supplied piston up to .100" over for the 650 with a disclaimer: "If the cylinder broke at the flange it was not their fault."
You can find the quote in one of the TriCor Service Bulletins.
Re: pre unit vs unit pistons 650, same???? [Re: John Healy] #220304
10/23/08 4:13 pm
10/23/08 4:13 pm
Very interesting. I did not know that eek
Re: pre unit vs unit pistons 650, same???? [Re: T120C] #220327
10/23/08 5:16 pm
10/23/08 5:16 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Like John said.... but there is also another big difference if you are discussing generic pre-unit vs. unit construction. Generic pre-unit could also include iron head engines, like the Thunderbird. The iron head has a much deeper "dish" and no squish band, therefore the crown of the piston rises much higher up into the head than on the alloy sport heads.
So you can run alloy head pistons in an iron head, but you cannot run iron head pistons in an alloy head (without some tricky piston crown machining).
You'll want to remember this next time you see new pistons on sale for ridiculously cheap prices... they're probably iron head pistons.
:bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
