ADC
ADC
CALIFORNIA
33 registered members (AndyB), 167 guests, and 391 spiders.
Mums, MyrtleBeezer, Crockermc, mpotter78, Frezz
10485 Registered Users
NickL 97
franko 87
Triless 66
754,293 mail-order LSR
Topics68,905
Posts671,177
Members10,485
Mystery engine #116513
05/21/07 6:50 pm
05/21/07 6:50 pm
Warrington, Cheshire, UK
TriVin Offline OP
TriVin  Offline OP
http://i189.photobucket.com/albums/z84/bodlan/IMG_1068.jpg
http://s189.photobucket.com/albums/z84/bodlan/
I hope that this works(the photos that is)
I've got hold of a bike that started life as a T120V but has had an engine swap at sometime. The bike goes very well but the engine is a mystery because as you can see it does not have an engine number stamped on the L/H side casing. How can this be? The DVLA at Swansea (remember I'm in the UK)have the engine as DU13368 on the registration documents but as you can see from the other photos (hopefully)it has a much later head so it cant be a 64 engine, or could it?
Can any of you long time experts identify this engine year from any other of the features that I have photographed. Can you get a 70's head onto a 64 bottom end?
Maybe the bloke who did this swap is out there looking at this post. What did you do with the original engine mate. Build a 5 speed Triton maybe?
Any help or information gratefully received.
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Re: Mystery engine #116514
05/21/07 7:02 pm
05/21/07 7:02 pm
I had a set of unstamped cases and built a '68 Bonnie out of it, stamped the cases to match the frame at the client's direction.
Talk about "anything goes"...
Re: Mystery engine #116515
05/21/07 7:06 pm
05/21/07 7:06 pm
Looks like a '73 or close...
Sure don't know where they got that number from, it looks like a complete bike to me, just not stamped. Perhaps the original engine was blown in the past, so cases had to be swapped.
Re: Mystery engine #116516
05/21/07 7:43 pm
05/21/07 7:43 pm
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
1972 T 140 with new engines cases after the original build.
Re: Mystery engine #116517
05/21/07 8:16 pm
05/21/07 8:16 pm
John Healy Offline
John Healy  Offline
T140?
Re: Mystery engine #116518
05/21/07 8:28 pm
05/21/07 8:28 pm
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
I thought in late 72 the engines were bored to 725 cc ,fitted with single flat inspection covers and refered to as T 140 Bonneville
Re: Mystery engine #116519
05/21/07 8:38 pm
05/21/07 8:38 pm
shel Offline
shel  Offline
Well it's definetly not a 64 since it breathes through the primary.
Does it have one head bolt or two between the rocker boxes?
Re: Mystery engine #116520
05/21/07 8:47 pm
05/21/07 8:47 pm
hamilton on. can.
H
highway Offline
highway  Offline
H
hamilton on. can.
My bet, New late model left crankcase.
73 650 top end, 10 bolt casting with 9
hole drill pattern.
T 140 in manifolds, manifolds for the
73 version were bolt to the head,
bolt/nut to the carbs so the air
filter holes lines up with the
carbs.
Cheers Rick
Re: Mystery engine #116521
05/21/07 9:48 pm
05/21/07 9:48 pm
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
Note the 12 point nuts on the barrel studs, What year did that end
Re: Mystery engine #116522
05/21/07 11:38 pm
05/21/07 11:38 pm
Jon W. Whitley Offline
Mid-season 1972 650's incorporated the designs you see on this engine.Bolt on manifolds, push-in exhaust and the 4 bolt inspection covers on the rocker boxes.
As pointed out, this engine has the later style breather which puts it in the right time frame. Look to see if the case halves match.You will have to look underneath the engine.On each case there will be a three digit number and they will be fairly close to and opposite of each other.
The primary cover is from a 1963-1967. The rest all looks 1972. Do the frame numbers correspond to a 1972?
Also,does it in fact have a five speed? Crazy question, but I don't know if you've rode the bike or had a chance to engage all five gears?
Re: Mystery engine #116523
05/22/07 12:59 am
05/22/07 12:59 am
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
Push in exhaust are you sure here
Re: Mystery engine #116524
05/22/07 1:04 am
05/22/07 1:04 am
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
T140?
hat do we have here
Re: Mystery engine #116525
05/22/07 2:07 am
05/22/07 2:07 am
Either that head has been modified to run with the earlier style exhaust stubs, or it using those push in exhaust adapters to use those pipes.Yeah, I'm sure.
Posted by triumphguy:
Re: Mystery engine #116526
05/22/07 7:58 am
05/22/07 7:58 am
TriVin Offline OP
TriVin  Offline OP
Thanks to all for the reply's so far.
