Blapper
Blapper
Kent UK
22 registered members (Alan_nc), 219 guests, and 434 spiders.
10419 Registered Users
btour 85
Rohan 77
Triless 70
reverb 68
713,648 mail-order LSR
Topics68,327
Posts665,185
Members10,419
T140 Neutral switch #107066
12/23/06 11:28 am
12/23/06 11:28 am
Lincoln, England
Bobsimmo Offline OP
Bobsimmo  Offline OP
Lincoln, England
I have had 'bonnie' for 19 years now, and often wished she had a neutral indicator. I have just stripped the engine totally (mainly just to fix numerous oil leaks) and bugger me, there is a switch on the inner gearbox cover (not connected to anything). It can only be a neutral indictor switch can't it? The wiring diagram don't show one though ??? (mine is the very first T140E, and has some 'E' and some 'V' bits)
76/78 T140 Bonnie, Suzuki B-King and Kawasaki ZZ-R1400.
Re: T140 Neutral switch #107067
12/23/06 3:00 pm
12/23/06 3:00 pm
Memphis, TN
TONUP69 Offline
TONUP69  Offline
Memphis, TN
I've had my 1979 Bonnie Special for 15 years. The neutral indicator switch has been broken for ~14 of those... laughing
The part was available two years ago when I bought one and realized how much stuff would have to come off to replace it!
LTR
Larry Reiter
TON UP CLUB
www.tonup.com
Re: T140 Neutral switch #107068
12/23/06 10:37 pm
12/23/06 10:37 pm
Devon UK
normski Offline
normski  Offline
Devon UK
The switch makes to earth when the gearchange quadrant is in the neutral position and the 'pip' depresses the plunger on the switch. Test your switch by checking that it flows electric with the switch depressed.
The switch also makes fitting and indexing the inner gear cover a doddle - make sure the gearchange camplate is in the neutral position ( it should be after re-installing the gears) then offer up the inner cover with the 'pip' engaging the switch.Much easier than with the earlier covers.
