east end rider
east end rider
long Island NY
26 registered members (Bikeosaurus), 219 guests, and 450 spiders.
10257 Registered Users
Stuart 77
Lannis 60
TBolt72 46
609,565 mail-order LSR
Topics67,125
Posts651,431
Members10,257
tls front brake #199117
11/22/07 8:31 pm
11/22/07 8:31 pm
kent uk
chris F Offline OP
chris F  Offline OP
kent uk
Hi again everyone i have fitted a 1969 BSA 8'' tls vertical pull front
wheel and brake to my clubman style 1961 A10 i have also purchased the
correct cable for the brake the problem being that the inner cable does
not reach the lever on the plate. There is an adjuster in the cable and
there is also an adjuster on handlebar control i have tried removing
the adjuster from the control but then the cable just pulls through i
would like to know if there is an adapter or part that i can buy that
will replace the adjuster and also stop the outer cable pulling through
as i am sure losing one adjuster would make the difference did the
bikes of this year not have adjusters on the control lever many thanks
frustrated Chris
Re: tls front brake #199118
11/22/07 10:31 pm
11/22/07 10:31 pm
I had a similar problem when using the TLS on my early A65. I hooked it up with the mid cable adjustment partway out then turned a small stepped brass fitting to sort out the lever end.
Re: tls front brake #199119
11/25/07 10:02 pm
11/25/07 10:02 pm
hampshire, england
t120mike Offline
t120mike  Offline
hampshire, england
If you want a cable specially made, try
J J Cables (J & P Engineering)
Hillfields Farm
Lighthorne
Warks
CV35 0BQ
01926 651470
They were very helpful to me and showed me the correct solder and how to solder on nipples securely. Since then I have always ordered brake and clutch cables without in-line adjusters and have finished them myself, relying on the lever adjusters only.
mike
Member #: 147
1960 T120 Bonneville
1999 H*%^a VFR 800 FI
V4 Triton Project (still keeping me sane (Ha-Ha!))
