Neal J
Neal J
Boston, MA
38 registered members (Adam M.), 264 guests, and 417 spiders.
Begbie, Andrew Fallo, Zack Banks, 1966g10, Tacet
10417 Registered Users
btour 84
Rohan 82
Triless 80
reverb 76
709,428 mail-order LSR
Topics68,297
Posts664,918
Members10,417
+ to earth? #15086
09/06/06 8:16 pm
09/06/06 8:16 pm
Oslo
Rocker Offline OP
Rocker  Offline OP
Oslo
My newly purchased 1940 M21 did not have light`s, until today. When I had a look in the battery case I found a wire that had come loose. I fixed it and after a little while I had lights !!
But one thing I don`tunderstand is that the bike had - to earth, not + to earth like I`m used. Is the battery faultly connected and if so, is it still possible that the lights could shine bright ?
Or should M21 have negative earth like mine might have?
1940 M21
1960 Golden Flash
"Everything takes longer time than it takes"
Re: + to earth? #15087
09/06/06 8:37 pm
09/06/06 8:37 pm
North East England
beezageezauk Offline
North East England
BSA Service Sheet number 808 shows the wiring diagram for the A,B & M group models. My copy has the date October 1948 and it is for a negative (-)earth system. These machines changed to a positive (+)earth system some time after 1948. I am sure that somebody can tell us the date of the changeover.
As your bike is a 1940 model, the negative earth system is correct.
Beezageezauk.
Re: + to earth? #15088
09/07/06 12:22 pm
09/07/06 12:22 pm
Alexandria, Virginia; U.S.A.
Mark Taylor Offline
Mark Taylor  Offline
Interesting... my recently purchased 1965 A50 also had the (-) side of the battery to ground. All of the literature I have suggests that it should be (+) to earth (BTW, it is a 6V battery). Question: if one of the previous owners got it backwards, what problems may I be facing?
Mark
2004 Triumph Daytona
1965 BSA
Pre-unit Triton
Re: + to earth? #15089
09/07/06 7:13 pm
09/07/06 7:13 pm
North East England
North East England
The BSA Twin Restoration book states that BSA started using positive earth systems in 1951. I take this to mean for all models and not just on the twin cylinder machines.
It doesn't state in it that BSA reverted back to the negative earth system. However, it does mention that the the 12volt system was standardised on the twin cylinder models in 1966. On saying this, some machines had 12volt systems prior to 1966, but not all of them.
Your A50 is probably correct with a 6volt system but it appears that it should have a positive earth.
Do we have any electrically orientated guys here who can advise and maybe comment on my findings?
Beezageezauk.
Re: + to earth? #15090
09/07/06 7:39 pm
09/07/06 7:39 pm
Winston, Oregon
beezerbill Offline
beezerbill  Offline
Winston, Oregon
One thing to remember BSA has a pos grd for some kind of safey thing a million years ago..anyway if your battery is completely dead it is very possible to charge it up backwards so what you end up with from the battery < is a negitive which is the postive..and a pos. which is neg.I just know this is got to helpful..Beezerbill
Re: + to earth? #15091
09/07/06 8:40 pm
09/07/06 8:40 pm
Mark Taylor Offline
Mark Taylor  Offline
beezageezauk, I agree. Everything I've read suggests that a 1965 A50 should be a 6V system with a positive earth.
beezerbill, I've heard the same thing... if the battery is completely dead, it's possible that the alternator could reverse the battery's polarity.
I think I'll see if the battery will hold a charge and then re-install it with a positive ground and see what happens... tahnks for your help!
Mark
1965 BSA
Pre-unit Triton
