57nortonmodel77
57nortonmodel77
Concord Township, Ohio
49 registered members (Al Eckstadt), 291 guests, and 404 spiders.
10256 Registered Users
Lannis 62
608,687 mail-order LSR
Topics67,112
Posts651,274
Members10,256
T140 Fork tube change #122786
08/29/07 11:40 am
08/29/07 11:40 am
Kent UK
Blapper Offline OP
Blapper  Offline OP
Kent UK
Hi All,
I have to change my fork tubes this winter, and will change seals and valves at the same time. Is there a 'MUST have' tool for this or is it just a 'handy to have' but can get by without?
Thanks for any help.
Blapper redwine
Re: T140 Fork tube change #122787
08/29/07 12:58 pm
08/29/07 12:58 pm
Tennessee
triumphmike Offline
triumphmike  Offline
Tennessee
IMHO the only must have tool is a pneumatic impact wrench for "spinning" off the socket head bolt under the front axle. There is a Triumph tool (or you can use very long screw driver) that reaches down the fork tubes to hold the damper assembly while cranking on the socket head bolt, but an air impact wrench usually works. Unless the PO used red loctite! Once the socket head bolt comes out you can pull the lower sliders off the tubes. I usually do this with the fork tubes still in the triple clamp. Good luck.
Re: T140 Fork tube change #122788
08/29/07 1:30 pm
08/29/07 1:30 pm
NSW Australia
BrianFromOz Offline
BrianFromOz  Offline
NSW Australia
so once 33 is removed then 19 holds the rest inside the leg and the slider just slides off ...??
"What are you rebelling against?
What have you got?"
77 T140V
Is Your Bike Here?
MembersBikesBritBikeForum
http://s165.photobucket.com/albums/u51/MembersBikesBritBikeForum/
Re: T140 Fork tube change #122789
08/29/07 3:41 pm
08/29/07 3:41 pm
Kent UK
Blapper Offline OP
Blapper  Offline OP
Kent UK
How long a screwdriver triumphmike? Chisel end or crosspoint?
Has BrianFromOz got it there?
Thanks for the heads up guys,
Blapper redwine (australian red that is wink )
Re: T140 Fork tube change #122790
08/29/07 5:26 pm
08/29/07 5:26 pm
shel Offline
shel  Offline
How long of a screwdriver? I don't know, never used one. the impact works great.
Yes, the Ozman is correct bigt
Re: T140 Fork tube change #122791
08/29/07 9:24 pm
08/29/07 9:24 pm
NSW Australia
BrianFromOz Offline
BrianFromOz  Offline
NSW Australia
Blap....try them with a normal hex key first...my bolts were lucky to be finger tight eek
your in the land of fine wine and your drinking ozzie red?? :p
ps...and watch for the sealing washer (34) INSIDE the stanchion....and mine also had a pile of sludge at the bottom too...
What have you got?"
77 T140V
Is Your Bike Here?
Re: T140 Fork tube change #122792
08/29/07 9:29 pm
08/29/07 9:29 pm
JubeePrince Offline
JubeePrince  Offline
Blapman
I, too, was able to remove the bolt without holding the damper assembly......give it a try....worst thing that can happen is it won't work... bigt
Re: T140 Fork tube change #122793
08/29/07 9:59 pm
08/29/07 9:59 pm
PDX
spikethebike Offline
PDX
You need a bigger hammer!
Spike Cornelius in PDX (Portland, OR)
1965 T100SC
And various others
Re: T140 Fork tube change #122794
08/29/07 10:38 pm
08/29/07 10:38 pm
NSW Australia
BrianFromOz Offline
BrianFromOz  Offline
NSW Australia
What have you got?"
77 T140V
Is Your Bike Here?
Re: T140 Fork tube change #122795
08/30/07 7:34 am
08/30/07 7:34 am
Kent UK
Blapper Offline OP
Blapper  Offline OP
Kent UK
Ah! I can see the problem Brian - you need more hammers. I've got another six you can borrow laugh
Some French wine is excellent, but a lot isn't. Best taste per is New World wine for us.
Thanks everybody,
Blapper redwine
