smitty
smitty
cleveland,ohio
26 registered members (998John), 193 guests, and 400 spiders.
10416 Registered Users
btour 83
Rohan 78
Triless 77
reverb 74
Stuart 70
706,407 mail-order LSR
Topics68,277
Posts664,694
Members10,416
Will a 750 5speed engine fit a 72 frame? #126427
10/16/07 7:44 pm
10/16/07 7:44 pm
Oklahoma City OK
Jake Hartley Offline OP
Oklahoma City OK
Was offered a good deal on a good engine. I need to know if the 73 5 speed engine will fit into my early 72 frame without much drama.
Sorry if this is a goofy question, but my last Brit bikes were Nortons......
"He who makes a beast of himself gets rid of the pain of being a man"
Re: Will a 750 5speed engine fit a 72 frame? #126428
10/16/07 8:17 pm
10/16/07 8:17 pm
Norman Rowbottom Offline
Hi Jake, ( have 1971 T120 OIF with a 1976 T140v motor, has you can see from the pic it looks more like a 1979 T140D special but it is not of course, so I don't think you should have any problems with your setup.
I presume your frame is an oil in the frame type.
No doubt the more knowledgeable will correct me if I am wrong.
Good luck norman.
IfYaWannaBeAWinnaYaGottaeatYaDinnaMamSaid
Re: Will a 750 5speed engine fit a 72 frame? #126429
10/16/07 8:38 pm
10/16/07 8:38 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
this is kind of bassackwards but my bike is a 73 T140 frame and 72 T120 engine so i dont see why not
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando
Re: Will a 750 5speed engine fit a 72 frame? #126430
10/17/07 3:15 am
10/17/07 3:15 am
Jon W. Whitley Offline
Jake,
The 1973 engine will fit into the 1972 frame......as if it was made to do so. The dimensions are the same. You may have to use spacers for your top end motormount ( to bring the bracket up to a level height )...but that's about it.
Re: Will a 750 5speed engine fit a 72 frame? #126431
10/17/07 4:30 am
10/17/07 4:30 am
Oklahoma City OK
Oklahoma City OK
Thanks all!
Re: Will a 750 5speed engine fit a 72 frame? #126432
10/17/07 4:35 am
10/17/07 4:35 am
uniontown, pa, usa
Buster Conrod Offline
uniontown, pa, usa
Hmmmmm....could there be an issue of the shifter and brake being on the same side? When did they change.
1970 TR6R Dry Frame Silver and Blue, Prettiest bike ever....
Re: Will a 750 5speed engine fit a 72 frame? #126433
10/17/07 7:46 am
10/17/07 7:46 am
Canby, Oregon
Bret Edwards Offline
Canby, Oregon
Buster,
'73 still had the shifter on the right and brake on the left. This makes the '73 T140 motor kind of neat since you can even drop it straight into a 1964-'70 pre-OIF chassis. '74 models got the shifter on the left.
I did this same '72 T120 chassis -'73 T140 motor conversion some years ago and, if I remember correctly, there were some alignment or reach issues with the rubber airbox boots not lining up quite right with the carbs on the 750 motor. Something about the '71-'72 high frame model airboxes and the 1/2" shorter 750 motor comes to mind. It still panned out somehow. Just be prepared for some fettling.
Cheers, Bret @ Glass from the Past
Re: Will a 750 5speed engine fit a 72 frame? #126434
10/17/07 12:37 pm
10/17/07 12:37 pm
The later left side shift engine will fit in all 650 and 750 Unit frames from 1963-up.When doing so, you can convert to right hand shift.....a fairly easy-straight forward operation. If wanting to stay with the left side shift, swap the drum brake swingarm for the disc brake swing arm and appropriate parts.This swing arm swap only applies to the 1971 and up OIF frames wink
Re: Will a 750 5speed engine fit a 72 frame? #126435
10/17/07 1:05 pm
10/17/07 1:05 pm
JubeePrince Online content
JubeePrince  Online Content
IIRC, the 750 twins went to left-hand shift in the '76 model year.....
And wouldn't the short-rod 750's fit better in the frame than the long-rod 650's??
Re: Will a 750 5speed engine fit a 72 frame? #126436
10/17/07 2:44 pm
10/17/07 2:44 pm
Canby, Oregon
Canby, Oregon
Actually Jubee,
We both were off the mark a bit. 1975 was the first of the left side shifters. But since not very many 1974 bikes left the factory due to the worker's cooperative blockade, most right side shift T140 motors found will be 1973 models.
Re: Will a 750 5speed engine fit a 72 frame? #126437
10/17/07 3:09 pm
10/17/07 3:09 pm
Canby, Oregon
Canby, Oregon
Jon,
Most here know what you meant, but just to clarify for any newbies. The reference to swapping the disc and drum swingarms and brakes is only for the 1971 and up OIF chassis. The OIF disc swingarms will not install into 1963-70 pre-OIF chassis. Anything is possible with enough work, but it's not a 'plug and play'.
Re: Will a 750 5speed engine fit a 72 frame? #126438
10/17/07 4:32 pm
10/17/07 4:32 pm
Thanks Bret,
I have edited my post to include that disclaimer! It didn't even cross my mind to add such a thing,taking for granted that everyone would know I was referring to the OIF frames, but then I pictured a guy trying to fit a later swing-arm onto a 1963-1970 frame, puzzled and cursing the guys giving advice on the board! beerchug
