Marty
Marty
Dorset, England
48 registered members (69BSATONY), 268 guests, and 65 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 97
reverb 83
Mori55 83
Triless 82
Stuart 82
DavidP 74
btour 66
690,301 mail-order LSR
Topics68,041
Posts662,035
Members10,387
78 T140 Too much oil #147387
08/23/08 7:21 pm
08/23/08 7:21 pm
Phoenix Arizona
PY66 Offline OP
PY66  Offline OP
Phoenix Arizona
Sorted seized camplate plunger reassembled bike charged battery checked oil level looked good give it fresh plugs & gas fired it up Great.
I decided to make sure the oil was flowing so I removed filler & mount edna erupted. So I drained oil cleaned strainer in frame reassemble with new gaskets filled oil level to marker on dip stick fired her up run down the street to check gears all working great decided to check oil for oil flowing did exactly the same again
Oil everywhere
Any ideas where my problem is ?
Peter
1959 Francis Barnett 250cc Cruiser
1973 Triumph 650cc Bonneville
1978 Triumph 750cc Bonneville
1971 Norton 750cc Commando (We Think)
Re: 78 T140 Too much oil #147388
08/23/08 7:43 pm
08/23/08 7:43 pm
Tulsa, Oklahoma, USA
Steve in Tulsa Offline
When you say Mount Etna are you saying oil
1) overflowed or
2) was pumping out under pressure?
Did you remove the oil lines from the pump? You have them reversed
Steve in Tulsa
Re: 78 T140 Too much oil #147389
08/23/08 7:44 pm
08/23/08 7:44 pm
JubeePrince Offline
JubeePrince  Offline
clogged oil vent pipe?
clogged rocker feed pipe?
[edited to add to Steve in Tulsa's thoughts]
Oil junction pipes for unit twins:
Front = Feed
Rear = Return
Re: 78 T140 Too much oil #147390
08/23/08 7:48 pm
08/23/08 7:48 pm
Prince, I thought about that but the oil flow to the rockers is minimal. That's why I asked if it's pumping or just over flowed. He was under the bike so I wondered if he pulled the oil feed and return lines.
PY, did the oil/ignition light go out or stay on or did you notice?
Steve in Tulsa
Re: 78 T140 Too much oil #147391
08/23/08 8:27 pm
08/23/08 8:27 pm
Noblesville, IN
Jack Adams Offline
Jack Adams  Offline
Noblesville, IN
PY, If you filled the frame up to the full mark with no regard for what there was in the crankcase, once the motor is running I would expect an overflow situation. Jack
Re: 78 T140 Too much oil #147392
08/23/08 8:50 pm
08/23/08 8:50 pm
Phoenix Arizona
PY66 Offline OP
PY66  Offline OP
Phoenix Arizona
Overflowed very fast as if too much oil but I did not drain the crankcase like Jack said.Should I drain the crankcase & see how much oil I get out ? oil light goes out as soon as I kickit over but the light does come back on
Re: 78 T140 Too much oil #147393
08/23/08 9:07 pm
08/23/08 9:07 pm
PY said:
oil light goes out as soon as I kick it over but the light does come back on
But are we talking running engine? If you kick it and the light goes out then the pump is filling the relief valve. But this just needs to be residual oil in the line.
BUT, IF WHEN RUNNING, the light comes back on, you have no oil pressure or a bad relief valve.You have to determine which it is BEFORE you ride any more. The best way is with a pressure gauge.
But you did not answer the question: Did you remove the oil feed and return lines to work on the bike? If you did the feed line from the OIF goes to right side feed tube under the timing cover. The return is the left.
If the crank is full then it is wet sumping - another issue.
The poor mans test:
1) check the line placement and
2) if correct, drain some oil from the OIF, start the bike and see if it's pumping back from the pump. Just don't run it long. You will know in a few seconds.
Let us know
Steve in Tulsa
Re: 78 T140 Too much oil #147394
08/23/08 10:48 pm
08/23/08 10:48 pm
Phoenix Arizona
PY66 Offline OP
PY66  Offline OP
Phoenix Arizona
Sorry no I did not remove oil feed lines I will hook a pressure gauge up & report back
Re: 78 T140 Too much oil #147395
08/23/08 11:18 pm
08/23/08 11:18 pm
Connect the pressure gauge in place of the relief valve.
Let us know.
Steve in Tulsa
Re: 78 T140 Too much oil #147396
08/24/08 12:34 am
08/24/08 12:34 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Originally posted by PY66:
Overflowed very fast as if too much oil but I did not drain the crankcase...
