Timecycles
Timecycles
Alberta, Canada
46 registered members (Adam M.), 294 guests, and 395 spiders.
IDG1, pemdoc65, creativecroc, gregneal, Chris Marsland
10170 Registered Users
Lannis 99
Stuart 83
reverb 82
NickL 73
koan58 56
549,701 mail-order LSR
Topics66,547
Posts645,114
Members10,170
wiring issues for a t120v #115453
05/08/07 4:59 pm
05/08/07 4:59 pm
nor-cal
mhall008 Offline OP
One time posting
mhall008  Offline OP
One time posting
nor-cal
well kiddies, im new to the britbike sceen and I need some help figuring out the wiring on these bikes. I have a 72 650 twin t120v. when I got the bike it was a pos. ground set up with a mity max power box but it was all okied up and I dont know where to start to get it fixed. So far Ive asked alot of mechanic friends for help and I heard alotta different stories but what i hear from everyone basically is pos ground is exactally backwards from neg. ground... Hmmm, well that helps a lil bit but not enough, then I heard this statement.. "The Mitymax can be hooked up either way, and the alternator has no inherent polarity. In other words, you can go either way; just make sure the polarity of the battery matches the polarity of the coils." Is this true? I have a mity max set up with the elec. ign, duz that mean i can just simply wire the bike to a standard neg ground and forget all about the nightmare i found the bike in??? I also heard that if you have a mity max power box you dont need to run a battery, is this also true? Thanx for your time. mhall
Re: wiring issues for a t120v #115454
05/09/07 2:45 am
05/09/07 2:45 am
Mark Z Offline
Mark Z  Offline
"when I got the bike it was a pos. ground set up"
That's how they came from the factory.
"...and I dont know where to start to get it fixed."
Is it broken? There's nothing inherently wrong with positive ground, it's just different from what most of us are used to. I've never had a problem mentally "converting" when working on Brit bikes, but if it really bugs you, you can change to negative ground; it makes no difference. In so doing, you may want to change your ground wires from red to black (red=positive seems to be a universal convention).
"...duz that mean i can just simply wire the bike to a standard neg ground and forget all about the nightmare i found the bike in?"
Again, simply having a positive ground does not qualify it as a "nightmare" - what else is wrong with it?
Page Time: 0.067s Queries: 14 (0.006s) Memory: 0.9887 MB (Peak: 1.1113 MB) Zlib disabled. Server Time: 2018-04-20 20:12:51 UTC
