MikesClassics
MikesClassics
Queensland, Australia
208 registered members (68 royalstar tony), 1,775 guests, and 586 spiders.
10032 Registered Users
Lannis 144
kommando 102
476,308 mail-order LSR
Topics65,711
Posts635,140
Members10,032
Page 2 of 2 1 2
Re: Anti-wet sumping valve.... #15727
09/29/06 3:04 am
09/29/06 3:04 am
43.34 (4320') | -79.81 (-794...
Gunk Offline
Gunk  Offline
Forgive me if I'm wrong but it seems to me that all this conjecture is missing one vital point.
The oil pump is above the lowest point in the line.
The oil lines run under the engine then the galleries to the oil pump run up from there.
The natural position of the ASV will be somewhere below the oil pump as a result of oil line routing, meaning the oil, to drain back out of the pump, would have to flow uphill.
Unless the laws of gravity are forgiven for oil in a BSA engine, the oil is trapped in a loop between the pump and the ASV, like filling the straw with oil and blocking the bottom end.
"he who laughs fast, laughs first"~Gunk
Re: Anti-wet sumping valve.... #15728
09/29/06 11:39 am
09/29/06 11:39 am
gavin eisler Online content
gavin eisler  Online Content
Your right Gunk ,I was kind of putting a worst case scenario. With the BSA set up and the imaginary ASV closing the feed line and removing the head of oil there is only a tiny head to push oil out of a leaky pump.
Assuming a tight ASV and lines of course.
Pod
Re: Anti-wet sumping valve.... #15729
09/29/06 11:42 am
09/29/06 11:42 am
hamilton on. can.
H
highway Offline
highway  Offline
H
hamilton on. can.
I have installed at least 100 awsv,s and have had only one problem. When the oil pipe junction was installed an o'ring was displaced while bolting in place. the line was primed, the bike started, oil pressure light went out, all ok, set timing.
Next morning I was pleased ther was not one drop of oil under the bike. Restarted, oil light stays on, check oil returning to tank, none, swore, shut off engine. Checked hose clamps, tight, no oil leaks, swore again. ( even good mechanics have bad days).
Took off junction and found the displaced o'ring. The slight gap allowed air to be sucked into the feed pipe which caused the loss of prime and prevented the awsv. from opening.
Question? why did the o,ring problem not cause an oil leak? Answer. No gravity. Without a awsv oil is pushed through the pump by gravity pushing on the oil in the tank. The anti wet sump valve spring and ball in the line counters this force of gravity, so no oil will leak from the line or FROM THE PUMP.
These valves must be fitted with care that no air leaks are present. A lot of my custmers think the valve is the best mod they have done to their bike. I have not had a single engine failure problem on an engine with a valve fitted and do not expect one. I am a little leary of fitting the hidden, inside the oil line valve, and fit the larger model.
When a bike has sat for a while, it should not be rushed into service, check all cable opperation, oil level, tire pressure, clutch plates stuck? Whadda think? you driving a car?
Re: Anti-wet sumping valve.... #15730
09/29/06 1:48 pm
09/29/06 1:48 pm
Gunk Offline
Gunk  Offline
Welcome to the new millenium Highway.
Everybody gets so much information all day long that they lose their common sense. ~Gertrude Stein
Re: Anti-wet sumping valve.... #15731
09/29/06 1:51 pm
09/29/06 1:51 pm
Mark Parker Online content
Mark Parker  Online Content
This photo shows how the pumps can leak at the join, this is about 40 seconds after wipeing the pump body clean, I would expect oil would spray out there when running. This type of leaking happens before the check valve under the pump, so can wet sump the engine after a few days.
