Mike Baker
Mike Baker
Asheville, NC
44 registered members (Adam M.), 238 guests, and 54 spiders.
10381 Registered Users
Mori55 98
NickL 91
Stuart 86
DavidP 78
Triless 71
reverb 70
Rohan 64
688,488 mail-order LSR
Topics68,011
Posts661,580
Members10,381
BSA a65 bottom end rebuild - need shop in NYC metro area #12671
06/27/06 5:00 pm
06/27/06 5:00 pm
nyc
quentin Offline OP
quentin  Offline OP
nyc
Hello gang - I'm going to do a complete rebuild on the bottom end of an a65 that presently has a siezed conrod bearing.
Any suggestions for a shop to do the work? I'm thinking of a roller bearing conversion, balanced crank, and oil pump upgrade.
Going to need the top end mic-ed. I think it's fine but want to be sure - new rings and a hone oughta be good, but I want an expert opinion.
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12672
06/27/06 9:42 pm
06/27/06 9:42 pm
An oil filter is cheaper than the needle bearing conversions (I assume that's what you meant).
Rich, ya got any opinions on this? laugh
And yes, do get the cylinders miced AFTER running a hone through them.
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12673
06/27/06 10:53 pm
06/27/06 10:53 pm
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
quentin, Your email address is no good. Contact me at mine. I can assist you.
,_o
_ -\_<,
NOPGS #2
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12674
06/28/06 11:08 am
06/28/06 11:08 am
Rich B Online happy
Rich B  Online Happy
Alex sez:
"Rich, ya got any opinions on this? laugh "
You know I do... laughing .
I suspect if John ends up helping out, it will be in good hands.....
Quentin,
After a recent exchange of comments on this and other boards about the bearing conversions...I finally quit being lazy and did the load/life calculations of the needle bearings used for the conversions....IMO...it isn't pretty. Needle bearings are not made for the loads/RPM an A65 is capable of.
The weakness of A65's has NOTHING to do with bearings or thrust control. That is nothing more than a fairy tale. And not even a good fairy tale at that.
The unit twins had problems with lubrication up until sometime during the 69 model year. It is not insurmountable. There has been plenty of threads over the last year on this subject. Do a search.
You want a big gear pump (67 on); a piston type relief; o-ring seal on the relief to seat it deeper; and for mid year 69 back cases, seal the lowest threads in the relief cavity to provide a seal between the pump oil and drain oil.
The pump needs to be hand fitted to be right, gasket needs relieved to actually fit the pump and cases.
You need a return line oil filter. Period. There is really nothing to discuss on this subject...plain bearing engines HAVE TO HAVE filtered oil.
All of this followed by careful assembly of the bottom end. They work and work well. It just requires some care and understanding.
Good luck
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12675
06/29/06 1:58 am
06/29/06 1:58 am
hamden, ct.
hacksaw Offline
hacksaw  Offline
hamden, ct.
cool.
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12676
06/29/06 2:00 am
06/29/06 2:00 am
hamden, ct.
hacksaw Offline
hacksaw  Offline
hamden, ct.
oh, and what about this balanced crank bull? i realize that a rebuilt crank needs to be balanced to a degree. but what degree? and what happens if you take a stock bottom end such as a 500, and put 650 top end on it? how balanced is that? or how imbalanced is it. even 40 over pistons, any effect?
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12677
06/29/06 2:10 am
06/29/06 2:10 am
new jersey usa
John RGS Offline
John RGS  Offline
new jersey usa
Hacksaw, To put it very mildly, starting with a factory balance motor, the degree of modifications you would want to do would depend on what your intended use is for the motorcycle. Going all out nuts on a touring Thunderbolt is in my opinion, false economy. If your building a race machine, the options vary substantially.
,_o
_ -\_<,
NOPGS #2
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12678
06/29/06 1:36 pm
06/29/06 1:36 pm
Hacksaw,
They are all unbalanced, but 500's and 650's use different balance factors. Careful static balancing (as described in the shop manual) to the recommended balance factor (70%) will go a long way, but dynamic balancing will reduce the 2nd order harmonics that tend to give A65's their "buzziness".
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12679
06/29/06 3:24 pm
06/29/06 3:24 pm
Adirondacks, New York
ADKdude Offline
ADKdude  Offline
The guys at 6th Street Cycles could help you out. Its on 6th street between ave c and d. YOu should visit there anyway iof you have an A65.
ADKdude
1970 BSA Thunderbolt
1971 Honda CB750
Re: BSA a65 bottom end rebuild - need shop in NYC metro area #12680
06/29/06 5:56 pm
06/29/06 5:56 pm
easley south carolina
bsadb Offline
bsadb  Offline
Balance.
Ted Hubbard (bsa's service tech) told me about many A65 BSA's cracking frames,headlamp mounts,oil tank mounts,and fenders because of out of balance cranks. The factory fix was to flip the bike upside down, remove the drain pan, stuff it with rags, and drill one two 1/2 in holes in the crank 180 from the pin. I woul take the time to at least check the static balance.
However,dynamic is the best.
Always use the Golden Rule.
