Denis J
Denis J
Sacramento, CA
20 registered members (79T140E), 199 guests, and 406 spiders.
10418 Registered Users
btour 89
Triless 78
reverb 76
710,145 mail-order LSR
Topics68,304
Posts665,017
Members10,418
3TA conversion to 500 cc spec. #124848
09/25/07 9:51 pm
09/25/07 9:51 pm
Croatia
Darko Offline OP
Darko  Offline OP
Croatia
Help, could I convert 3TA engine to 500cc using T100R cylinder head?
Re: 3TA conversion to 500 cc spec. #124849
09/26/07 12:25 am
09/26/07 12:25 am
australia
6
649 Offline
649  Offline
australia
do you mean head and barrels & pistons? if you think changing the head can increase it to 500cc suggest you leave it alone as would require a little more mechanical knowledge
1970 tr6r dryframe
Re: 3TA conversion to 500 cc spec. #124850
09/26/07 2:05 am
09/26/07 2:05 am
australia
tiger_cub Offline
tiger_cub  Offline
australia
Hi, I have done this, but you need the head, barrels, pistons AND conrods from the 500.
1970 TR6C
1970 TR6R
Re: 3TA conversion to 500 cc spec. #124851
09/26/07 3:01 am
09/26/07 3:01 am
australia
6
649 Offline
649  Offline
australia
and preferably timing side bearing conversion?
1970 tr6r dryframe
Re: 3TA conversion to 500 cc spec. #124852
09/26/07 5:06 am
09/26/07 5:06 am
Croatia
Darko Offline OP
Darko  Offline OP
Croatia
I meant cylinder head, barrels, pistons, valves, rockers everything and mechanic who will do it. But since I should provide the parts I wonder if I could do conversion to 500 cc using Daytona T100R cylinder head instead 5TA head since I heard that this two are not the same.
Best regards
Re: 3TA conversion to 500 cc spec. #124853
09/26/07 5:10 am
09/26/07 5:10 am
Croatia
Darko Offline OP
Darko  Offline OP
Croatia
Did you noticed any problems, issues with reliability etc?
Best regards
Re: 3TA conversion to 500 cc spec. #124854
09/26/07 1:34 pm
09/26/07 1:34 pm
Solihull, West midlands UK
Grappa Speziale Offline
Should not be any problems with this, no need to change the timing side bearing, its the same bearing on 350-500. I think the clutch have 1 more plate and probably higher gearing.
Good luck!
1960 T100A
1963 T100SS
1965 Norton Atlas 750 Caferacer
Re: 3TA conversion to 500 cc spec. #124855
09/26/07 2:56 pm
09/26/07 2:56 pm
Halifax, Butt end of Europe
andrewinpopayan Offline
Thats the reason there aren't many 3TA's still about, they seem to get wrecked by the conversion.
For the extra clutch plate you need the deeper basket, to accomodate this you need the deeper chaincase, you need a larger carb, jets are different, ignition advance range is different, and as stated, barrels, pistons, rings, rods, head, maybe a set of B.E. shells, TS bearing, I believe the camshafts are different.
All in all a way to throw money at an engine in order to break it.
99% of carb problems are electrical.
1959 3TA
BMW R1150 Oilhead
Re: 3TA conversion to 500 cc spec. #124856
09/26/07 8:23 pm
09/26/07 8:23 pm
Greenock, Scotland
gearhead1951 Offline
Greenock, Scotland
I saw acouple of conversions back about '68,'70
that involved puting a sportsters cams, lifters,
and complete top end on to a 45 flatheads cases!
They ran like a turpintined tom cat for a while, but all of them eventually grenaded, that bottom end just was not capable of standing up to all the improvments to the top end
I am not so familiar with the 3TA but I'll bet that the same situation would apply
