29 registered members (Alan_nc), 209 guests, and 459 spiders.
10257 Registered Users
Stuart 77
Lannis 56
610,291 mail-order LSR
Topics67,138
Posts651,518
Members10,257
Carb blowback #154595
06/06/08 6:15 pm
06/06/08 6:15 pm
Warrington, Cheshire, UK
TriVin Offline OP
TriVin  Offline OP
Hi
I've just got my Comet together after fitting a new piston. It started first kick but it appears to be blowing back out of the carb. What should I check first do you think?
I checked the timing marks carefully, set the timing and electronic ignition as per the instructions, checked valve clearances.
I'm stumped
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Support your #1 Vincent Forum
Vincent Motorcycles on e-Bay UK, Vincent motorcycles on e-Bay North America
Re: Carb blowback #154596
06/07/08 3:42 am
06/07/08 3:42 am
australia
douglas Offline
douglas  Offline
australia
I'm afraid it sounds like valve timing will be out by a tooth or too. Oh well!! off with the timing cover. No, i'm not sadistic!! Douglas
Re: Carb blowback #154598
06/12/08 11:54 am
06/12/08 11:54 am
Does it blow regularly at half engine speed or occasionally sneeze?
Sneezing is usually a weak pilot mixture or slide or inlet air leak.
Re: Carb blowback #154599
06/13/08 3:37 pm
06/13/08 3:37 pm
TriVin Offline OP
TriVin  Offline OP
Hi Guys
Things have moved on a lot since last week.
Before having a chance to do anything with the timing my mate and I went off to York last Saturday for the Vincent Rally where we were advised to set the cams 'on the rock' at TDC just to get it close. Then my mate found an old article in MPH from 1968 which stated that the diagram for the Comet valve timing shown in Paul Richardson's book, which I had been using as my guide, was in fact 50 degress out! So we were not even near to correct. In fact I'm surprised it even started.
Anyway after doing as advised it started and ran pretty good today. However, I would like to now fine tune it using a DTI as you have suggested here. Could you explain the procedure for me or direct me to somewhere where it is written down.
First I must get a DTI. Should I get the plunger type or the finger type? Am I going to need to get a magnetic base or what.
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
