Ola
Ola
Norway
30 registered members (Bodie), 237 guests, and 397 spiders.
10294 Registered Users
Stuart 97
Lannis 68
Mori55 67
640,014 mail-order LSR
Topics67,418
Posts654,633
Members10,294
T120 - a wider tyre, pros and cons? #104837
11/05/06 9:21 pm
11/05/06 9:21 pm
Johann T Offline OP
Johann T  Offline OP
I'm just about to order new rims for the 1969 T120 Triumph Bonneville I'm restoring. (see http://bonneville.typepad.com for more about the bike).
Standard rims are WM2-18 for the front, and WM2-19 for the rear. However, the wheel-building company has suggested I go for the standard WM2-18 on the front but a wider WM3-19 on the back.
I can see that a wider rear tyre makes sense in terms of increased road grip, but are there any other pros and cons I should be aware of in terms of handling etc before I make a final decision?
Any words of wisdom gratefully received,
Johann T
Re: T120 - a wider tyre, pros and cons? #104838
11/05/06 9:27 pm
11/05/06 9:27 pm
shel Offline
shel  Offline
if I were your wheel builder I would suggest you put the 18" on the rear and the 19" up front laughing
Re: T120 - a wider tyre, pros and cons? #104839
11/05/06 9:33 pm
11/05/06 9:33 pm
Johann T Offline OP
Johann T  Offline OP
My mistake - it's been a long weekend. I should of course have referred to an 18" on the rear and 19" up front. My fault, not the wheel-builders.
All the same, does anyone have any experience (good or bad) of a WM2-19 on the front and a WM3-18 on the back?
JT
Re: T120 - a wider tyre, pros and cons? #104840
11/05/06 9:41 pm
11/05/06 9:41 pm
shel Offline
shel  Offline
i was just having a little fun with you.
my parts catalogue list a wm3-18 as standard for 1969. was this different for home market models?
Re: T120 - a wider tyre, pros and cons? #104841
11/05/06 9:57 pm
11/05/06 9:57 pm
Johann T Offline OP
Johann T  Offline OP
Hi Shel -
I've just re-examined my parts book and although the WM2-18 appears to be standard for the UK bike, it DOES list at the foot of the page a WM3-18 as an alternative rim for a 4 inch tyre. I hadn't noticed this before. Thanks for causing me to take a closer look! :-)
Re: T120 - a wider tyre, pros and cons? #104842
11/05/06 10:04 pm
11/05/06 10:04 pm
The Northwoods... Michigan
Steve Erickson Offline
I think that the "home" models came stock with a 3.50X18 on the rear on a WM2-18, whereas the export models, at least those to the US, had a 4.00x18 on a WM3-18 rear as standard. Some models even had different side stands because of the tire size, I believe.
Re: T120 - a wider tyre, pros and cons? #104843
11/05/06 11:07 pm
11/05/06 11:07 pm
shel Offline
shel  Offline
i wish they would have gave us the big tank as well laughing
Re: T120 - a wider tyre, pros and cons? #104844
11/06/06 10:48 am
11/06/06 10:48 am
Melbourne Australia
Tiger Offline
Tiger  Offline
Melbourne Australia
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by shel:
<strong> i wish they would have gave us the big tank as well bigt
Johann, you could easily end up with tyre/chainguard clearance problems if you go too wide with a rear tyre and std chainguard.
A 110 Avon is very close on my '69 Tiger.
1969 TR6R
Re: T120 - a wider tyre, pros and cons? #104845
11/06/06 11:57 am
11/06/06 11:57 am
Johann T Offline OP
Johann T  Offline OP
Thanks for the clearance advice. The bike definitely has a WM2-18 on the rear. Do you think I will have clearance problems if I go for a WM3-18?
Re: T120 - a wider tyre, pros and cons? #104846
11/06/06 12:20 pm
11/06/06 12:20 pm
Houston Texas
Britbodger R.I.P. Offline
Houston Texas
Johann,
I can verify that models exported to the US have a 18" WM3 rim on the rear so should be OK on your bike. Actually, I have a WM4 rim on my Triumph that I use for Proddie racing and it works fine.
As Tiger has pointed-out its more the tire width that you need to be concerned about. In this regard there is no clearance problem with the original 4" K70's that were fitted stock. However you have to be carefull when selecting a more modern tire. In the case of Avon Road Runners/Super Venoms that are very popular the widest you can get away with without the tire rubbing the chainguard is 90/110 (4.33") as Tiger has already stated. However, if you are prepared to run without the chainguard or alternatively cut a slot in it a 90/120 (4.72") will fit OK. That is what I have done with my T120 and BSA Rocket Three.
Re: T120 - a wider tyre, pros and cons? #104847
11/06/06 5:35 pm
11/06/06 5:35 pm
Peasmarsh, East Sussex
Micknal Offline
Micknal  Offline
Johann
I had exactly the same decision to make when rebuilding my 69 TR6 over the last few years.
It was only when I spoke to the very reputable Tony Miller at the then Miller Motorcyles,Hastings ,that I made my mind up and went for the stock WM3-18. I was able to source a new old Avon Roadrunner R2 100/90 that was a bit difficult to fit to the rim but didn't give me any clearance problems with the chainguard.
On the original WM2-19 front I have fitted an Avon Roadrunner AM20 which has performed fine this summer.
BTW Tony also advised against drilling the rim and fitting the security bolt as all I was using the bike for was pleasure riding as against speed trials or other high performance riding.
HTH.
Mick
1969 TR6
Re: T120 - a wider tyre, pros and cons? #104848
11/07/06 6:40 am
11/07/06 6:40 am
Stuart Offline
Stuart  Offline
Hi Johann,
I believe it's actually a typo - if you look in other Triumph publications for the model, and in other years, you'll find WM3-18 for the rear rim on a UK & GE bike; also, if you look at the other bikes in the range, they were all specified for WM2-19 front and WM3-18 rear.