I'm in Gods own country until Friday next (Coventry) so cant get at it again until then, when I can check a few more things out re the casting numbers idea and the number of head bolts.
The frame is spot on 1972, April according to the charts I have seen on the net. The stampings are clean and not messed with.
It was advertised as a 4 speed box so I never tried for 5th!! Speed cameras and country lanes prevented a full blown test drive anyway!! Pulls well though.
Jon W, what were the differences to the primary chain case cover that enable you to be so exact with your date of the cover. I'll have dig out book with pictures of 60's Bonnies's to see if I can spot it too.
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Re: Mystery engine #116527
05/22/07 12:12 pm
05/22/07 12:12 pm
TriVin Offline OP
TriVin  Offline OP
Something else of interest is that front mud guard. Its also not original is it?
Anyone recognise what its off?
Tiger 100SS 1966
T120V 1972
Vincent Comet 1952
Re: Mystery engine #116528
05/22/07 12:14 pm
05/22/07 12:14 pm
shel Offline
shel  Offline
The later covers have an additional inspection plug at the front for strobe timing.
Re: Mystery engine #116529
05/22/07 12:21 pm
05/22/07 12:21 pm
John Healy Offline
John Healy  Offline
"Note the 12 point nuts on the barrel studs, What year did that end"
It ended with the 650 motor, there isn't enough room for them on the outside 4 base studs on the 750.
Seat pull latch on left side from a vary late 72 or very early 73. While this is surely shows some signs of being a "bitsa," I know of some 650 models that were made for the 1973 model year for Canada. What I don't know if the Canadian 1973 650's were fitted with a disc brake making the frame/forks from a late 72.
Re: Mystery engine #116530
05/22/07 12:33 pm
05/22/07 12:33 pm
DaveT100SS
As far as the primary cover is concerned,starting in 1968 and up through 1974 there was a round three fixing point removable cover where the Triumph logo is and as Shel explained is for access to the rotor for strobe timing. Front mudguard looks to be off of a later model T140.
Re: Mystery engine #116531
05/22/07 12:49 pm
05/22/07 12:49 pm
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
That 's what I'm trying to say . It ended in late 72 . What I believe we have is a late home model 1972 , bored to 725 cc , fitted with a version of the up coming 73 750 head ,and all done by the factory . Referred to as a 72 T140 Bonneville . Just because the cases are not stamped does not mean that it did not come from the factory that way.
I think the bike has the original engine.
Re: Mystery engine #116532
05/22/07 2:08 pm
05/22/07 2:08 pm
Dallas Texas
RPM Online content
RPM  Online Content
Dallas Texas
All Triumphs had matching engine frame numbers begining in the early 50's. No execptions. This bike has replacement cases. Late 1972 650 with T140 intake manifolds and airbox. Of course the 650 motor is taller than the 750, thats why the airbox and carbs do not line up. If you look at the head it is cast for 10 bolts but drilled for 9 just as the highway posted. The manifols on a 72 are machined to angle down a bit to line up with the airbox. This bike also has the pull knob on the left side for the seat latch. This would be a lower frame than the 71/early72.
Re: Mystery engine #116533
05/22/07 3:39 pm
05/22/07 3:39 pm
John Healy Offline
John Healy  Offline
No Triumphguy, it ended with the last 650 in 1973. Yes, they did make 650 in 1973, but I believe they were fitted with disc brakes like their 750 cousins of the year.
Bikes DID NOT leave the factory without engine numbers!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I don't think these are new cases at all, but ones that someone has altered. All of the engine cases in my possesion do not have the serifs on the "T." I would be interested if any one else has an engine case stamped with the "Triumph" logo that has the serifs on the "T."
Also all of the cases I have do not have the Triumph placed in a random pattern. They are all equally spaced and LEVEL.
I would be very interested in seeing the gasket cylinder base gasket surface just above the number pad.
Re: Mystery engine #116534
05/22/07 4:42 pm
05/22/07 4:42 pm
Winchester Tn.
triumphguy Offline
triumphguy  Offline
Winchester Tn.
Ok Sincerey I convinced ,no bikes left that were not stamped.
Re: Mystery engine #116535
05/22/07 4:51 pm
05/22/07 4:51 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
The numbers of the matching case halves, on the bottom of the sump will probably prove that the DS engine case is new. If matching, then the serial number has been artfully machined off... which is more common than one would think.
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Mystery engine #116536
05/22/07 10:09 pm
05/22/07 10:09 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
I count 8 cylinder fins.
That means it's a long rod engine.
T120, 650CC
AFIK there is no T140 with 8 fins.
Stop the insanity.
Re: Mystery engine #116537
05/22/07 10:30 pm
05/22/07 10:30 pm
Anonymous
Unregistered
Anonymous
Unregistered
bored to 725 cc
What???
