porge
porge
Tasmania, Australia
191 registered members (1xfatboy), 1,761 guests, and 601 spiders.
Lannis 144
kommando 105
476,772 mail-order LSR
Topics65,721
Posts635,225
Grimeca 4LS #196190
05/26/05 6:42 am
05/26/05 6:42 am
Oslo Norway
Per B Offline OP
Per B  Offline OP
Oslo Norway
I have a 4 LS Grimeca 230mm hub with the original Grimeca linings inside on my BSA B33/Goldstar hybride, i am not overly impressed by the performance of this brakes, the brakes are ok when its warmed up,(wich is good for racing) but from cold its not much better than a good bsa 8" hub, (not very good for road use) The setup includes a Magura double pull handle, very solid brake cables. The adjustment is spot on.
Any advise for better performance from cold?
Best regards
Per
best regards
Per
Goldi Clubmans
Goldi Scrambler
Rob North R3
OIF A65
Re: Grimeca 4LS #196191
05/26/05 10:28 am
05/26/05 10:28 am
Altoona, Florida
Mike Carter R.I.P. Offline
Altoona, Florida
I would have modern linings put on the existing shoes... I will trade you my TLS for your 4LS straight up laugh
Cheers man,
Mike Carter
Re: Grimeca 4LS #196192
05/26/05 8:18 pm
05/26/05 8:18 pm
Indianapolis, IN
Sonic Twin Offline
Sonic Twin  Offline
Indianapolis, IN
You may very well have full race linings, like the Ferodo "green" linings, AM4 I believe. These are totally useless when cold, but work great when hot. If this is the case, you will need to replace the linings. Vintage Brake in California USA does very nice work, not cheap, but right.
If, however, the linings / shoes are not contacting the drum with good surface area contact, that is not the lining material.
Re: Grimeca 4LS #196193
06/01/05 7:27 am
06/01/05 7:27 am
Oslo Norway
Per B Offline OP
Per B  Offline OP
Oslo Norway
Thanks folks,
The Grimeca brake is brand new, so far done about 2000 km, I belive this should be enough for the lining to bed in correctely, I will have a look at this tonight.
I am also suspecting that the linings are some sort of racing stuff, and hopefully a new set of linings will solve this small problem, but new linings will have to wait untill winter as the driving season here in Norway are short as it is.
As an intermediate aktion I will try to increase the leverage as Panic are describing.
Per
best regards
Per
Goldi Clubmans
Goldi Scrambler
Rob North R3
OIF A65
Re: Grimeca 4LS #196194
06/02/05 2:13 am
06/02/05 2:13 am
Ron - in California R.I.P. Offline
Ah er.. that brake should work great, hot or cold... I have one on my Goldie... it will out stop darn near anything..! When my brake was new, it took some wear in to get the shoes arced to the drum (guess the factory does not do it). Once it broke in, it was almost too good..! I went and lightly chamferred the leading edges, as it was tooo grabby at low speeds. (it almost made me fall over more than once at 5 mph).
Also the stock return springs are way too stiff, contact Vintage brake, and he has some nice springs..!
You should NOT need to extend the leverage ratio... worst case, you need new linings.
Re: Grimeca 4LS #196195
06/02/05 10:21 am
06/02/05 10:21 am
Oslo Norway
Per B Offline OP
Per B  Offline OP
Oslo Norway
Ron
Do you know if the lining in your Grimeca are the standard one as supplied by Grimeca or are they changed?
I am using a Magura doble pull lever as supplid from British spares http://www.britishspares.com/index.htm page 21 in their catalouge, may be this lever are giving me less leverage than the lever you are using?
Per
best regards
Per
Goldi Clubmans
Goldi Scrambler
Rob North R3
OIF A65
Re: Grimeca 4LS #196196
06/11/05 4:20 pm
06/11/05 4:20 pm
My brake was N.O.S. that I got from a pal that bought it and never used it. I am using a Suzuki twin cable brake lever set up (has a nice brake lite switch in it) that I got from an outfit that also sells new Grimeca's and other nice bits...
http://www.ajsmotorcycles.co.uk/docs/grimeca1/Docs/grimeca.htm
Hope this helps..
Ron
Re: Grimeca 4LS #196197
06/11/05 5:31 pm
06/11/05 5:31 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
It was a nice sunny day in Wales, not much traffic and the roads were fast and swoopy winding through the huge bright green hills of this near idylic countryside. Nice. We're headed down into Wales for a visit at SRM.
Yuppers our little Goldies were having some fun in The Swoopies! The three of us are cranking along in the 75 - 90 per zone. Ain't no stinkin speed cameras out there. Ron on his hot rod GS in the lead, Steve next and I'm pulling up the rear.
We round a curve in the trees and yikers, our narrow lane carved out of the hillside is baricaded closed and traffic coming in the opposite lane!
No warning signs, flagmen or nothing ... Ron's Grimeca whoas him up nicely, Steve's got his rear wheel locked and he's sliding due to his crappy front brake and he ends up stopped alongside Ron.
Holy Cats ... "Vintage Brake built 190 mm don't fail me now"!, as I slip between the two of them, with a couple of feet short of "will it fly?", to spare. ooohhh ...
Yup we still talk about it over beers every once in awhile... Coulda, woulda, been a bad one.
Fix those crappy brakes, you may only "need", them once you know ... And the often heard, "I don't ride fast", is a very poor and perhaps deadly excuse you know.
Have I told you about staying at the Black Lion pub that night, the friendly people, the good food and beer and the ... ah geeze, fun stuff that ya just gotta live at least once. Do it.
dave - NV
envious of pal Ron doing it again this summer. Lucky him.
dave - NV
Re: Grimeca 4LS #196198
06/26/05 7:19 am
06/26/05 7:19 am
Christchurch New Zealand
Lew Graham Offline
Lew Graham  Offline
A while ago I had some BSA front brakes ground true. As the machinist had to take out a section of the bed of the lathe so he could fit the whole wheel in, I gave him a couple of 4LS brakes to do as well. One was a brand new (purchased 1986) 230mm Grimeca, spoked into Borrani alloy rim, but it had not yet been on the road.
He reported that one side was perfectly true, but the other side was 8 thou high in one spot. I don't imagine that spoking the drum into a rim could easily produce a single high spot, so maybe it came from the factory like that. It sure wouldn't have helped with the braking!
Lew G.
