bitsa110
bitsa110
Far Northern California
207 registered members (57nortonmodel77), 2,344 guests, and 679 spiders.
myshootingstar68, Caddy, Spitfiregary, Ashley, HerbertG
10073 Registered Users
koan58 82
NickL 81
Stuart 64
503,301 mail-order LSR
Topics66,021
Posts638,985
Members10,073
lucas 6v/60watt E3LM-MO dynamo #19660
01/14/07 11:20 pm
01/14/07 11:20 pm
The Netherlands
Dick1969 Offline OP
Dick1969  Offline OP
The Netherlands
Is there someone that can help me with a diagram, drawing or picture of the wiring of the Lucas 6v/60watt E3LM-MO dynamo.
If it maters at all witch coil side has to be connected to F and to earth. And witch brush needs to be connected to earth and to C.
thanks
1954 BSA B31 plunger
1989 GL1500 Aspengate
Re: lucas 6v/60watt E3LM-MO dynamo #19661
01/15/07 1:25 am
01/15/07 1:25 am
Ohio, U.S.A.
GOLD S-TARvin R.I.P. Offline
Ohio, U.S.A.
Two really good sites for anyone using a dynamo.
"where's that dynamo coming from?"
Check em out:
credit to pinman
lucas manual
2c
GOLD S-TARvin
OVBSAOC # 1625
1960 DBD34 Gold Star
1956 DB34 Gold Star
1969 Bonneville
several basket case Triumphs
Re: lucas 6v/60watt E3LM-MO dynamo #19662
01/15/07 1:36 am
01/15/07 1:36 am
John Healy Online content
John Healy  Online Content
If my memory serves me:
The two field wires crossed as they emerged from the field. One has a yellow band around it (it will be placed through the right hand hole in the end plate - the other doesn't and is fed through the left hand hole in the end plate - as viewed fron the brusg end with the armature at the top.
Looking down at the generator from the brush end, Armature toward the top, the filed wire with the yellow band emerges through the hole in the end housing on the right side and looped over to ground. It was joined at the same ground point by the left brush wire. The right brush wire went to the connector marked "D" and the field wire emerging from the left hole in the end housing went to the "F" connector.
Now this is the wiring for a positive ground Triumph E3L, but I think it is the same for the BSA.
Re: lucas 6v/60watt E3LM-MO dynamo #19663
01/15/07 1:59 am
01/15/07 1:59 am
North Georgia, USA
RF Whatley Online content
RF Whatley  Online Content
North Georgia, USA
John, all you said is correct. Would only like to add, I find it easier to remember that field wiring is dependent on the desired direction of rotation. So it would depend on the model of bike as to which direction the dynamo is turned in service. Using this you can fit any dynamo to any bike (if they mechanically fit) and wire to suit.
Then you can bench test by connecting D & F to neg 6V, and the body to pos 6V and see if the rotation is correct.
That's much easier on the old grey cells, don't you think?
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: lucas 6v/60watt E3LM-MO dynamo #19664
01/23/07 9:50 pm
01/23/07 9:50 pm
Asheville, North Carolina
ca7a Offline
ca7a  Offline
Matters not which field wire goes to D or F as long as you "flash"
(polarize) the field after connecting them. THEN you need to mark one of them for the next time you disconnect (or reflash if you didn't).
As for "C ", I guess you meant D.
Page Time: 0.824s Queries: 14 (0.052s) Memory: 1.0173 MB (Peak: 1.1660 MB) Zlib disabled. Server Time: 2018-02-21 13:07:35 UTC
