Panhead EL
Panhead EL
Virginia
37 registered members (79T140E), 255 guests, and 438 spiders.
LandoLando, MikeA, Jay Gilling, scratchedtank, Magic Monkey
10253 Registered Users
Stuart 72
Lannis 67
NickL 48
606,779 mail-order LSR
Topics67,086
Posts650,981
Members10,253
1950 Bullet cam pinion #152978
10/22/07 10:20 am
10/22/07 10:20 am
huntsville ont. canada
obsolete Offline OP
obsolete  Offline OP
I have been gathering pieces a 1950 Bullet for quite some time . Last winter I began to rough assemble the parts onto the frame . I used a bare motor and tranny to sit in the frame to keep things together . Decided on the weekend to disassemble the original motor to get it cleaned up and ready to install once the frame has been painted . I cannot get the oil pump worm loose . There is no nut on back of worm to get a wrwnch on . I need the worm off so as to get the pinion gear off , so as to remove the crank assembly . I checked out a couple parts books . The 1949 one shows the timing shaft as a one piece unit . The 1961 shows as a removeable worm and pinion .
This is my first Bullet teardown . Is there a special trick to this job . Thanks John Ruff
1959 Constellation
1968 MK 1A Interceptor
1960 Pashley
1958 Crusader
1962 Super Five
1967 Continental GT
1959 Big Head Fury/Westerner
195? 500 Bullet Woodsman/Westerner ? #6655
1950 Model RE
1946 Model RE
1950 Model G
1955 250 Clipper
Re: 1950 Bullet cam pinion #152979
10/22/07 11:37 pm
10/22/07 11:37 pm
San Antonio, Texas
rotorwrench Offline
rotorwrench  Offline
San Antonio, Texas
I've heard that the 50 through 52 G models had a one piece worm/pinion but I'm stumped on how it goes on and comes off. Hitchcocks has one of those cranks for sale in there used parts section but the picture is too small to tell for sure. I hope someone else that frequents this site can tell you, or you might have to e-mail Hitchcock's for the answer. My guess is that it is pressed on with a key but a guess like that can cost you if not correct.
Kerby
Re: 1950 Bullet cam pinion #152980
10/23/07 10:07 am
10/23/07 10:07 am
obsolete Offline OP
obsolete  Offline OP
Kerby Thanks for the info . So I wonder how everything was put together in the first place . Can not get at the pin from the crank side , can not get the pinion gear thru the bushing . It`s a bit of a stumper . It has to be either pressed on or threaded (left hand) I will try a couple e-mails . John
1959 Constellation
1960 Pashley
1958 Crusader
1962 Super Five
1967 Continental GT
1950 Model RE
1946 Model RE
1950 Model G
1955 250 Clipper
