blackhallr
blackhallr
north east england
40 registered members (Bart223), 238 guests, and 418 spiders.
FireGuyKC, spuggy, Vinny Cotroneo, KeithM, Mridul Handa
10285 Registered Users
Stuart 97
Lannis 62
634,097 mail-order LSR
Topics67,352
Posts653,918
Members10,285
Oil leak from forks 1970 TR6 #127023
10/25/07 1:00 pm
10/25/07 1:00 pm
V
victortrry Offline OP
V
I am in the process of refettling my 1970 TR6, I have used ATF oil in the front forks, My question is, is this oil to light it seems to be leaking from the bottom of the stanchion and not from the drain plug. The A65 also has this problem. Any suggestions
Victor
1970 TR^
1970 A65 Firebird
1981 XS650 Yamaha
Re: Oil leak from forks 1970 TR6 #127024
10/25/07 2:10 pm
10/25/07 2:10 pm
, Lower -Lower michigan
Bob S Offline
Bob S  Offline
in the bottom of the fork legs, there is a tall fitting 3" maybe, can`t think of the name of it. i just rebuilt 2mos ago,my 70 bonne forks, filled them up. came out the next morning one leg is leaking, Theres a small nut in the dead center, of the bottom of the fork leg. mine wasn`t tightened up enough. tightened it up, no leaks
ps. you have to take wheel, and bottom axel cap off to see it, and it takes a super thin wall socket to tighten it up. plus you have to take the bottom, leg off [easier] and use a long and a deep well, extension to hold the tall bolt piece, thing down in the tube. smile
hth bob s smile
Bob S
Street Rods, Kustom Kars,A BSA,Cushmans,H.Shadow ACE, Now a 2004 triumph america . "More than enough!!!!
Re: Oil leak from forks 1970 TR6 #127025
10/25/07 2:27 pm
10/25/07 2:27 pm
Dillsburg, PA - USA
mattstriumph Offline
Dillsburg, PA - USA
I beleive there is an extension on the drain plug that holds the restrictor, which is the inner nut nut in place.
1965 Triumph T100SR
Re: Oil leak from forks 1970 TR6 #127026
10/25/07 4:28 pm
10/25/07 4:28 pm
dave jones Offline
dave jones  Offline
20 or 30 oil is best on the external spring forks. Must be leaking from the bolt hidden underneath, as mentioned.
dave
Re: Oil leak from forks 1970 TR6 #127027
10/26/07 12:04 am
10/26/07 12:04 am
australia
6
649 Offline
649  Offline
australia
ATF is much too light..20 is recommended but synthetic engine oil is good...experiment with weight, but ATF is about as useless as water in these
1970 tr6r dryframe
Re: Oil leak from forks 1970 TR6 #127028
10/26/07 3:23 am
10/26/07 3:23 am
hamden, ct.
hacksaw Offline
hacksaw  Offline
hamden, ct.
i didnt fair well at all with atf. to weak as these guys attest.
