kingodawg
kingodawg
Cleveland,Ohio
194 registered members (79T140E), 2,184 guests, and 595 spiders.
koan58 90
Lannis 88
NickL 86
Stuart 57
505,913 mail-order LSR
Topics66,065
Posts639,446
crosshatch #125819
10/08/07 10:10 pm
10/08/07 10:10 pm
the south
headlamp Offline OP
headlamp  Offline OP
the south
I want to replace the rings in my T140 I would like to know the grit type and crosshatch information..The machinest i called says his machine uses a 45 degree cross hatch but he said its adjustable..Then there is the Qusetion of what rings should I use chrome or steel
thanks for you help! and this fourm
Re: crosshatch #125820
10/09/07 12:40 am
10/09/07 12:40 am
John Healy Online content
John Healy  Online Content
Hastings recommends 45 for their rings.
They also recommend 220 to 280 grit surface finish for all three of their rings types:
a. grey cast iron (because we are using our rings in an air cooled engine ( where it is impossible to get cylinder perfectly round and distortion from mounting hardware is typical, I would use 220),
b. ductile iron and
c. steel rings
(both ductile iron and steel are coated with special coatings to make them compatable with the cast iron cylinder like chrome).
http://www.hastingsmanufacturing.com/ServiceTips/cylinder_bore_refinishing.htm
Re: crosshatch #125821
10/09/07 2:26 am
10/09/07 2:26 am
the south
headlamp Offline OP
headlamp  Offline OP
the south
Thanks for that bit of information It will make life easier
Re: crosshatch #125822
10/09/07 12:50 pm
10/09/07 12:50 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
While on the site for Hastings rings, is it possible to make up a ring set for a piston from thier stock items and the careful use of a stone/dremel for the end gaps?
I have written to them and enquired thier minimum order, I might import a few sets for A10's etc and *bay them .
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: crosshatch #125823
10/09/07 7:37 pm
10/09/07 7:37 pm
!!!!BUMP!!!!
1959 3TA
BMW R1150 Oilhead
Page Time: 1.027s Queries: 14 (0.033s) Memory: 1.0154 MB (Peak: 1.1626 MB) Zlib disabled. Server Time: 2018-02-25 19:14:51 UTC
