Timecycles
Timecycles
Alberta, Canada
20 registered members (Alan_nc), 154 guests, and 436 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,042 mail-order LSR
Topics68,853
Posts670,686
Members10,478
Extra primary oil? #114639
04/23/07 2:56 pm
04/23/07 2:56 pm
Surrey, UK.
splittie65 Offline OP
Surrey, UK.
1975 Triumph T140V
Opened up the cover in the Primary Chaincase by the rotor so I could check the timing, and loads of extra oil came flooding out. I know the correct amount was in there, so where's the extra most likeley to have come from?
Oil has dropped from the main reservoir, but I have a leak anyway. The oil seemed quite thin.
From the gearbox?
Also have great difficulty finding neutral gear when engine warmed up. Any suggestions?
Cheers.
Re: Extra primary oil? #114640
04/23/07 3:01 pm
04/23/07 3:01 pm
kommando Offline
kommando  Offline
Check the holes in the inner primary that allow the excess oil from the primary to drain back into the crankcase as it sounds like they are blocked. The engine and primary oil are shared on a T140 and the engine breathes out through the primary.
Re: Extra primary oil? #114641
04/23/07 4:01 pm
04/23/07 4:01 pm
North Georgia, USA
RF Whatley Offline
RF Whatley  Offline
North Georgia, USA
65 -
Sounds as if your engine is trying to "oil wet sump", but the crank is throwing all the excess oil over into the primary case. Normally it would level out by draining back through the 3 small holes Kommando said to clean... then the oil pump would take it all back to the main oil tank.
You'll simply have to investigate. Do a search here on "oil wet sump". There's lots written about the subject.
Too much oil in the primary would make the bike very hard to shift. So I'm not convinced that your 2 issues aren't connected.
:bigt:
Don't hide 'em, Ride 'em !!
RF Whatley
Cornelia, GA
Re: Extra primary oil? #114642
04/23/07 7:13 pm
04/23/07 7:13 pm
Surrey, UK.
Surrey, UK.
Cheers for that, I'll have alook at those.
