J Rowe
J Rowe
Orange, MA USA
34 registered members (Al Eckstadt), 204 guests, and 447 spiders.
10257 Registered Users
Lannis 55
TBolt72 47
610,743 mail-order LSR
Topics67,150
Posts651,632
Members10,257
TR6 With Mikuni problems - newbie help! #110274
02/17/07 5:33 am
02/17/07 5:33 am
Tasmania, Australia
porge Offline OP
porge  Offline OP
Tasmania, Australia
OK - Before 'Tiger' says "stick a Concentric on there already", I'll give the mikuni ONE last go. confused
So - after cleaning the float bowl of the accumulated crap to stop petrol spewing out of the bell mouth, the throttle became sticky. So I took the tank off to get a better look. Stopped sticking. Tank on - no problems.
Restarted, "idling" about 3K rpm or so. Before this point, the bike would idle at an indicated 800rpm. The throttle slide moves smoothly up and down the bore of the carb with the twist grip, about a 10-14mm gap between the bottom of the bellmouth and the cutout on the slide.
So - convinced I need to take this thing apart - what does the accumulated and much appreciated knowlege of the group think??
1969 Triumph TR6R
1956 Matchless G80S
1964 Royal Enfield 350 Bullet
1964 Honda CD125
Re: TR6 With Mikuni problems - newbie help! #110275
02/17/07 4:22 pm
02/17/07 4:22 pm
Anonymous
Unregistered
Anonymous
Unregistered
A guess?
The cable isn't fully seated in the slide.
Re: TR6 With Mikuni problems - newbie help! #110276
02/17/07 6:01 pm
02/17/07 6:01 pm
Melbourne, Australia
MikeTRP Offline
MikeTRP  Offline
Floats upside down.
Re: TR6 With Mikuni problems - newbie help! #110277
02/17/07 6:01 pm
02/17/07 6:01 pm
Out There!
Nick Offline
Nick  Offline
Out There!
There must be a small amount of play in the twist grip before it begins to lift the slide. Use the adjuster on the top of the carb to achieve this. Then, when you open and release the twist grip you must be able to hear the slide come to a stop on the idle screw. Don't start the bike without both of the above conditions being met. Also make certain that the cable runs smoothly from carb to grip, turn bars from lock to lock to make the slide does not lift while doing so.
The Mikuni is one of the best motorcycle carburetors ever made. If you're having problems with it, don't blame the carb.
Re: TR6 With Mikuni problems - newbie help! #110278
02/18/07 12:36 am
02/18/07 12:36 am
Tasmania, Australia
porge Offline OP
porge  Offline OP
Tasmania, Australia
OK - About to go back to shed.
Mike - Floats are marked with an up position, so I hope I'm good on this one wink That said...the little "knibs" off the floats - do they face in towards each other, or "out" - away from each other?
Nick - will check out the cable routing and the amount of play in the twistgrip.
Panic - will check when I do the above
1969 Triumph TR6R
1956 Matchless G80S
1964 Honda CD125
Re: TR6 With Mikuni problems - newbie help! #110279
02/18/07 1:43 am
02/18/07 1:43 am
Cincinnati, Oh
Jethro Offline
Jethro  Offline
Cincinnati, Oh
Just want to say something about Mikunis. I have an old, rigid chopper (t120), and am running dual 26mm Mikunis. It WAS quite a chore to get them tuned. I BOUGHT the manual from SUDCO!!! I can not recommend enough how much that manual saved me, and how great a resource it was. Someone on this board recommended it... THANK YOU! Now, once I got them running well, they have NEVER hiccuped... and they run like striped-*** apes. GREAT carb, I kid you not.
Re: TR6 With Mikuni problems - newbie help! #110280
02/18/07 3:56 pm
02/18/07 3:56 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
Slide is in backwards, cutaway should face engine
Stop the insanity.
Re: TR6 With Mikuni problems - newbie help! #110281
02/18/07 4:14 pm
02/18/07 4:14 pm
shel Offline
shel  Offline
confused
Re: TR6 With Mikuni problems - newbie help! #110282
02/18/07 4:39 pm
02/18/07 4:39 pm
Virginia, USA
SBoyd Offline
SBoyd  Offline
Virginia, USA
Yes Shel, I too am puzzled by my own remark!!!!
I did not properly read the original post.
(one of my pet peeves as well)
Stop the insanity.
Re: TR6 With Mikuni problems - newbie help! #110283
02/18/07 4:53 pm
02/18/07 4:53 pm
shel Offline
shel  Offline
I thought maybe you were having a little fun with us laughing
