Hector Catre
Hector Catre
Toronto/Ontario/Canada
205 registered members (68 royalstar tony), 1,706 guests, and 551 spiders.
10036 Registered Users
Lannis 147
kommando 113
Stuart 62
478,362 mail-order LSR
Topics65,740
Posts635,506
Members10,036
t140 valve stem seals #109548
02/04/07 8:15 am
02/04/07 8:15 am
tasmania
bert007 Offline OP
bert007  Offline OP
tasmania
im rebuilding t140 head pre 79, im considering fitting steam seals, i read somwhere triumph fitted 'o' rings in 80,81,? instead of the 1979 seals. if this is correct can i fit these to early valves, is it worth it, did they work. or should i not bother. any opinions thanks
t140
Re: t140 valve stem seals #109549
02/04/07 3:10 pm
02/04/07 3:10 pm
John Healy Online content
John Healy  Online Content
Your T140 guide can easily be modified to accept the Norton valve guide seal.
I have heard he "O" ring trick, but never seen it in a Triumph from the factory. The "o" ring finds its way under the valve collar and deflects the oil from running down the valve stem.
In comparison to other motors, the area around the guide is subjected to very little oil. If one was to modify the oil feed to the rockers, as discussed on other threads, it might make sense. In my experience it snuggles right in there with the Boyer - points; AMAL - Mikuni; etc discussion.
If this group is as predictable as I believe, what will follow is 60-40 split, with 40 for the oil seal and 60 against.
Now I would spend my time and effort buying REAL valves and REAL valve guides: Nitrided valves and guides made from real valve guide material, not free machining brass...
Re: t140 valve stem seals #109550
02/04/07 3:49 pm
02/04/07 3:49 pm
Massachusetts, U.S.A.
btour Online content
btour  Online Content
Hi John,
I think I saw those threads, but can not remember well so I do not understand this sentence:
"In comparison to other motors, the area around the guide is subjected to very little oil. If one was to modify the oil feed to the rockers, as discussed on other threads, it might make sense."
Does this meant that if you allows more oil feed to rockers than the modification of adding valve guide seal makes sense? Or something else.
I am curious because I was told a valve guide seal
could be added to my 71 T120R. I would like to know if there is a downside, and what is involved in doing that.
I also remember a thread somewhere in which it was suggested that a "what is the right word" camfer (sp), bevel?, could be added to the valve guide so that less oil would run down it.
I have no idea which is better, in terms of durability of effect.
Re: t140 valve stem seals #109551
02/04/07 7:45 pm
02/04/07 7:45 pm
Tennessee
Fisherman Offline
Fisherman  Offline
Tennessee
Btour, I'll not answer for John, but might try to repeat what I remember when asking the same type question when I saw 2 umbrella type seals in my gasket set when rebuilding my son's '66 TR6.
More oil feed to the rocker shafts usually means running a pressurized feed from the oil pressure switch output up to the rockers. It was done by some guys who raced, but I don't know if it is a reasonable mod for any bike. The problem created is that the volume of oil goes up, and it has to drain through the same holes in the guideblocks, thus the oil can theoretically back up in the pushrod tubes and fill the rocker cavity. Then you need to enlarge the drain back holes, by how much? Who knows? The factory rocker feed seems adequate for street use and most if not all racing applications.
I mentioned the umbrella seal for your problem to band aid a possible sloppy valve guide. Chamfering would tend to make the oil slide off the outside rather than going down inside the guide, and maybe avoid fouling the plug. Either would help a guide that is marginal.
Bottom line for me, I didn't use the valve seals.
Bernie
'Never argue with an idiot, they'll bring you down to their level, and beat you with experience'
'72 TR6
'12 Hinckley Scrambler
'95 FLHTC Road Sofa
Re: t140 valve stem seals #109552
02/04/07 10:04 pm
02/04/07 10:04 pm
Fife,Scotland, UK
Grin Offline
Grin  Offline
Fife,Scotland, UK
I would go with John Healy on this one.
The Meriden factory never fitted the O ring but Harris did to his Bonnies along with cast iron guides on some of his bikes,untill the UK dealers moane about them and went back to the normal bronze type material.
Re: t140 valve stem seals #109553
02/05/07 7:41 am
02/05/07 7:41 am
tasmania
bert007 Offline OP
bert007  Offline OP
tasmania
john does that mean if you where rebuilding a t140e 1979 you would not bother with the oil seal
t140
Re: t140 valve stem seals #109554
02/05/07 2:02 pm
02/05/07 2:02 pm
Bert: That seems like a simple question and there is a simple answer: emissions. But I get the feeling that you know this and want my opinion on using valve guide seals on Triumphs.
As far as emissions is concerned it is a problem in some states in the US. Thus in these localities I would certainly do what I had to do to get my bike to pass the emission tests. Fitting valve guide seals is certainly one of them.
If I was doing a customer's "E" bike, again I would install the seals. It seems to be custom in this industry to blame the previous mechanic for all sorts of unrelated problems... That **** healy didn't fit the valve guide seals, that is why I have to charge you $3,000 to replace the main bearings. The last mechanic never seems to have done anything right in this business!!!
If it was for my personal bike here in Massachusetts, where we do not have emission testing for motorcycles, I would do what I have been doing for years... not fit them.
Re: t140 valve stem seals #109555
02/06/07 5:34 am
02/06/07 5:34 am
tasmania
bert007 Offline OP
bert007  Offline OP
tasmania
thanks for your honesty john, appreciated
t140
