24 registered members (Alan_nc), 232 guests, and 467 spiders.
10291 Registered Users
Stuart 93
Lannis 66
Mori55 64
637,456 mail-order LSR
Topics67,386
Posts654,254
Members10,291
Making a Piston Stop out of a Spark Plug #206409
07/13/07 2:10 pm
07/13/07 2:10 pm
England
Tom_dup1 Offline OP
Tom_dup1  Offline OP
England
I've seen references to making a piston stop out of an old spark plug. Have done a search but can't find anything. I want to make one so that I can accurately measure TDC (with a degree wheel) without taking the head off to use a dial gauge. I want to dial the cam in on my B40 scrambler.
Anyone got the recipe?
Tom
Re: Making a Piston Stop out of a Spark Plug #206410
07/13/07 2:38 pm
07/13/07 2:38 pm
Out There!
Nick Offline
Nick  Offline
Out There!
knock the guts out of a spark plug - braze/weld a nut on the top - screw a bolt down the center - use another nut to lock the bolt in place - if your're timing a high performance engine and a valve hits the plug stop, remove stop, turn engine until valve returns to seat and re-install stop to catch piston on its way back up.
Re: Making a Piston Stop out of a Spark Plug #206411
07/13/07 2:45 pm
07/13/07 2:45 pm
England
Tom_dup1 Offline OP
Tom_dup1  Offline OP
England
Excellent, thanks Nick!
Re: Making a Piston Stop out of a Spark Plug #206412
07/13/07 3:15 pm
07/13/07 3:15 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
If your going to the trouble try to make sure that the stop is long enough to stop the piston at about 30 degrees. As Mr. Panic has stated it's better than one that stops it at just 10 degrees. Put a bull nose radius on the end of the bolt at the contact spot. On a Norton this is about an inch and a 1/4 long and a diameter of .160 will just miss the valves.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: Making a Piston Stop out of a Spark Plug #206413
07/13/07 5:21 pm
07/13/07 5:21 pm
Hammond, LA
liaison Offline
liaison  Offline
Hammond, LA
About 40 years ago when I thought that a big hammer was a necessary tool for working on bikes, I made a piston stop by finding an old bolt that was a semi-interference fit in the spark plug body and pounding it home. The piston stop is still in my tool box, but the hammer has been retired.
Brgds,
Jim
1966 Triumph T120R
2005 Suzuki DL650 V-Strom
Brgds,
Jim
1966 Triumph T120R
Re: Making a Piston Stop out of a Spark Plug #206414
07/13/07 5:29 pm
07/13/07 5:29 pm
I used a wooden dowel epoxyied into the plug body, less chance of hurting piston or valve but you have to be very careful not to snap the wood and have to take the head off. Touch wood never had to but there is always a first time .
Re: Making a Piston Stop out of a Spark Plug #206415
07/13/07 10:30 pm
07/13/07 10:30 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
If you make a 'bump stop', by threading the body of a spark plug for a largish bolt, insure you have a vent hole to allow compression pressure to escape. And as has been mentioned, be sure to round off the end of the bolt to prevent marring the top of the piston.
dave - NV
Re: Making a Piston Stop out of a Spark Plug #206416
07/13/07 11:23 pm
07/13/07 11:23 pm
Anonymous
Unregistered
Anonymous
Unregistered
"insure you have a vent hole to allow compression pressure to escape"
This is an excellent and frequently overlooked point. If any compression is trapped near TDC it will tend to rock the crankshaft back away from TDC, and may be small enough not to be easily detected - but will make the measured distance useless.
If possible, the hole should be large to vent the cylinder without delay. If the hole needs be small, it's important that you wait until the escaping air stops before proceeding.
Some of the softer plastics can be threaded 14mm, drilled, and won't damage the piston on contact but I don't know which; shop-made tool seen long ago.
Re: Making a Piston Stop out of a Spark Plug #206417
07/14/07 1:29 am
07/14/07 1:29 am
georgia
trumpetloon Offline
trumpetloon  Offline
georgia
If you use a smooth rod equipped with a set screw locked collar, you will be able to take dial indicator measurements directly from the rod through the center. Think timing locator tool writ large; with a repeatable stop for precise measurement. HTH!!! beerchug
1974 TR5T
Re: Making a Piston Stop out of a Spark Plug #206418
07/14/07 3:23 am
07/14/07 3:23 am
Anonymous
Unregistered
Anonymous
Unregistered
but... you need to do the trig re: the plug angle to determine the actual movement - the dial motion will always be larger. What's the plug angle? IKBA.
Re: Making a Piston Stop out of a Spark Plug #206419
07/15/07 8:17 pm
07/15/07 8:17 pm
georgia
trumpetloon Offline
trumpetloon  Offline
georgia
Panic; please 'splain...triangles confuse me. Isn't the motion in a straight line regardless of angle of inclination and hence "one to one"?
1974 TR5T
Re: Making a Piston Stop out of a Spark Plug #206420
07/16/07 6:17 am
07/16/07 6:17 am
England
Tom_dup1 Offline OP
Tom_dup1  Offline OP
England
Thanks. The tool is now made! I included a vent hole and the welder accidently made another. Damn thin those spark plug casings.
Re: Making a Piston Stop out of a Spark Plug #206421
07/16/07 2:49 pm
07/16/07 2:49 pm
Anonymous
Unregistered
Anonymous
Unregistered
Look at it this way: if the plug thread were horizontal, an indicator in the plug hole wouldn't move no matter what the piston did - its movement could be infinite and would still show nothing. If the plug thread were vertical (parallel to the bore axis) the indicator movement would be exactly the same as piston movement.
In between (which is almost everything except some flatheads) the indicator distance is always larger since it's a vector: one component is horizontal (based on the angle) and the other is vertical (based on piston movement).
To find the actual piston movement, multiply the indicator reading by the cosine of the plug angle.
If 0 is a vertical plug, a 30 plug indicator reading will be higher than the actual movement; multiplied by the cosine of 30 (.866), each .100" of indicator travel = .0866" of piston movement.
45 plug: .7071, 15 plug: .0966.
Re: Making a Piston Stop out of a Spark Plug #206422
07/16/07 3:33 pm
07/16/07 3:33 pm
georgia
trumpetloon Offline
trumpetloon  Offline
georgia
Thanks for the lesson for the mathematically challenged (me)!!!!
1974 TR5T
Re: Making a Piston Stop out of a Spark Plug #206423
07/16/07 3:46 pm
07/16/07 3:46 pm
Anonymous
Unregistered
Anonymous
Unregistered
Now if we had good data on spark plug angles for some common engines, I could do up a chart for the board of indicator motion per .001" by brand and model...
Moderated by  Allan Gill
