mike treloar
mike treloar
new zealand
42 registered members (Adam M.), 274 guests, and 337 spiders.
10476 Registered Users
NickL 89
franko 71
Triless 67
747,003 mail-order LSR
Topics68,810
Posts670,260
Members10,476
Pre unit gearbox numbers #120262
07/25/07 12:53 am
07/25/07 12:53 am
San Pedro CA
Lenos Offline OP
Lenos  Offline OP
San Pedro CA
What is the significance of the number stamped on the gearbox case on pre-units? For example I have a TR6 with the numbers 115506 stamped. Unfortunately this case has a crack so I need to repair or replace it. what numbers can I use or does it matter?
thanks all.
'64 Atlas/'60 TR6 Triton
Re: Pre unit gearbox numbers #120263
07/25/07 1:04 am
07/25/07 1:04 am
Jon W. Whitley Offline
You want to replace with like year cases. The factory dispatch records for a Triumph of that time would have included the engine,frame and transmission numbers. If it is an all original bike and the case is repairable then you might want to do that.But, you can use a case within the motorcycles manufactured time frame.
There are a few different variations of the the pre-unit cases...inner and outer.If your bike is a swing-arm model then the swing-arm model cases from 1954-1962 will work for you. The difference between a rigid case and a swing-arm case is easily identified. So, what year motorcycle is it?
Re: Pre unit gearbox numbers #120264
07/25/07 6:46 am
07/25/07 6:46 am
San Pedro CA
Lenos Offline OP
Lenos  Offline OP
San Pedro CA
The engine number is D2570 which makes it a 1960 I believe. The frame is long gone. I bought the engine and gearbox for use in a Triton so it's not such a big deal, but I do want to be period correct.