Re: Anti-wet sumping valve.... #15732
09/29/06 2:41 pm
09/29/06 2:41 pm
oldbeefer Offline
oldbeefer  Offline
Lannis talks about hanging 2 feet of hose full of oil. The differnce with the bikes is that the oilways are quite narrow and air would be less likely to bubble through the fairly tortuous route back to the valve. I've used a tap on my ES2 for ages - never had a problem (hang the keys on it when it's at home as a reminder to turn it on) - after all, when you do an oil change, do you wait an hour for the oil to prime the pump, or do you kick into life straight away?
Re: Anti-wet sumping valve.... #15733
09/29/06 5:11 pm
09/29/06 5:11 pm
Lannis Online content OP
Lannis  Online Content OP
oldbeefer -
When I do an oil change, I put the bike in gear on the centerstand and turn the back wheel until oil is coming out of the return pipe to the oil tank.....
At the VBMC rally a couple years ago, a guy pulled up on a Vincent twin, parked it and snapped a pink elastic lacy garter onto the kickstart pedal. I asked him what that was all about, and he said he always looped the pink garter from his oil tap to his kickstart to remind him to turn it on before he started it.....
We're approaching the tipping point ... where those who vote for a living will outnumber those who work for a living .....
Re: Anti-wet sumping valve.... #15734
09/29/06 7:05 pm
09/29/06 7:05 pm
Gunk Offline
Gunk  Offline
So what you need is a pink lacy garter?
Re: Anti-wet sumping valve.... #15735
09/29/06 10:30 pm
09/29/06 10:30 pm
Flint,Mich
norbsa48503 Offline
norbsa48503  Offline
Flint,Mich
From what I have seen it's not the turn on part that's the problem. It's when you pull up on a distraction and forget to turn it off. Then upon takeing off turn it "on" and really turn it off and ride. I have seen two bikes get blown this way.Riding up on a big group of fine bikes can be distracting.
norbsa
1960 TR6
1963 Super Rocket
1965 650 Star
1966 441
1968 Thunderbolt
1969 Twinkle 250
1972 Fastback
1974 Roadster
1970 S.S
Way too many BSA's not named
http://decentcycles.com
Re: Anti-wet sumping valve.... #15736
04/07/08 4:19 pm
04/07/08 4:19 pm
Surrey, Olde England
ChazzyB Offline
ChazzyB  Offline
I wonder if that's where my B25's problem is. I've replaced the anti-drain spring and ball, seating it by giving the ball a good tap. It still drains enough over two or three days to reach the level of the gearchange shaft - from where the oil then drips...
Re: Anti-wet sumping valve.... #15737
04/07/08 5:07 pm
04/07/08 5:07 pm
Also on a B25 (or any Unit Single) if your pressure release valve leaks as it before the non-return valve then the oil leaks to the sump, plus you don't get full oil pressure when running.
Re: Anti-wet sumping valve.... #15738
04/07/08 6:03 pm
04/07/08 6:03 pm
ChazzyB Offline
ChazzyB  Offline
I *think* my oil pressure is fine. When cold, the light will go out kicking it over. Also, if the engine stops when cold, it can take a while (read minutes) for the oil light to come on again. Hmm, I guess if the pressure release valve is before the non-return valve, the non-return valve is stopping the pressure dropping but the pressure release could still be leaking from the tank. What sort of oil pressure should be expected when the engine's warm and running?
Re: Anti-wet sumping valve.... #15739
04/07/08 6:25 pm
04/07/08 6:25 pm
Rich B Online happy
Rich B  Online Happy
Check to see if the pump is leaking between the body and case. I have had some issues with unit singles not sealing at this joint. IME, it has been crap gaskets. The ones from Britgaskets seem to work the best.
Re: Anti-wet sumping valve.... #15740
04/07/08 7:22 pm
04/07/08 7:22 pm
The oil pressure switch is set to a few psi, a few psi is well below whats needed which is why the light goes off with a kick on a cold engine and doesn't go on until the pressure is released after stopping. As the pressure release is set for 50 or 75 psi depending on the year this is the pressure required with a handful of throttle.
Page 2 of 2 1 2
