BrizzoBrit
BrizzoBrit
Brisbane, Australia
39 registered members (AML), 240 guests, and 383 spiders.
10476 Registered Users
franko 72
Triless 65
747,514 mail-order LSR
Topics68,824
Posts670,351
Members10,476
A65 Emco muffler #216082
09/29/08 11:04 pm
09/29/08 11:04 pm
Bethesda, MD
V
Valk Offline OP
Valk  Offline OP
V
Bethesda, MD
I bought an Emco muffler for my '66 Tbolt and it doesn't fit. The exhaust pipe does not go into the muffler far enough for the mounting bolt to align with the frame - it hits the baffle. My old mufflers, which I beleive are stock BSA, work fine in this regard, as the baffles are set further back inside the muffler.
Also, I have what I believe are called "TT" pipes. They do not have a gentle curve as stock, but more of a right angle at the head. Could these pipes possibly be longer than stock and thus causing this problem with the Emco?
I could saw an inch or two off the pipes and make them fit, but I'm not going to.
Anyone else experience this problem???
Thanks very much,
Peter
'56 Road Rocket
'66 Lightningbolt
'98 Valk
Re: A65 Emco muffler [Re: Valk] #216343
10/01/08 2:27 am
10/01/08 2:27 am
Winston-Salem N.C.
D.W.R. Offline
D.W.R.  Offline
Winston-Salem N.C.
Well, I see that no one has said it, may as well be me.
Got a good flame suit!
Since you have after market pipes from one manufacturer, and muflers from another, I'm not real surprised you're experiancing problems! You're going to have to modify something to make it work with the parts you have, or try different parts.
Not an uncommon situation from what I've seen over the years.
Sorry!
Don R.
Re: A65 Emco muffler [Re: D.W.R.] #216371
10/01/08 11:09 am
10/01/08 11:09 am
San Luis Obispo, CA
Richard Phillips Offline
San Luis Obispo, CA
Peter,
If you have the TT pipes, orginal TT pipes. Don't cut them. Some one would want them. Mater of fact I would for my west coast Hornet.
Regarding the Emgo mufflers, I have used these without a problem but I use the stock pipes.
Richard Phillips
Re: A65 Emco muffler [Re: Richard Phillips] #216399
10/01/08 1:58 pm
10/01/08 1:58 pm
Bethesda, MD
V
Valk Offline OP
Valk  Offline OP
V
Bethesda, MD
Thanks for the responses. Perhaps this is a better way to approach this: are the Emgo mufflers, which are routinely described on eBay and at meets as "stock replacements", identical to stock BSA? The one I have looks identical on the outside, but, like I referenced above, is very different on the inside.
Thanks again,
Peter
PS I have 1 brand new Emgo a65 muffler for sale. I ain't giving up the TT pipes.
'56 Road Rocket
'66 Lightningbolt
'98 Valk
Re: A65 Emco muffler [Re: Valk] #216403
10/01/08 2:28 pm
10/01/08 2:28 pm
Rich B Offline
Rich B  Offline
Alex & I are both using the Emgo's. They do look and fit like stock. However, the baffles are different and they are somewhat louder than a set of stock mufflers.
No one is going to flame you Don....oh wait, this is the 'net, even when you are right you can get flamed eek
Re: A65 Emco muffler [Re: Rich B] #216404
10/01/08 2:42 pm
10/01/08 2:42 pm
Bethesda, MD
V
Valk Offline OP
Valk  Offline OP
V
Bethesda, MD
well there you go - thanks for the answer Rich.
Peter
'56 Road Rocket
'66 Lightningbolt
'98 Valk
Re: A65 Emco muffler [Re: Valk] #216413
10/01/08 3:47 pm
10/01/08 3:47 pm
San Diego, CA
Will S. Offline
Sponsor Member
Will S.  Offline
Sponsor Member
San Diego, CA
Hi Valk - Your description sounds like photos I've seen of aftermarket Cycle Shack pipes, with the sharp right angle at the head.
Also, I'm confused as to how stock A65 mufflers would fit on TT pipes, what with the TT pipes coming together under the motor and terminating in front of the rear tire?
Will S.
BSAs: '66 & '69 Lightning
Triumphs: '68 TR6R, '68 Bonneville, '73 TR7, '55 6T
'71 Norton Commando
www.britironsd.com
Re: A65 Emco muffler [Re: Will S.] #216415
10/01/08 3:58 pm
10/01/08 3:58 pm
Bethesda, MD
V
Valk Offline OP
Valk  Offline OP
V
Bethesda, MD
Hi Will,
No, my pipes are not the ones you speak of - I know what you are referring to. The angle on my pipes at the head is not a sharp, radical right angle, nor do they come under the frame. Mine could easily be mistaken for stock except, again, for the angle at the head and apparently they're a bit longer. I'll try and post a pic.
Peter
'56 Road Rocket
'66 Lightningbolt
'98 Valk