KY66 -
When you say overflowed, we assume you are talking about engine oil and I assume you are talking about the engine oil tank which is accessed from under the seat. Meaning: you removed the cap to the tank and the oil flowed out the fill cap.
If this is the case then nothing is wrong. No measurements are needed. Your bike is working correctly.
The only issue is that you've over-filled the engine oil, and this most probably by over-filling the primary case. The primary and engine oil are shared, so that when you over fill the primary, the oil pump evacuates the excess back to the tank like it should. When you take off the oil tank inspection cap, then Surprise! there it is.
If this is the case, then you really should measure more carefully as per your manuals.
bigt
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: 78 T140 Too much oil #147397
08/24/08 12:36 am
08/24/08 12:36 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
This I gotta see.
I think he means in place of the oil pressure sender, not the OPRV.
laughing
RF Whatley
Cornelia, GA
Re: 78 T140 Too much oil #147398
08/24/08 3:09 am
08/24/08 3:09 am
RF, uh...yes, that's what I meant. :rolleyes:
Steve in Tulsa
Re: 78 T140 Too much oil #147399
08/24/08 3:23 am
08/24/08 3:23 am
Phoenix Arizona
PY66 Offline OP
PY66  Offline OP
Phoenix Arizona
For once I new what you meant & where to install it will let you guys know tomorrow how it works out
Re: 78 T140 Too much oil #147400
08/24/08 3:28 am
08/24/08 3:28 am
darn, just once? eek
laughing
Steve in Tulsa
Re: 78 T140 Too much oil #147401
08/24/08 10:12 am
08/24/08 10:12 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
I was going to hand you s#it about that but Richard beat me to it frown laugh
All the best Engineering systems have multiple review and this is one of the best bigt
1969 TR6R
Re: 78 T140 Too much oil #147402
08/24/08 6:03 pm
08/24/08 6:03 pm
Phoenix Arizona
PY66 Offline OP
PY66  Offline OP
Phoenix Arizona
Installed pressure gauge fired it up very little low oil pressure lucky if I get a reading on tickover if I rev to 3K maybe get 25psi
Bad oil pump ? or dirty maybe ?
Re: 78 T140 Too much oil #147403
08/24/08 7:21 pm
08/24/08 7:21 pm
Ouch! I have 70 PSI at 3000 and 15-20 PSI idle warm.
1) Bad pump
2) bad crank seal in timing cover
3) bad ( internally) oil line from OIF to pump
4) clogged oil screen filter in reservoir
5) garbage in feed side of pump
Good luck, don't ride it.
OK , RF and Tiger, tell him what I mean laughing
Steve in Tulsa
Re: 78 T140 Too much oil #147404
08/24/08 8:26 pm
08/24/08 8:26 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Steve in Tulsa:
<strong> Ouch! I have 70 PSI at 3000 and 15-20 PSI idle warm. OK , RF and Tiger, tell him what I mean bigt
RF Whatley
Cornelia, GA
Re: 78 T140 Too much oil #147405
08/24/08 9:05 pm
08/24/08 9:05 pm
What Steve was really trying to say was don't ride the bike, don't start the bike, don't even sit on it until it's fixed. [Laughing]
Yep, that's it. Now why didn't I say that? laughing
Steve in Tulsa
Re: 78 T140 Too much oil #147406
08/24/08 9:42 pm
08/24/08 9:42 pm
Tulsa
Kelly in Tulsa Offline
Tulsa
You guys are scaring me here! Steve can you drop by the house sometime...and bring your gauges? I got beer!
Re: 78 T140 Too much oil #147407
08/24/08 10:30 pm
08/24/08 10:30 pm
Kelly, Sure. I'll email you.
Steve in Tulsa
Re: 78 T140 Too much oil #147408
08/25/08 1:09 am
08/25/08 1:09 am
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Steve -
Can you drop by the house sometime... forget the gauges, bring the beer.
RF Whatley
Cornelia, GA
Re: 78 T140 Too much oil #147409
08/25/08 1:56 am
08/25/08 1:56 am
Phoenix Arizona
PY66 Offline OP
PY66  Offline OP
Phoenix Arizona
Hell if you all lived nearer forget it all I have the bike most tools & a fridge full of cold beer
Thanks I will follow your recommendations step by step
Re: 78 T140 Too much oil #147410
08/25/08 6:15 am
08/25/08 6:15 am
Kent UK
Blapper Offline
Blapper  Offline
Kent UK
Hey PY, don't forget to report back. bigt
Blapper redwine
Re: 78 T140 Too much oil #147411
08/25/08 5:10 pm
08/25/08 5:10 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
Inquiring minds want to know.
RF Whatley
Cornelia, GA
